Jeep Grand Cherokee AWD Transfer Case Problems
lv06lv06 Member Posts: 3
edited February 2017 in Jeep
I was driving in forward then reverse to make a path in the snow when I heard a loud "clunk". My tires spun after that. The Jeep drives fine except that it is all over the place with no traction. Obviously, my 4 wheel drive is out. My Jeep is AWD and you would never even notice anything was wrong except in the inclimate Ohio weather we are having right now. I was told by a friend that my transfer case needs replaced. Now for my 4.7L it is about $2200 for the trasfer case. Could there be something wrong in the case and I would not have to replace the entire thing? Additionally, is it safe to drive in normal road conditions? Can I take it to the dealer and can they tell without taking the whole thing apart?
See Also: All Wheel Drive Explained
    gotoomangotooman Member Posts: 2
    I have a 2001 GC with 114500 miles that I just purchased. After about 5 miles of driving I hear a whining noise that is very irritating as I accelerate and slow down. It sounds like the tires are rubbing the fender well but that is not the case. It will not make the noise when put on a rack and the transmission seems to work fine. I was told possible wheel bearings, or maybe propeller shaft problem in front differential. The noise will go away when I slow to below 10 mph, anyone have this problem, I would appreciate any input. Already had right axle replaced thinking this was the problem/ Thanks
    tuggajbtuggajb Member Posts: 646
    could be front diffrencal bearings remove front drive shaft ant drive see if noise goes away
    can remove front drive shaft and run in 2 wheel drive for the summer and then replace transfer in fall have clutches inside transfer that go bad
    scraggly2scraggly2 Member Posts: 1
    just bought 2 weeks ago, learned the transmission was shot so i replaced it with a used one with 40k miles on it. The 2nd day after I picked it up, I was pulling out of taco bell on Dixie in the rain and the rear passenger tire broke traction and kept spinning – I thought it was odd that nothing buzzed and transferred power to the other wheels. it is full time 4wd with a quadra trac 2 transmission.
    I was putting the wheel speed sensor in tonight and noticed the front wheels spun freely in park while breaking the nuts loose. Didn’t think this was normal so I backed into a small ditch forcing the passenger rear wheel to spin. the front wheels were not getting power to pull me out of the small ditch, the passenger rear wheel was the only wheel turning
    using a neighbors lift,We lifted it 3 inches off ground, started, and put into gear and the front wheels did not spin
    When in park with engine off, both front wheels spin freely when turned by hand
    Also with engine off I can turn front driveshaft with hands
    Started and lifted off the ground the front driveshaft does turn, but motion stops at the front differential
    please help me if there would be any reason for the front drive shaft to be turning under power but the differential not transferring the power to either front wheel. It make no noises when driven at all.
    Email me at tsiefert@bellsouth.net with any suggestions
    do you see the front axelshaft to the front hubs?
    remove filler plug and see if front ring gear is there (could have removed that because of front noise
    i run mine in two wheel drive by removing the front axels because they cost so much to replace will find some in pick a part this summer
    thanks so far for all info: i took to different shop with good reputation, found out it was front left wheel bearing. had it replaced and noise is now gone, still might need to have rear diff worked on this summer but at least no one is starring at me as i drive down the road.
    chre012386chre012386 Member Posts: 1
    i was leaving work to night and my transfercase sounded like there was a bearing bouncing around in side. it makes the sound when in 4 wheel all time but not in 4 low. yet neutral and 4 low both engage as 4 low. so i am lost. please help
    repeterrepeter Member Posts: 3
    I have a 95 Jeep grand cherokee Quad-trac 4x4 all wheel drive...after a short highway drive it jerks and skips in tight maneuvers as in parking lots..believe problem is in transfer case;probably the viscuos coupler as suggested by other writers..I'm thinking of removing the front drive shaft for the non snow months of the year..hopefully this gets rid of the problem.My questions are ...will this improve gas mileage?...will it put too much strain on the transfer case,which is probably designed for four wheels pulling?...I do not intend to tow anything...at the very least it should isolate the problem and indicate whether the problem is in the front end or the transfer case/rear diff..any advice or helpful info would be appreciated...thankyou Peter helpet08@hotmail.com
    husker52husker52 Member Posts: 1
    I purchased a 2009 Grand Cherokee Limited brand new. After about 10 months and 9,000 miles the front differential went out, locking up the right front tire at 70 mph. Fortunately no traffiic around me so no injuries or damage to the body of the vehicle. Dealer replaced the front diff. under warranty. Exactly 12 months and 10,000 miles later, in year 2 the same exact thing happened again, only this time it didn't completely lock up right away and I was able to get off the road. Dealer replaced again, but Chrysler won't authorize any more work to determine the root cause and says it is "normal wear and tear". The dealer disagrees but it looks like I am screwed by Chrysler at this point. Has anybody heard anything like this before on these vehicles or does anyone have any suggestions as to root cause. I never pull anything with the vehicle and it has never been off the paved or gravel roads. Live in North Dakota so we deal with snow and ice on the road, but that is it. Dealer thought it might be the transfer case was engaged full time causing premature wear and tear on the front diff. Chrysler authorized them to pull some fluid and test. Claim everything is ok so now the dealer has been stonewalled.
