I purchased a Ford radio removal tool at JK auto parts in VA. If they're around, you may be able to find them again. Otherwise, their not too expensive, and you may be able to find them through Crutchfield (www.crutchfield.com).
Good Luck.
I found the removal tool from a snap-on salesman. I was able to fix the radio and the other bulbs in the a/c and heating contols.
Thanks for the note.
Jim H.
Your daughter's issue is more likely related to the calibration. The vehicle was purchased in MI (low elevation) but is now being driven in CO (high elevation). The air is much thinner at higher altitudes.
The 4 cylinder/ATX combo doesn't help, either.
I changed the batteries in the remote...didn't change a thing.
Anyone else have these problems...
Anyway, he had new rotors put on it about a month ago. About a week after the rear rotors were put on, this loud CLUNK comes from the right rear suspension. We took it to Miekene and had it checked. The guy said the struts were fine, the brakes were fine, the exhaust pipe isn't loose.
This is driving both of us NUTS! So anyone have this problem thus far? I think the strut is bad, but the mechanic said they "balanced" the struts and with no problems. My friend doesn't drive that far, and doesn't really wanna take the car to the stealership for this problem.
Any advice? Thanks a bunch!
Took it to the local brake shop for inspection.
The rear pads AND ROTORS are shot. $356.56 to replace. OUCH!!!!!!!
The silly thing is, there are wear sensors built into the pads and should give you a dash light indicating brake problem. Never happened!!!!!
The moral of this story is: KEEP A CLOSE EYE ON BRAKE WEAR. The rears appear to wear pretty quick compared to the front.
Skip G.
At least my rotors were OK.
I am looking to get my 19 year old daughter a new (02 now that 03's are coming out to save a little money) car. I really want to get her a Mustang, but she likes the Cougars.
So, can any of you '02 owners (basic coupe with auto transmission) tell me about any problems you've had? And, if you had both a Cougar and Mustang (V6 auto), which would you go with and why? Thanks so much!
despite these three problems i love my cougar.
You might do well to take the car to a Mercury dealership and let them take a look at it. But it seems tranny problems are par for the course in these cars.
I have a 2001 C2 with the V6 and automatic and I average 25 in city driving and 34 to 35 on the highway. Oh I have 34,xxx miles on my C2.
I am also getting a sensor alert for the exhust i believe it is the cataletic converter, any suggestion on where to go for the best deal. thanks
My first post... Great and informative forum! Keep up all the great work!
I just purchased a 1999 Cougar V6 for my 16 year old daughter. New driver... first car. After reading many scary reviews in Edmunds on this car is this car really that bad and unreliable? Any feedback either way would me most welcomed.
I pray I didn't put my daughter in a clunker for her first car! She is sooooo excited.
Thanks!!
The Cougar is not exactly a clunker, it just breaks a lot and then it's expensive to fix. For example, my shifter linkage part was $30 but it cost $700 to put it in because they had to pull the transmission to get to it. The light bulb on my clock went out and I was told that it would cost $500 to replace because they would have to disassemble the dash...
It drives beautifully when it's running. Great handling and brakes.
Oh, the rear visibility is awful. Enormous blind spots. That would concern me for new driver's car.
Although many of the extended warranties leave alot to be desired! Thanks again for your input.
We were hoping for any solution less costly, even an aftermarket 'pop-up' to fill the hole. Granted the factory hatch panel is in perfect shape, the expense is the nagging factor...
Any help would be greatly appreciated,
Mark Wootton :sick:
All sorts of things broke on mine which is why I got rid of it.
Is this about average?
The Cougar could have been a "perfect" (or at least really good) car but Ford did not choose to correct its problems or promote its strengths.
-Left Knob is Temperature; works fine, hot to cold.
-Right Knob is Fan Speed; works fine, low to max.
-The Middle Knob; the only positions that work are Off and Defrost. Everyother position on the knob defaults to 'defrost' and nothing comes out anywhere else. If I take it to off, it stops, which makes me believe it isn't the switch.
This happened one day when I started the car up and attempted to put the AC on. Does anyone have any advice where to start? (Please don't say take it to the dealer)
Thanks for the advice, John
I have a 99' cougar that I bought about 1 1/2 years ago. Has about 145,000 miles on it (WOW!) but runs good. Any ways I got the A/c rechared and worked great. month later i moved to Florida and the A/c decided to not work on and off half way down. Than it would work on the right two vents and not the left two...than it stopped working all together. Hoping it was just a small leak i took it into tuffy's, they said it was the clutch and they could manually go in and push on it and make it work. They said it would be cheaper to get a whole new compressor b/c cost as much as a clutch plus the compressor would go soon any ways (they say). Just woundering if this is true. Also, if it would be semi-easy to install myself. I know i can buy one for about 150$ verses the 700 they quoted me. (im a college student that just moved here with no money!!! so need some good advice or ill just fry this summer!)
I have had the 99 4-cyl automatic for over a year now. The only things I had wrong were old belts and a couple alternaters (90,000/115 ish, and now i think the air compressor. My car has 145,000 miles on it. I dont know what kinda work had been done on it before, but its a nice, stylish car.
