Toyota Highlander Navigation Issues
Hi Everyone,
Was wondering if anyone knew where I could find a navigation tutorial for the 2008 Highlander, preferably online.
Gilbert
Gilbert
http://www.toyotaiguide.com/content/08Highlander/iGuide.htm
Navigation guide
http://www.toyota-eshowroom.com/partner/HighlanderNav/toyota_nav.html
I remember seeing that there is a pre-start workaround that must be done each and every time. The post directed to a google search, I have not been able to find it. Was I not understanding?
I really don't want to do the hardware work around.
Thanks for the info.
Guess what, after the XM receiver was installed it all sounded great. Once I tweaked the settings (bass/midrange/treble, fade and balance) it sounded even better and all is well.
I still need to read the manuals.
John
any and all help will be appreciated!
I live in Chicago, but this has happened both downtown and way out in the suburbs.
Is there a way to fix this?
2014 Accord Touring
Once the extension module was replaced i was able to notice a sirius radio problem (it may have existed previously but never had the opportunity to experience it because unit kept rebooting). I loose the sirius signal for no reason-- I drove the car on saturday the first couple fo hours no problem--parked for 6 or so hours and then drove the same route and I must have lost the sirius signal 20 times in a matter for 2 hours--also periodically get a message on the screen that says to check antenna. this problem has been going on since early January when they replaced the extension module--meeting with the techinal field rep from toyota next week, Good look--- my understanding is there a bullentin on the extension module (my dealer spoke to toytoa to get advice relative to that fix)--- keep us posted
a question for all of you---when listening to the radio and using navigation does your radio's volume decrease so you can hear the navigation insturction---mine does not but it did on my 08 Sequoia
Whatever happened with the Sirius issue? Sounds like the antenna was somehow unplugged when they fixed the first issue. However, I have dropped the signal in the past with Sirius/XM when between large buildings or out in the middle of nowhere. The volume on our radio does decrease slightly when the navigation is giving voice commands. It doesn't drop too much and does not bother me.
On my front I just got off the phone with the general manager of the dealership. Seems like a good guy and got in touch with the regional folks. Around here they have not heard of the issue, but they seem willing to give it an honest try. I did pass on the information you gave me to see if it may help them. Thanks and I'll keep you posted.
Spent about 2 hours yesterday with Toyota's field technical expert--what was determined was the PROBLEM with my sirius is "CHARACTERISTIC" of the highlander. We drove another highlander and it it did the same exact thing--toyota considers this normal. Currently have two other non toyota vehicles with sirius and neither vehicle does this. Also the 08 sequoia that I sold in December didn't do it either. Another loyal toyota owner no more--this will be my last toyota (have had 5 others prior to this one) and last Saturday I bought my son a mazda.
No for you--I had the opportunity to talk to the field technical expert about your current issue and my previous issue and he stated he has seen it before and that the extension module replacement is the fix.--good luck
ANYONE interested in a 2013 highlander limited less than $6500 miles--very seriously thinking of getting rid of this vehicle
good luck Pheaton
Another issue I am having and would appreciate feed back is that the navigation screen when you have it on DVD setting has a play and pause button but the DVD when loaded will not operate from the touch screen I have to use the remote to get the movie to start. Anyone have that problem. Dealer said that system was designed to work only from remote.
Appreciate any help or feed back from anyone on any of the issues.
Ed
I've got a similar issue with a 2013 Highlander that started about a 3 weeks ago. The sound system started rebooting while bluetooth is enabled on my iPhone 4s, and it reboots approximately 30 times, and then just shuts down. If I turn off bluetooth on the iPhone, then the sound system works fine (minus the ability to use bluetooth to talk on the phone).
Spoke to dealer they past on to Toyota. waiting for reply. Now when i start car Navigation goes back to complete start menu this is my 4th kluger three have had factory fitted navigation Never had any trouble before.
I have not heard on any complaints in klugers will have to wait and what dealer comes up with.