    cherokee8cherokee8 Member Posts: 1
    I would look into Lemon laws and possibly seek legal action
    00jeepgc100jeepgc1 Member Posts: 2
    I have a 2000 Jeep Grand Cherokee Limited. When I make a slow, tight left-hand turn (like a u-turn, or in a parking lot) a violent grinding noise comes from under the car. It shakes all the way up into the steering wheel. I don't notice any leaks from either the transfer case or the transmission. I have replaced the transfer case about a year ago. After transfer case was replaced the grinding was gone for about a week, then slowly came back. I am completely out of ideas. It does not happen every time, but most of the time. It's as if some differential, transmission, transfer case is for that moment not having any lubrication in it. Right-hand turns never cause a problem, and I don't think I have ever noticed it while driving off road.
    amandanabmageeamandanabmagee Member Posts: 2
    If you off road check your track bar bolts and tie rods. If the bolt is loose it starts with the grinding and gradually over time will shake if not fixed.
    pjsideaspjsideas Member Posts: 1
    I bought my Jeep brand new, a GC Ltd. Had about 30,000 miles on it and was on a long trip, when the service 4 wheel drive system light came on. I called the service dept at my dealership and was told it was probably a sensor and would be ok till I got home, however if I wanted to find a dealer and run it by to have the code checked I could. I took it in when I got home and was told that nothing came up on the computer, and they reset whatever so the light would go off. It stayed off for months and then back on. Took back to dealer and they replaced 2 sensors at over 400.00 dollars. The light went off. After about 80,000 miles light back on. Dealer says it is the transfer case clutch. I never put my jeep in 4 wheel low as I live in the south and don't mud ride. They said it would cost over 2500.00 dollars to replace. I have done nothing and have had no problems with the jeep. I have had to have some axle seals replaced and other maintenance like brakes, etc. I take very good care of it and everyone is shocked when they find out it is an 05 because it looks so nice. Not good on gas and will have to replace soon as it now has over 125,000 miles on it.
    melm217melm217 Member Posts: 1
    I know your post is from back in 2011 but I'm having a huge issue with my jeep and it sounds just like yours as well as the 4wd light coming on. I have a 2006 Grand Cherokee Limited that I got back in 2009. When i first got it the 4wd light kept coming on and they said it was the sensor and changed it and it seemed to fix it for the time being. Maybe 6 months ago all the noise started, ive had to replace my tires twice so far since 09'. It was just in the shop for the grinding front end noise (this time it wouldn't go away as it had in the past), I was told it was going to drive like a brand new jeep once it was fixed, well........... $2,600 later (that including again, 4 new tires) I had my Jeep for about 2 days and it started making the SAME :cry: exact noise and vibration as what brought me to the dealership in the first place. I was told that they could not duplicate the issue. I had left my Jeep there a few days ago to have it checked AGAIN and now they are telling me its going to cost me another $1,800+ :lemon: to have the problem fixed. I was lucky it didn't freeze up like yours did while driving, and to read that it happened again for you again is disheartening. I was told by the dealership that the problem is the clutches that are in the front axle differential case and that by driving the jeep with bad tires is what causes it or even if you use your spare full sized tire with your older other three this would cause it too. It now at this very moment is sitting on the lift still at the dealership, they are saying that it is now completely stuck now in this state and it can not be driven until fixed. So I now have to redo the loan I got less than 2 weeks ago. Not Happy!!!!!
    I love my Jeep but I'm not sure if I love it this much :sick: . If by chance you know or have had any other problems with your Jeep could you message me back, please and ty :)
    laketahoegallaketahoegal Member Posts: 1
    I have the same problem with my 2000 Jeep Grand Cherokee. It grinds horribly when making a slow left turn and continues to grind when turning left even at higher speeds but not as loud. It was up on a rack at an auto store when they showed me that when turning the wheel left it actually sticks during the turn and then jumps back to where it should be when it gets past that point in the turn. I live in snow country and this explains why my jeep has be sliding instead of turning when I turn left on an icy/snow road.
