Wheel Balancing - When first try doesn't work
Couple of thoughts about wheel balancing:
Have them check ream of suspected wheel it's may be bent out of round and most balance equipment wouldn't catch it if damage not to big, it can be fixed. If you have difficulties with new or almost new tire it may be no good and needs to be replaced. As of the size of the tires, you probably driving GM large(performance) sedan and those cars not that reliable as they use to be and wheel bearings is worth checking. If you stuck with one out of balance tire - use it as spare, or at least on the rear axle - less impact on driving this way. And at last, you can make intervention in balancing process, freak out and make them to do it your way. BTW don’t let them use impact wrench to install alloy wheels(to remove it’s OK).
Thanks for your input. Actually, the tires are on a brand new Diamante, much more quality and precision than a GM sedan. True, it may be possible I have a bent wheel or other non-tire defect, but the way to find out is to get a proper balance job done first. I think the problem I am having is due to the fact that the dealer only does a "quick and dirty" balance job. That's probably the same at most tire stores. I need to find a shop that can do precision balancing.
I really agree with you on the impact wrench comment. Go to News & Views conference and see topic 291, first message. If you read all the messages there, you need to then jump to Maintenance, topic 14 where the conversation picks up again.
I found an excellent web page on balancing at http://www.dsm.org/how-tos/wheelvibrations.htm
I suspect one of my tires is causing the problem. It has twice as much balancing weight as the others. They put it on the rear, but that is no solution since I will rotate it to the front in 5,000 miles.
I am considering putting the spare on the alloy wheel and retiring the tire that needs the extra balance weight to spare duty. Thank goodness the spare is a full-sized one and I only have 2,000 miles on the car.
Have speciality shop check the suspected ream. My suggestion is to turn to a place which sells aftermarket alloys, they might have some expirience with it.
The next time I owned a sports car was two years ago. My fourth generation Z-28 Camaro had the awesome LT-1 275 horsepower engine, and an equally over-performing chassis considering it was live axle in rear. It came with nitrogen gas charged shocks, rack and pinion steering, factory alloys and P245/50/ZR16 Goodyear Eagles. It's tight, on-center feel and steering response I could have only dreamed about when I owned that Datsun 240Z.
If ever a candidate for balance problems, I would have thought the Camaro would be it. But no. I took it to Goodyear. Computer spin balance, puts weights on inside or outside depending on what computer says, I drive out...it's perfect.
So I'm inclined to believe, still other factors are at play. Out of round tires, ply separations, bent rim, warped rotor cannot be ruled out.
I don't have Mitsubishi specs but the max allowable radial runout for a Honda aluminum wheel is 0.7 mm (new) or 1.5 mm (used). Max axial runout for the Honda is 0.7 mm (new) and 2.0 mm (used). I recall an old Ford spec for radial runout of the tire; 2.0 mm maximum. These are probably worth checking.
One vehicle I couldn't just balance was an '87 Mustang with 225/50R16s on 16x7 2-piece light-alloy wheels. These tires had to be trued (ie cut round) to be vibration-free.
*--since steel is an alloy, ALL wheels are 'alloy' wheels. So...aluminum and magnesium wheels are 'light-alloy' wheels.
I checked all rims for lateral runout and they were within .004". The spec is .040", so they were well within spec.
I took the car to a Goodyear dealer (the tires are Goodyear and still under warranty). They found two of them have treads that wobble. They have ordered me two new tires (free, under warranty) and I will have these installed soon.
A third tire showed excessive radial runout. The tire store said the alloy wheel had excessive radial runout and needed to be replaced. The way they checked the radial runout was to hold a stationary bar against the inside of the wheel and rotate it. It made an irregular scraping noise as a low spot passed the bar. I suggested that radial runout should be checked by dismounting the tire and using a dial indicator to measure from the surface the bead seats against. It would seem that the exterior of the wheel is not as perfectly machined as the bead surface. Also, the runout spec is .040 and that is enough to make the scraping noise irregular. They didn't want to go through the trouble, saying they were confident that their method worked.
