Too much oil is indeed a problem; the issue is when the level is too high, the throws of the crankshaft beat the oil into a froth, at which point it can't be pumped, the pressure goes south, and the engine is toast.. how much is too much depends on the engine, but since shops routinely overfill by a quart or so, there's some leeaway built in. I went like half a pint over, being the cautious type myself
And you're right, I should just chuck a qt under the trunk floor. Just don't feel like my wife should have to mess with this. They'll be back tomorrow.. so far, no warning light.
Cheers -m
I'm pretty partial to Mazdas these days.
If you want something significant to worry about, there's this:
TESLA HACKED
I pulled apart the steering on my '69 Econoline in order to replace the idler arm bushing. On mine, the actual bushing between the post and the sleeve (as viewed in that link) was completely disintegrated, leaving behind a fairly substantial amount of play that would manifest itself in "interesting" ways.
However, the "bushing" was more than just a bushing, but included the sleeve and the post as well, so I needed to press the sleeve on my van's mounting bracket out in order to get this one in. The problem is that I don't have the tools to accomplish this, and my attempts to use what I do have did not yield results.
The guys at the shop worked it into their schedule within an hour of my dropping it by and charged me $15 for the effort. I asked the rep to bump it to $25 and be sure express my gratitude to the tech. For me, just saving the aggravation of messing with it was worth that! I don't throw these guys a lot of business (as I do most of my work myself), but I do appreciate their attitudes and competency when I need them.
Must be a good day for projects. I youtubed my frig and took the faceplates and icemaker stuff out of the freezer, pulled the evap fan and played with it on my "bench" with a lamp cord. Stuffed it back in the freezer with some foam padding to try to keep any excess moisture away, theory being that the fan was icing up and that was causing it to hum loudly.
So far so good, and got it back together with no extra parts, but it may take a day or so for the icing symptom to manifest itself again. If that happens, I suppose I'll order a new part and try that. Techs often go out and "fix" this issue with a heat gun.
The poor techs have to compete with every parts company and Joe Blow handyman posting fixes all over the net now. There were at least four videos just on my little problem.
I have my Mazda 5 in for an oil change at a bit over 5k since I bought it. To tell the truth if it weren't for warranty possibilities later I;d let is slide a couple more. Not down a drop and still clean.
Most don't even know how to correctly gage the oil level with a dipstick today anyway. The "correct" oil level is usually anywhere between the minimum and maximum marks, not at them. People often add oil beyond the fill spec. Some of the Toyota Prius for example have a fill spec of 3.9qt with the filter. They should NOT get all four quarts. With the Atkinson cycle engine and low tension piston rings any extra oil can result in oil making it from the cylinder back into the intake manifold, eventually collecting enough that it can get drawn back in to the cylinder during a hard acceleration and result in oil fouled spark plugs.
As far as someone not commenting on a post, its interesting that everyone avoided the last one I put up here referring to the threads on linked in. For all of the criticism the trade gets about price, seeing what these managers demand for wages while the trade self destructs under them should have gotten more attention.
So there's ~6 years under warranty. At some point it'll be easier for the manufacturer to simply swap out the rental or CPO and ship the broken car to Central Warehousing for recycling, instead of paying techs in every dealership to fix something. Think VCRs or TVs or toasters.
Call it the subscription model.
I'm kind of with xwesx here.
In Pa we cannot fail a car for rusty brake lines. Brake lines fail if they are leaking when we look at them, but pass the inspection if they are not leaking. Techs should advise the customer about the findings during the inspection and if the lines appear to be bad enough recommend that they be replaced but that's all they are permitted to do. There is a very good reason why its done this way. Allowing the lines to fail the inspection based on what they look like leaves the tech open to be wrong both ways in that if the tech could fail a car that someone else judges the lines to not require replacement, or the tech could pass a car only to have the lines fail shortly afterwards.
Now for the fun one, do the wheels actually have to be pulled to inspect the brakes? There are cars today that do not require the wheels to be removed in order to measure the brake linings, with disc brakes. There are some with drum brakes that the manufacturers have installed inspection ports in the backing plate and the basic check of those assemblies is all that they require unless there are other symptoms that suggest there is a problem with the system that goes beyond basic wear.
Rust, rocker panel rust can fail in some cases, and not fail in others. Even then it can be somewhat subjective.
Make sure you read through the comments, one poster now expects that the techs will fail everything and that will cost him/her more money.