    I've been told it's the CV Boot, Boot Strap, Transfer Case, etc. How do I identify what the problem really is and what do you think the repair should cost?
    Stuck in Truckee...
    whizzowhizzo Member Posts: 1
    I have 80,000 miles on an 08 Grand Cherokee (second owner) and am getting Service 4WD on the display. The error code is c1438. I am being told that the transfer case needs to be replaced. It shifts fine and I hear no clunks, grinding or whining noises. Is there a sensor or something else that should be looked at before replacing the transfer case?
    mussledmussled Member Posts: 1
    I took my daughter's 2005 Grand Jeep Cherokee for service and some repairs. Later, they called and told me the air bag sensor was coming on. When Jeep looked, only one was bad, but I was told that if they replaced one, all the other 3 would go out. I asked for the statistics on that, but all they had was the technician who said this always happened. He also said there were bottles rolling around under the seat that was the problem as there are sensors under the seat. I said there is nothing in the book about that, and no one told us. If there are going to be problems if you leave bottled water and it goes under the seat, shouldn't it at least be in the book as a warning?
    Has anyone had any of these problems. I really don't believe that about fixing one sensor, and the others going out, but how could I take a chance with my 19 year old?
    tahoegal1tahoegal1 Member Posts: 11
    I had the exact same problem, it turned out to be the CV Boot. It was pretty pricey, $450+ to replace the CV boot. We found a local independent auto repair shop and they replaced the whole front axle with a remanufactured axle which included a remanufacture of both of the CV boots, for only $250. $150 for the parts and $100 for the labor.
    We own both a 1997 Jeep Grand Cherokee and a 2000 Jeep Grand Cherokee, and we are the original owners. I can't tell you how much money we could have saved repairing our 2000 Jeep Grand Cherokee if we had known then what we know now.
    When you have an engine or transmission problem don't pay for any repairs until you have replaced both your TCM and PCM. These parts can be purchased online, for about $125 each and best of all you can install them yourself.
    We have had a huge variety of intermittent error codes and mechanical problems over the years including but not limited to: multiple fuel injector failure, limp mode transmission, engine electrical failure, alternator failure, transmission slipping and/or hard shifting, transmission won't engage, shifter stuck in park, engine won't start, engine quits while driving and the list goes on... The Jeep Dealership said our car was haunted, no kidding!
    All of the above issues were fixed when we replaced both the TCM and PCM. It was easy to do ourselves and now we love our 2000 Jeep again. NOTE: The 1997 Jeep was not affected, all of the problems where with the 2000 Jeep as it has a lot more computer controlled components.
    Hopefully, this will help you. If it does, let me know and spread the word :-)
    pjlittlepjlittle Member Posts: 1
    I haven't had this but 6 months, and I am starting to hear noise at 50,000 miles. I am not sure if it us U-joint, transfer case or transmission., or none of the above. I am not seeing an error code. This is the second Chrysler I purchased that seems to be a lemon. The last one was a truck that got two new transmissions is 11,000 miles. I'd like to know why they cannot build a vehicle that is a tough as a F150 and reliable as a GMC Jimmy
    1988xj1988xj Member Posts: 2
    I would love.a.1999.to 03, grand Cherokee,a v8 awd version of my Chrysler 300m? Oh yeah. Let me ask has all the.30k drive train service been performed on these jeeps?and.were all the.tires.matching? As a shop manager for 15 years I've always been wary of quadra trac, I see no ones.mentioned axleseals, which always leak and blow diffs out., are we changing transfer case fluids? Always hated the awd because of this, Durango can have a 59 2/4wd setting.mabey when I buy one ill insyall a np242, and just resolve this issue
    Subaru is worse, if you dont change.all four tires at one time and a variance of 2/3 32nds of any tire you will blow the.center viscous diff, something the.dealer never "romanced" during your purchase, or told.the.tire.industry yay.
    fjack1415fjack1415 Member Posts: 2
    Hmm, I was just reading that the Quadra Trac Jeep models do not have limited slip differentials on the front and rear axles. Kind of hard to believe but sure fits with your situation. Maybe Jeep figured good enough to have a limited slip diff going from front to rear. I guess just dumb luck I got a Quadra Drive when I bought my 1999 GC Ltd. two years ago. This whole thing of different drive trains for different models and years can get pretty confusing! PS I am no mechanic.
    Stuck in Truckee...