Anyway, I had them write that the wheel is out of round on the repair order and I took that to the car dealer and they are ordering me a new alloy wheel (free, under warranty). I will have the wheel replaced and the tire remounted on this new wheel.
Once all has been done, I will report back the results.
Interesting note, I had bought Goodyear tires many years ago and all four had tread separation. My brother recently bought a set of Goodyears and they had irregular treads. Out of my set of four, two had irregular treads. What gives? I never had that problem with Bridgestones, Yokohamas or Michelins. Is this another case of import products being superior?
Michelins. Is this another case of import productsbeing superior?
You should go to Costco, and talk to the tire guys... The "Kirkland Signature" tires used to be made by yokohama. But after numerous complaints, and after mucho $$$ wasted because those tires never lasted even close to warranty specs, they switched back to Uniroyal Tigerpaws....
So, not likely....
So, I can't speak for contract tires made by Yokohama, but I have had two sets of real Yoko's in the past and never had a problem with balance or irregular wear. Got about 60,000 miles on each.
Bridgestones, same story, except based on wear so far, my wife will probably get the claimed 80,000 on her Bridgestone Turanzas.
I agree that the method used by your dealer did nothing to quantify the runout; the "scraping noise" could have been very distinct with something less than 0.040". As you indicate, you are lucky that the auto dealer accepted the tire dealer's "best guess" that the wheel was faulty.
I believe in a previous post it was also suggested you could have a tire or wheel problem, not balance.
When I rent late model American cars, I find trim parts loose, rattles, paint flaws, etc. I have rented Galants and Corollas and they have all been flawless. And I vacation out West where I take cars places the rental company would not be happy about.
So when one sees industry statistics and has similar experiences to back it up, he forms...you guessed it...bias.
But I can't have a bias about the tires...they're radials.
But this topic is about wheel balance. There are other topics devoted to American versus Imported. So, on to the wheel balance topic:
Actually, I do not agree that the rim is out of round. Radial runout typically does not cause steering wheel shimmy at 60 mph. Runout problems show up below 40 mph, balance problems above that.
The fact the Mitsubishi will give me a new rim is just an example of good customer service. They are going to actually give me the rim to take to the tire dealer (at my request) to have the tire remounted. That way I can have the tire dealer verify if it was the rim or tire and resolve the problem all at once. Since I will have the new rim over the weekend, I will mount it on my car and check the runout. Then when the tire dealer gives me the old rim to take back to the dealer, I will try to mount and check it, too. I then will know if it was actually out of round or not.
As to my comment about Goodyear tires, that was a question based on my own experience. I do not have any industry stats other than to note that Goodyear ranked about average in J.D. Power. Michelin usually tops the list.
JD Power ranked Oldsmobile as being more reliable and cheaper to maintain than camry and accord....
Also, CR polls its readers... Now there is a scientific poll if I ever seen one.... (Chicago Tribune declares Dewey as the presidential winner by a landslide, according to a poll.... Too bad he lost)
It would be better if CR showed how many complaints were submitted on a particular vehicle, along with the number of comments total received....
If 2 people say the Intrigue's fuel pump died, but only 3 people responded about the intrigue, that ain't saying much...
You are just biased...
While I was in college, my GF's 94 Integra GS fried its PCM after only 5 months. My other friends GS-R had an engine replacement... My friends 98 Accord V6 lost its fuel pump with less then 100 ticks on the odometer....
But these things don't really mean anything.... Just because it happened to my friends doesn't mean it will happen to everyone...
My old buick has like 170,000 miles on it, and never had any problems... My parents Chevy has almost 200,000 miles with zero problems... Just an ignition module replaced, but that was a 5 minute job... (and technically can be considered routine maintence, as that part is listed under one of the tune-ups...)
None of our domestics had any problems... I also have a 99 Lexus ES300, and its sunroof decided to freeze shut, and is less than a year old... Its also not getting anywhere near its EPA rated fuel economy, while my GTP is continuing to get BETTER than the EPA rated fuel economy, (which happens to be higher than the ES300's EPA economy)
Anyways, its extremely hard to prove/disprove import/domestic superiority/inferiority... Its pretty much even ground right now...
