timing belt replacement?
The squealing you hear is NOT the timing belt. It is either one of your other (non-timing) belts (V-Belts) or it is an idler pulley that has a bad bearing.
Bruce
A squalling power steering belt has a longer fuse but should be fixed.
Some of those service departments said they would not change the timing belt without replacing the water pump. Got one honest guy-said he never replaces the water pump unless it needs replacing.
Am at 105K now and will replace the belt when get to around 140K-maybe 150. Do not waste bandwidth telling me this is a mistake-all highway miles means the belt will probably be good to 200K and I know it is an interference engine.
Pat
Pat
It's only money, after all!
And, to not replace your water pump while you are in there is false economy in my book. It is exposed and takes nothing to replace since everything is already apart.
How long will that "good" pump last? Another 100,000 miles.? Pretty doubtful.
With my luck, if I didn't change it, it would start leaking the following month!
I guess I just don't see the advantage of trying to squeeze out a few extra miles. $500 every 60000 miles is CHEAP! Owning a car, insuring a car, and fueling a car is expensive. Maintaining one is not.
The two service managers who had the lowest prices also said they only replaced the water pumps when they had indications of problems and that this was a very rare event. Also it is very interesting to note the always replace the water pump guys had the highest prices for replacing the pump.
There are honest people in the car business-you just gotta search around to find them. Unfortunately most of them are in the business of relieving you of as much of your cash as possible.
An ounce of prevention is worth a pound of cure in my book.
Any feedback would be great!
Kristina/co host Our Turn
Roving Host
Now, does anyone know anything about CV boots....
By the way-road damage caused by all the crap you see on the highways can also tear your boots. Check them monthly.
What did it cost to replace the timing belt and water pump. Best price I have found from a Honda dealer was about $425.
The total bill was (drum roll please) 1186.65 of which $370 was the A-pipe. I knew going in that the a-pipe was an expensive part. Long story short the service department didn't break out the cost of each repair - just a total. However when I called before making the appointment - they quoted me a price of $470 for the timing belt and water pump job.
It was during this service that they mentioned my CV boots were going. Didn't have that fixed yet - need to get 4 new tires first!!
They also pointed out that both front CV boots would need replacement as they had rips in them, fairly recent rips. i can imagine I got these on a 5000 mile road trip over summer, during the course of which i did some slightly unsuitable off-roading!
The cost to replace the boots with non-split (ie original, full) boots is about $240 (both on front), and this includes a huge amount for labour to take the ball joints in the axles apart, with a slight risk of further damage in this process. on the other hand, replacing the axle joints (which come with a whole bunch of new CV boots, grease and other seals/boots) is approximately $300. I am considering getting this done instead.
Any advice? And how long can I wait before I do this - considering that I am getting the axle joints replaced. I was hoping I could wait a bit, as I also just had a pair of new tires put in and can't afford to spend so much on the car right now. Is there a risk of any other damage that could crop up as a result of not changing the CV boots right away? (any more than replacing the axle joint, which is what I plan to do!)
-ashu
By the way, before I take my car to anyone whom I do not know, I always very carefully inspect the cv joint boots for damage and very emphatically tell the service people I have done an inspection and I know nothing is wrong with the boots. More than a few service people manufacture problems to create income and tearing a boot with a pair of pliers is a quick way to make a buck.
Robert Smith
smithrob75@hotmail.com
Take it to a dealer or an independant who specializes in Hondas. Usually when the crank seal gos out, oil gets on the timing belt. In which case, the belt should be replaced.
They may have done this since everything was apart anyway. I think Alcan is correct.
Don't ignore it.
1- had all wheels balanced, problem still there
2- full alignment, still shaking at 65+
3- replaced all 4 struts (not cheap), didn't fix the problem
4 - another wheel alignment
finally.......
they replaced the right front strut mount ($30) and that did it.
so the I basically wasted about $600 for nothing. all these were suggested by the mechanic, as I will not step into dealer shop. every time, I've gone in, I came out with more problem than before. just don't trust those boys.
But I am experiencing some major paranoia about driving it in the meantime, knowing that it should have been replaced. With my luck I'll end up on the side of the road in some remote area with a busted belt and bent valves!
Why do I worry so much? Because I've been there! I had a 1989 Civic CRX and around about 78000 miles, the timing belt went POW! I was dead in the water with $2000 owed yet on the car -looking at a $2000 valve job. I junked it and started over. It was a major loss to me as I was dirt poor at the time.
Isellhondas, I think you may be off a little as to the year in which Honda changed the timimg belt replacement recommendation to 90,000 miles. My car was an '89 and the belt went at 75,000 miles. The manual said it should have been changed at 60.
At that time, I had no clue that a timing belt even needed to be replaced. I was very maintenance ignorant. Just check out this "dumb chick's" path of destruction in chronological order: 1972 Chevy Vega, siezed engine due to no oil (how could this NOT happen, since it burned a quart a day!); 1990 Bronco II - threw a tie rod due to improper maintenance (but the truck was a DOG anyway); 1983 Nissan Pickup seized up (I still miss that beater truck with the duct tape fenders); 1989 Honda CRX, timing belt disaster.
After that, I made a decision not to buy a used car ever again and to pay attention to the maintenance schedules. I can't say that I've followed them all to the letter, but my Civic has been a wonderful car so far.
In light of your bad experience, I can't understand why you would tempt fate again!!
It always puzzles me when people will spend big bucks for a car and then will skimp on them. It makes no sense to me at all.
You probably have nothing to fear. these belts usually go quite a ways past the 90K.
Still, why take a gamble?
And, when you go to trade it in, the first question you will probably be asked is " Did you replace your timing belt?"
And, guess what...the costs of replacing it will be deducted from the appraised value.
Good Luck!
fast accelaration.nurse it easy.you should be all right.
I have had my car to a dealer for trade-in on a Toyota Tacoma, and surprisingly, they didn't ask me a thing about the timing belt, although I was fully expecting them to. They did deduct money for "fair" tires (which happen to be less than 9 months old and have nearly new tread). I learned real fast that it doesn't matter how much you baby a car, when trade-in time comes, they'll low-ball you anyway.
It is amazing how long a well maintained Honda can last. change the oil often.