    I have a 1999 Jeep GC Ltd. with Quadra Drive that I bought used two years ago. A few months ago I started hearing these random chirping noises from under the car and then after a while I noticed grinding and crunching noises when parking and moving the wheels sharply. Then, just recently I started to hear a lot of ugly grinding and groaning noises when coming to a stop or doing just about anything. The problem turned out to be with the front drive shaft, apparently in the U joint in the rear, transfer case side of the shaft (although perhaps it could have been additionally the CV joint on the forward side of the shaft) Regardless, removing the front drive shaft solved the problem with ALL the noises in ALL the situations. I suggest you have it removed and try driving in to see if this fixes the problem. Now, putting in a rebuilt front drive shaft is about $|1000 and do not want to spend this money if I can help it. And, God knows, it could happen that I put the money into a rebuilt drive shaft and next thing the viscous coupler in the transfer case goes bad. So I am going to go without AWD and just rely on the real wheels, which normally get most all the power anyway. Actually my Jeep is driving better now. It seems to be friskier. The AWD is really only needed in true off road situations like getting into sand. But if you have a Quadra Drive system as I do (I lucked out when I bought it used, as I knew nothing about the various Jeep drive trains) you will get a limited slip differential (so I have been reading) on front and rear axles, so even without the front wheels picking up when the rear wheels slip, you will at least have left and right wheels in the rear working together to get you traction. From what I have been reading, for the Jeep drive trains for Jeeps newer than 1995 there should be no problem driving without the front drive shaft, that is, no damage to the transfer case, and no problem with the Park position on the tranny selector not holding the vehicle.
    superwksuperwk Member Posts: 1
    edited December 2015
    (excuse my spelling,on a phone)
    I have a '05 Jeep WK and as I was driving aprox. 45mph, my jeep jerked and my RPMs shot up to around 4500-5000 and Immediately lost all speed. I ended up rolling to a stop and had NO power. I tried Drive and selected each gear individually (1-4) as well as reverse. All gears (including reverse) acted as neutral. I first thought it was my transmission, but while on the phone wish the repair company, I told him the same story above. He said to try to push the jeep in park. It rolled! Even park acts as Neutral. He said it was the transfer case. Is this possible? I should also mention that my 4Low doesn't/hasn't worked in a long while. When I attempt to engage that I get a message saying "Service 4WD System" and there has never been an engine error code for that. If you have any quick thoughts or info, please message me at [Email removed]
    vetkammonvetkammon Member Posts: 1
    Dear all
    I have the same problem in my Jeep grand cherokee 1996 zj. There was a whining noise that disappeared after removing the transmission shaft. I do not know whether the problem is in the transfer case or in the differential.
    Anybody could assist please.
    Are you an owner of a 2014-15 Jeep Grand Cherokee who is trying to get some clarification on the recent gearshift recall? A reporter wants to hear about your experience. Please reach out to pr@edmunds.com by no later than June 22, 2016
    joebear1joebear1 Member Posts: 1
    I have the same issue as superwk. Can someone tell me how this is possible? I have to believe it's the transfer case. I've pulled it and there seems to be no issue internally. The only thing I'm not certain about is the clutch pack internal to the planetary gear set. If this clutch pack is bad, would that cause the jeep to drift in park? The output shaft of the transmission is locked when I shift to park. To me, this means there's something wrong between the trans and wheels (transfer case/differential. Both input opinions spin when spinning the wheels. Please help before I spend money on the wrong things!
    ray_suggsray_suggs Member Posts: 1
    I have a 2005 jeep grand cherokee laredo. The other day I was sitting at a red light, the light turns green so I hit the gas and immediately hit the brake (not hard) and the front wheels locked up. Won't roll in neutral or reverse. I had to get it towed. While unloading it from the tow truck I noticed that the rear wheels are turning but the front wheels are stuck. I know it's not the brakes because it will idle forward and backward about 5 inches. I jacked the front up and spun the front wheels by hand no problem. I'm at a loss here. I'm thinking it's somewhere between the transfer case and the front diff. Has anyone else had this problem? Also should mention the service 4wd system light has been on a while.