Also, paint is very dependant on how you care for it... My cars have excellent paint jobs... I take care of it... I wash it, wax it, polish it, clay it, etc etc... When I went to the dealer for whatever reason, be it Performance Parts, or whatever, my 1 year old car lustered and shined more than the cars in the showroom...
Also, my friends grandpa... He never takes care of the paint... Its sad... He has an E320 Merc that had all its paint flake off... His idea of a car wash is taking a hose and a rag to the car... Its pitiful.... He just got an LS400, so we're trying to get him to take better care of the car...
"...I can't have a bias about the tires; they're radials...." Enjoyed that!
Now...I decided to measure the current rim (tire is mounted on it) at the same place that the tire dealer did: from the inside edge. I got .002 runout. I'd say that was excellent. I rechecked lateral runout and it is within .004, same "perfect" measurement as all the other rims.
So why did the tire dealer think the rim was out of round. I noticed that they mounted it on the balancer using a cone on the inside and a large disc on the outside. I say that would allow the rim to not seat perfectly centered, causing the illusion of an out of round rim.
I go back to the tire store tomorrow morning for the tire replacements. Now I have to convince them that they need to hold the rim with two cones so that it centers on the balancing machine shaft. Now I wonder about the validity of all they have done so far.
I will report the results.
I think it's unlikely that two cones would provide the proper setup; two cones could conceivably allow the plane of the wheel not to be perpendicular to to the axis of rotation. As avs007 indicates, the cone must center on the appropriate machined part of the wheel; an incorrect cone could cause centering on a shoulder of the cast wheel which has not been machined for that purpose.
They mounted the two new tires on the right side and rebalanced the LF tire, all using the proper mounting on the balancing machine.
End of story? Nope, still have a vibration. It's either the original LF tire itself or something in the drivetrain. It's not the engine or torque converter, the balance is the same regardless of gear. I can even put it in neutral and no change in the vibration.
When I get some time, I will put the two new tires on the front and see if that makes a difference. I will also check the drivetrain to see if I can find anything that contributes to the balance. I will also go to the dealer and drive a similar car. Remember this vibration is slight and maybe it is just a characteristic of the drivetrain. A resonation of the parts at a certain speed.
Mitsubishi has graciously allowed me to hang on the new rim for a couple of weeks while I check thing out just in case I do find a rim problem. They also are checking the national service records to see if anybody else has reported a vibration problem.
Question #1. If I jack up the car with both front wheels off the ground and check for a drivetrain vibration, would that be a valid test, or would the axles be at too severe an angle with the wheels at the bottom of their suspension travel?
Question #2. I can't find any specifications for axle or CV Joint runout. Anybody know what a reasonable runout would be?
Question #3. This car was made in August and I bought it in December with 31 miles on it. That means it sat in inventory for a few months (this is a very low volume car due to zero marketing). Could the tires have flat spots from sitting such a long time?
#3 - Flat spots are not usually a problem on radials as they are on bias ply
P.S.
Another topic somewhere it was stated that if you feel a vibration through your feet through the floorboard and body, but not the steering wheel, you can rotate a wheel from the back to the front, one at a time. If doing this causes your steering wheel to vibrate, you have isolated it.
Or it might be the method for identifying which corner of the car has the vibration.
You take a strobe light that gets triggered from a vibration sensor, and spin the wheel on the car using a floor jack and an electric motor. The strobe light freezes the action, allowing you to see where to put the wheel weight. The vibration sensor itself can measure the amplitude in units like inches per second. Just compare to the other corners.
I took it to another branch of the same chain. They were re-balanced again. It still had the shakes. I took it to a third branch. Finally, the car didn't shake. The difference: the other two shops' balance machines were out of calibration. In the haste to make money in a short period of time, many shops don't take the time to check the balance machine itself. Before you give up, try another shop.
