Also, the engine light came on and we took it in the diagnose it and it says a gas leak (??!?). This happened before and we took it to the dealership when it was under warranty and they said they couldn't find a problem. The light came back on so we took it back. I don't know what they did, but we didn't have the problem again for about a year and now the same issue is happening again. Ford says we have no warranty now (another story - they have been so disappointing and I will NEVER buy from them again).
Are these two issues possibly related and what needs to be fixed? I know nothing about cars so I am nervous to get ripped off. :S
Thanks so much for any help!
The valve leaked, replaced it
The seal of the level control replaced.
It was determined today after the radiator was replaced, that the vacuum hose is not working on the heater valve. The hose was left disconnected and the heater is now working.
The heater valve was purchased and installed by Kaufman Tire Service. The radiator was installed by a referred mechanical service. When the heater did not heat, the mechanic checked out the heater valve and determined the trouble was with the new heater valve system.
I would like input regarding how confronting Kaufman facility that performed the work. This was a cost to me in the amount of $218.00 and it's only been 11 days from repair/replacement.
Thank you for your time.
Constanceb
Plus, please put your comments on what happened on Yelp. People do go by Yelp in getting services.
Any solutions, or ideas? Thanks.
If you google 2002 ford explorer blend door gears, you will see the box im talking about, and you will be able to tell which part you can "temporarily" take apart and stick back into the truck to have a quick fix if they have to order the part.
i have narrowed the problem down to a vacuum problem. There is no vacuum on line to heatcontrol valve and no leak on line. Vacuum diagram shows an outside resurculate door vacuum motor between the inside instrument panel line and the heater control valve outside line.
IS there anyone outthere who could point me in the direction of locating the vacuum motor where is it and how difficult is it to replace?
Thankyou
A/C was blowing hot. Turned to vent control, expecting outside air (upper vent and combination upper/lower settings are the two settings that do NOT use A/C compressor). Air was very hot.
Turned car off, turned key to on. Vent setting blows cool outside air. Start car, air immediately turns very hot. Temperature control has no impact.
Seems almost like when the car is running, the air is being pulled directly from the heater?
This doesn't seem to be an A/C charging issue since I can't get the vent to even work. Started to do research, but I don't have A/C repair experience. If it's a mechanical problem, like some door broke and I can get to it to replace it, might be able to remedy situation.
I'm thinking that since we only have a few more weeks of hot weather, I MAY choose to temporarily pull blower motor fuse to see if that makes the vent funnel outside air while driving.
I've read about blend door issues, but haven't figured out how to diagnose that yet.
Thanks in advance!
jetmech_63, "Ford F-Series Climate Control" #1, 10 Oct 2006 11:48 pm
Drivers side has great heat. Same issue is present whether I select defrost, vent or floor heat. Drivers side works fine... Now that its cold out this is an issue...
paratechs@yahoo.com
You have a relay under the dash to the right of the gas pedal behind the radio
If both front and rear heat and AC aren't working, you must have a door blockage somewhere if you aren't getting any air flow of any sort. This presumes a) your fan is working and b) your AC compressor is engaging.
Please what could be responsible? What can we do?