I found this after a quick search. http://dmv.vermont.gov/safety/detailedinformation
I always have a difficult time with scenarios where one person is held accountable for the effects of another person's actions. If the car really was passed without performing the required inspections, then that is a failing of the shop/tech. But, if the inspection was done to standard (how do they know it wasn't, exactly?), it's pretty desperate to blame the shop for something that happened months later.
Cars fail. I've experienced brake failure before (master cylinder went bad), and it is really scary, but then I drove another 1,500 miles to Alaska before fixing them, so I also know that the most likely reason this woman died was because her husband panicked when the brakes failed.
The Savvy Aviator #51: A Mechanic's Liability (avweb.com)
On this page the author states that the fee for an inspection is based on the shops labor rate, and then there is the $10-$25 quote in the above link.
This forum does mention prices in the $35 range, but what really gets some attention is the fact that several state that the inspection typically took the techs about 5 minutes.http://www.city-data.com/forum/vermont/586208-places-car-inspection.html
Note how some tell others to avoid certain shops that find things wrong with the car when doing an inspection. They try and make it appear to be unethical to actually have to repair a car under the program, so its no wonder that some techs would end up essentially selling stickers. They come off as hero's for not doing the job, that is until something bad happens.
Last night on the way home, I saw a 2006 Subaru Forester disabled on the side of the road with generous amounts of steam rolling from the engine. I stopped to help, and they had someone on the way already, so we chatted about the apparent issue. The guy who was with the owner (a middle-aged lady) said he figured it was "just a thermostat," but I took one look at the coolant overflow bottle and said that they definitely had bad head gaskets (as was clearly evidenced by the massive amount of combustion gunk built up in there - a telltale sign on these cars).
Immediately, the lady launches into a tirade about a local auto shop, where she took the car only a week earlier as part of her getting ready to sell it, and she had asked them for an inspection and to top off all the fluids. Well, they quickly came back with telling her that it needed new head gaskets, as well as another $600 or so in other odds and ends, for a grand total of $3,700. She then went on to say how they "didn't even top off the fluids like I asked them to, so I had to do it myself!" She specifically noted that the PS fluid and brake fluid were not done, etc.
Without trying to disregard her concerns, I noted that they weren't wrong about the head gaskets, and that it is a very labor-intensive job. I related my past work on the subject and the time involved (took me about 18 hours of labor), as well as the cost in parts. She wasn't very encouraged by all that, but hopefully came to realize that the auto shop (which generally has a good reputation) was not trying to fleece her. She asked for an inspection, and they clearly did one, but she already had the expectation that it was in top condition, so hearing otherwise only served to disappoint her.
My sister, the one lusting after a MINI (for several years now), has an '05 Forester that won't die. She doesn't really want to trade it or buy a MINI until the Subie starts giving her trouble, but it's pushing 160k and no leaks, and has the original gaskets afaik (she got it used). Complaints for that year don't seem high anyway but there are some reports on the net.
Meanwhile this is interesting. http://www.autonews.com/article/20150706/RETAIL05/307069993/asbury-takes-tech-shortage-into-own-hands $12. hour to go to their training program and they give the tech a starter set of tools and $5000 at graduation. The only requirement after that is the graduates have to commit to working for the dealer for a year or else they have to return the tools and some of the money for the schooling. I know a shop that is looking for an entry level tech, which is what you would have after a program like this that wants to pay $10/hr.
For instance, if parents are going to fork over $30K to $60K a year for a kid's college education, but this kid is really into Porsches and Ferraris, why not pay an independent Porsche facility to educate him instead?
This system relieves the shop of having to support a non-productive newbie for a while (the rule being that an untrained person at a repair shop costs the shop money for the first 6 months, then "breaks even" the next 6, and finally starts making the shop some money after that).
It also relieves the apprentice of having to work at the shop after his training and can also pay for his tools. Part of the apprenticeship would be in business management, so that the newbie will have a better chance of success once he's on his own.
This program would be for young people who really want to go to the top of their game, and carve themselves a reputation perhaps in auto sports, aftermarket product development, restoration work, or even sales.
Amazon and Google start warehouse workers at $12/hr, just down the street from me.
If you can't pay more than that for a tech, you might as well close up.
well, you probably already guessed that is not the end of the story. Still didn't work and I set about testing every damned component without any luck. High pressure switch OK; low pressure switch OK; compressor OK; fuses OK; relay OK; cabin temp sensor OK. It just wouldn't complete the circuit through the relay and send power to the compressor. Seemed it had something to do with the ECM not doing its job. After much web surfing, I finally found a post where someone had removed and reseated their ECM to solve what sounded like the same problem. Eh, can't hurt, right? Sure enough, that cured it! So it took about 4 hours of my life for what amounted to about 30 mins of actual work, all told. Ugh. At least it didn't cost me anything in parts.