I can't be sure of the problem, but if the above components are OK, the re-warping of the brake rotors within a short period of time sounds suspicious.
Suggest that you check for a brake that's not quite releasing all the way. It may be applying sufficient force to heat up and warp the rotor but not so much that you notice the drag. After driving a few miles with very little braking, stop and check the temperature of each rotor with your finger to see if one or both are "much too hot" to touch. Be careful! If too hot, it could be due to a bad caliper cylinder or master cylinder.
See the Maintenance & Repair Topic #14 for more discussion on this problem.
A Mitsubishi factory representative has driven my car and says that even though the vibration is very slight, there should be none at all. He has authorized full warranty payment for a relatively new kind of wheel balance process called "Road Force Measurement".
Hunter makes a machine they call the GSP 9700 that actually measures wheel and tire runout and, most importantly, measures the assembly with a roller pressed against the tire simulating the same conditions the tire would be under if it were actually mounted on the car. Even though a tire and wheel assembly is in perfect balance, there may be variances in the sidewall or belt that only show up when the tire has a load on it. That explains why a certain percentage of tires continue to exhibit vibration despite repeated trips to the balancer. A very good description of the new machine can be found at http://www.hunter.com/pub/product/balancer/4159T/4159t.htm
It appears that this is far better than any other method of balancing. Visit the Hunter web site and read all about it and remember this solution if you have a balancing problem. Not many shops will have this machine, though, because it costs a lot (estimate $10,000). Mostly, you will only find them at car dealers.
I have an appointment for July 1st. I'll post the results.
The only fix for this is the normal, routine procedure of turning the rotors on a lathe to eliminate the run-out, or replacing them. Turning them is routine for a good brake job, but they can only remove so much metal before they must be replaced thereafter.
I doubt that this will enhance Hunter's friendship with some of the tire companies!
Please do let us know if this solves your problem.
So I called the GoodYear dealer and told them of the results and they have ordered me replacement tires for the..well..replacement tires. Hopefully these will be better. I will have to let GoodYear mount and balance them. If I still have a vibration, Mitsubishi said they will gladly rebalance them at no charge with the GSP 9700.
Once I get a set of tires that the GSP 9700 says are in balance if I still have a vibration, then we have to look at something other than tires and rims. But I think getting a good set of tires will fix it. The dealer mechanic did say they have had problems with the GoodYear Eagle GA tires causing vibration.
I'll report back once the new GoodYears are mounted.
Gee, I'm TIREd.
With a bubble balance, all the hi/lo spots cancel out, and you arrive at one location on the rim to place the weight. The only guess work is to split the weights in half for inside and outside edges, or put all of it on one side or the other.
The Hunter GPS 9700 machine should be no better for balancing tires than other dynamic spin balancers. Its advantage is in detecting out of round conditions that cause vibration, so tires can be singled out for replacement.
But I wonder about Bvolk's comment above. Tires have many process variables affecting consistency and quality. The question for me, is who makes the most uniform, consistently round tire. Steel belted radials were big improvement over bias ply tires, but still use hand laid plies, and vulcanizing is still inconsistent.
But the ads for Bridgestone Uni-T tires say the tire-bead-cable is one piece construction, eliminating the butt-splice. Should help in making a round tire. Anyone happy with these?
The reason a spin balancer may change settings is that many techs do not carefully and properly mount the tire on the balancer to begin with. If the tire was mounted properly and the balancer is in proper calibration, then it should provide repeatable results.
As to the GSP 7700, it does a better job than a regular balancer because it can pinpoint exactly where on the rim the weights are needed, including inside the dish of an alloy wheel. It can even indicate two different spots on the same side of the wheel. Most regular balancers are only accurate to .25 oz. The 7700 is accurate to .035 oz. And the pressure roller does more than find an out of round tire, it finds places where the sidewall may be stiffer or softer than other places. This helps because the tire can be perfectly round, but when it rolls on the ground it can still vibrate due to sidewall variance.