    FMFPIPEFMFPIPE Member Posts: 1
    I have a 96 grand cherokee thats FWD all the time I'm looking to swap the transfer case   so it can be 2x4   and have 4x4 when I need it. does any body know the part number or The name of the transfer case I need??m
    JeepGHOSTJeepGHOST Member Posts: 1
    Jeep Grand Cherokee Laredo 2002:
    I had the full wheel drive on and braked hard and swerved to the shoulder to avoid a collision. The Jeep would NOT stop with the brake firmly applied. I started fishtailing and hit the car that cut me off. Then I hit the center divider. The Jeep continued to spin out. I threw the car into park and was able to get it to stop but the wheels continued to spin out. I strongly believe it was the back wheels as the "spin out" sound was behind me. The only thing that was different is that I had the car in Full 4 Wheel Drive. Truly a Ghost in the Machine. The other thing is the key fell out of the ignition and the Jeep was still on. I luckily remembered I had a spare key in the center console. I then was able to shut down the Jeep. I called in insurance, Jeep Dealer, and the Police and nobody seems to care. The Police said the only thing I could do is hire an attorney and start a lawsuit. This thing is going to Kill somebody.
    I have been giving it a lot of thought and I have no idea how the transmission could be related to acceleration. I think it has something to do with the fact that I was in Full 4Wheel drive and the transfer case. But, I do not know. Has anybody heard of this? Does anybody know what could be the problem or would cause this?
    dragon5126dragon5126 Member Posts: 15
    Lets set things straight first. Despite erroneous advertising material, there is no such thing as an "AWD" GC. these are TRUE fulltime 4WD. I have been driving Quadra-Trac setups as well as rebuilding the transfer cases since 1976. They are one of the strongest chain-driven xfer cases ever made, bar none, and what isn't realized is they are front-wheel biased drive. When one of the front wheels slip, the rear axle locks in. This can cause unfamiliar noises in many instances and isn't abnormal as long as it isn't constantly happening institutions when the transfer case should not be locking in. Axle seals don't blow differentials out, lack of proper maintenance of the differential fluid does. since the axle tubes extend into the diff housing, not all the fluid can drain out so the gears can only run dry if the bottom of the pumpkin is fractured (Ived personally done this, experience speaks volumes). Your claim of the "awd" being a problem because of this holds no reality since this would affect all rear wheel drive vehicles, and it doesn't. Your Opinion is yours and you are welcome to it but please make sure you are basing it on facts so that you are not lying to yourself and others.
    This Is a KNOWN issue that results from OPERATOR ERROR. Under no circumstances should you set a quadra-Trac driveline to full 4wd while on road. In this setting all four wheels are locked together. NO SLIPPAGE. Your primary braking is done via your front wheels. with drive still applied to your rear axle you will be spun around. Even GM and Ford suffer this issue. Most owners manuals warn not to use this setting onroad. Landrover even supplies training to new owners that includes this. Its compounded by automatic transmissions and lockup torque converters...
    a note on your key falling out of the ignition switch... there is a recall on this, I believe it covers your 2002, it did on my 2005.
    edited September 2020
    I don't recall the transfer case number (edit: the transfer case I recommend is the NP 229) off the top of my head, The option IS called Selec-trac, I pulled it out of my deceased 98 grand Cherokee Larado to install in my 2006 TJ Wrangler in order to gain 4wd ONROAD ability (the transfer case has 2wd, 4wd, 4wd locked 4wd low and of course, neutral). Living in Wisconsin on the shore of Lake Michigan, full-time 4wd for on-road use in such a light suv is a must. Without it the clutch is literally ripped apart in under 2years due to the torque applied.
    edits came after I double checked my notes.
    it sounds like you may have snapped the drive chain in the transfer case. if you are a half way competent mechanic you are in luck. They are easy to rebuild. The xfer case ID is on the rear of it, grab a flashlight and go get the info off the red round tag, look up the exploded parts diagram for it. Go to your local used parts place and buy a replacement. split it open, order a new chain and any worn parts reassemble using your original speedo sensor and drive yokes.and you should be set. BUT before going this far, when you disconnect the front propeller shaft, make sure you can turn the front wheels with it. if you cant, then its the front differential. And I hate working on those due to setting spacing...
    Not knowing which transfer cases are in these individual vehicles all I can offer is an educated guess. That would be that the Viscous Coupler went south, this is the first component in the transfer case, that takes the output of the transmission, it is essentially a can of plates of steel and super thick silicon fluid layered between each other this fluid is quite literally thicker than that used in breast implants for those with that particular knowledge. when functioning properly, it acts as a clutch and the input breaks free from the output allowing front and rear axles to function independently. If the mounting of this unit is damaged even when it is locked out, no drive from the transmission will reach the rear axle, Also if the splines on the interior of its input are stripped no transmission output will be passed. This is the most Common reason for loss of drive in quadratrac drivelines, however, keep in mind, we are also referencing a system that goes back to the seventies with substantial success, and has been licensed to most AWD automobile mfgs from Subaru to Audi and BMW...