Then again, ravens and eagles short out transformer stations now and then.
(edit - found a good link about the
entomologyetymologically of "buggy")Back when that was first written in the Washington post and the related TED Talk was reviewed it had of course mixed reactions in the automotive tech and shops world. Some parts were felt to be correct but most of it was believed to be over-hyped. One particular concern that those outside of the business would likely overlook was about the "go-fund me" aspect of it all. The most notable part of that was how Ms. Banks was way off target with her reported needs when it came to the kind of capitol that is required to open a shop and just what one really needs to have in order to open a shop. On just the financial perspective, she missed the mark by an order of some ten to twenty times, and depending on a given location and the shops targeted specialty it could even be some multiple of that. Worse yet was her focus on material inventory as compared to the tools and equipment required to provide the services that the customers would need her to have. If she was really ready to be a technician/shop owner then her business plan (and help request) should have reflected the real costs of opening such a business. That should be seen as a concern to consumers because anyone opening a business without a solid business plan usually finds themselves in trouble in a hurry.
A few of the women shop owners from this group
http://www.carcare.org/womens-board/ did reach out to her unsuccessfully.
http://www.autonews.com/article/20150911/RETAIL05/150919958/colo-dealership-held-liable-in-test-drive-accident
The dealer is liable for the accident while the customer was driving during a (new to her) vehicle purchase.
Mine: 1995 318ti Club Sport; 2020 C43; 2021 Sahara 4xe 1996 Speed Triple Challenge Cup Replica Wife's: 2015 X1 xDrive28i Son's: 2009 328i; 2018 330i xDrive
So nothing much has really changed, although you may not like how it works.
Now I understand why so many dealers have been willing to let my wife and I take off on test drives by ourselves.
Meanwhile, Asbury Automotive Group, of Duluth, Ga., northeast of Atlanta, this year has hired about 200 service techs across its 86 dealerships including adding "a significant number" of what the company calls "quick lube techs and tech trainees," said Renee McKenzie, Asbury's vice president of human resources.
Asbury wants to add another 250 techs over the next 12 months, primarily in Florida, Georgia and North Carolina, McKenzie said. Besides training techs internally, Asbury is getting them through referrals, outside hires and technical schools and local high schools.
An increase in warranty work due to recalls is diverting service technicians from high-profit customer-pay business, D yke said. Honda and BMW, which have issued wide-reaching recalls, account for 30 of Sonic's 102 stores, he said.
In March, Sonic created designated "warranty teams" at its 15 Honda stores to deal with warranty work and free other staff to do more customer-pay business.
Likewise, said [non-permissible content removed]: "I'd hire another 200 immediately if they were available. We're building new stores left and right and we're adding lots of service capacity."
Respectfully Tom that article is just marketing propaganda written by high level people disconnected from tech's entirely. I consistently see the really good tech's leaving the big dealerships to get paid more by the independents. They usually earn commission there, do no more warranty (which we all know is a time/money waster for tech's and writers), and they don't have to work Sundays.
These big dealers are "always" hiring new tech's because they are always loosing them by not sharing the proper amount of the profits with them and forcing them to do the low paying really long and complicated jobs while the lube techs make more than they do and know less
The "non permissible" BTW was a guy's name, suspect he is Scandinavian.
But good luck finding one.
There are just too many bad aspects to the career for the talk to make a difference. The trade will continue to fail until flat rate goes away and the working conditions, wages, and benefits get moved to where they need to be.
It already happens with engine "rebuilds" - I'd rather have a reman than have a dealer do a complete rebuild of my engine (or transmission). Plenty of techs can't even get an oil change right.
Cars are pretty dumb items anyway; for all the improvement over the decades but they still are a bunch of bits and pieces that bolt together and then get covered up by pretty sheetmetal. When you pop a panel off, it's either a wiring harness mess or a bunch of parts that have to fit together just so to work, and when something wears or breaks, the whole shebang has to be disassembled to fix it. And often the part is surrounded by other parts or hoses, with frozen bolts and sharp edges to contend with.
The thing is, though, that automotive work really IS fun! People go into this field because they love it; it's interesting, challenging, and rewarding work! So, it's a shame that the "industry" has figured out how to make the work a drudgery such that all the negative aspects overpower the inherent rewards of the job.