I have used Bridgestone Turanzas on two cars with no balance problems whatsoever. They wore very evenly. Nice tires. Don't know about the Uni-T's.
If it isn't the tires, then I will check runout of all hubs, rotors and the front half-shafts. Does anybody know what a reasonable spec would be for half-shaft runout? What about CV Joint runout?
Bvolk, your experience is very interesting. I'm sure we have all seen some tires which require little or no balancing but generally have not dared to forgo the balancing. What brand and type of tires have provided this good fortune?
On balancing, all these tire brands I have used seem to have no problems with regards to vibration, cupping, etc. After I tried no balancing I was sure that I would come back to the tire store with a humble, dumb customer look and tell the "tire man" how stupid I was - but it just has not happened. We know that if one particular tire company made a bad tire, the news would be out right now, eg. Firestone a while back. Tire companies cannot afford to make a non-competitive tire.
If you think about it, the way technolgy and engineering has advanced, tire technology and construction is much better than with bias ply and the early radial tires. I think balancing tires is fine, but just something always done does not make it necessary. Tire store people will scoff at you, however the cost of balancing has gone crazy for only a few minutes of work - again a nice profit for the tire store.
As a side note, the person in front of me buying tires was curious about my lack wisdom but wondered if he had been had when 3 of the 4 tires he had mounted has something like one oz or less added to his tires. A 15 inch tire revolves about 1345 times a mile or 1345 rev/min at 60 mph. Not much.
I am just relating my experience at tire buying and will stick with the no balance. If I have a variable speed vibration in the car or see other problems I will be first in line to get a balance. Why give a tire store 7-8 bucks a tire if not needed.
What kind of car is it Bvolk? Or vibrationless-wise, are your cars as generic as your tires?
Rpm wise at 60 mph, it's closer to 1000 rpm for a 15 inch rim.
I took the car back to the dealer and he balanced the replacement Goodyear tires on the Hunter. He found that they were not properly balanced and indexed when mounted by the tire dealer. This Hunter machine does a lot better job than regular balancing machines (see previous messages about the Hunter machine).
The vibration is gone!!
Before going to the dealer I did check all hub, rotor and drivetrain runout and found it to be excellent. Heck, the rotors had essentially zero runout. So all along it was the tires and not the car. That's good news.
I do have to say that both Mitsubishi and Goodyear were very cooperative. Mitsubishi in particular went to great lengths find a solution, including rebalancing the replacement Goodyears at their own expense, even though the problem was with the replacement tires and not the car.
As for indexing your tire on the rim, what was the reason for this? If the rim w/o tire was in balance, and had no radial run out, what difference would it make indexing the tire? I always thought the reason you did was to locate the heavy spot of the tire 180 degrees out of phase with the heavy spot on the rim.
I lost sight of one parameter, Vivona. There was much discussion of wheel and brake runouts but were you monitoring the radial runout of the tire, measured at the center of the tread? If so, what amount of runout did you have before and after this latest work? Re-indexing the tires on the wheels can sometimes have a modest effect in this regard even with a very small wheel radial runout. I'm focusing, of course, on the concept that perfectly balanced components will not operate smoothly if the tire periphery is not concentric with the center of rotation.
So indexing the tire would have been for offsetting the balance of the rim against the balance of the tire.
The GPS9700 had already identified the first replacement set of Goodyears as having excessive sidewall variance, so they were thrown out for that reason. I think the GPS9700 would discount the radial runout of the tire for the same reason.
So this raises some questions. Is the rim in perfect balance without the tire? With the apparent hyper-sensitivity to balance, how long will it stay balanced???
Some insight will be gained from learning the amount, the number, and location of the wheel weights that were applied.
Apart from the indexing, Vivona, and recognizing that the GPS9700 should detect structural differences in the tire, I would be curious to know if radial runout of your tires (not the wheels) was monitored and what was seen. (I just saw a magazine report that the maximum allowable radial runout of the tire should be 0.050" to 0.060"; this is tighter than the 0.078" that I was given several years ago.)
