With a factory level scan tool the first step is to confirm if the instrument cluster is present on the data bus when the problem occurs. Then one has to confirm powers and grounds as well as confirm if the system uses a wake up command to turn modules on and if it does the tech has to confirm if that command is being received. When you approach the shop describe the problem and the frequency of the events. Set an appointment in a manner that they will take the car in the next time that it happens, without you disconnecting the battery to make the problem go away.
