Funny Noises Department
I have a new '00 Nissan Xterra (rear wheel drive)
4x4, automatic tranny. The truck/suv has about
1200 miles on it so far.
Lately, I've noticed a fairly loud "whine" coming
from the right side of the engine compartment when
my foot is depressed on the gas. Its most
noticeable at hiway speeds, and the noise
disappears abruptly when I take my foot off the
gas.
Is this normal? I'm used to driving a fwd saturn,
so I can understand that a "truck" might have
different sounds. Could this be one of those "fuel
pump" noises, since it only occurs when the
accelerator is depressed?
Just wondering, and thanks for any insight you can
give!
gas.
give!
Might as well answer my own question, in case anyone happens upon this topic in the next 50 years or so. . .
The whine or whirr noise is cause by the ring and pinion gears in the final drive assembly of the differential. I found this out via other boards on the 'net.
The big surprise? The Nissan tech could not have been more understanding. I went in expecting:
"Yeah, so what, they all do that. . ." or
"That's just normal gear noise". . . or
"What do you expect, this isn't a mercedes!"
Instead, I got a tech who took a ride with me and immediately noticed the noise and then HE suggested we take out a new Xterra to see if it made the same noise (it didn't of course).
Then, he promised to call me that same day after checking with "california" which he actually did! (I was bowled over by this time).
So, bottom line is that a new differential is on order from Nissan, Japan and I'm crossing my fingers that this will be the worst problem ever until I hit 200,000 miles.
2) unfortunately, it's something inside your dash, and to get to it, you may have to take the entire thing apart, and still might not find where the offending piece is. rattles suck.
-Chris
possibly power steering pump, or worn belt that's powering it.... but that's a guess... mystery noises without knowing location are kinda tough to debug...
good luck.
-Chris
The problem with (soft) rubber bushings is that they aren't really very slippery, like a good bushing should be. So they wear out faster and make noise once they dry out. Tires (made from rubber) chirp when they are dragged across the road surface, and rubber bushings do the same when the suspension parts rub against them...
The reason your mechanic said they are not worth replacing is that they are not worn enough to prevent them from doing their job. They are just complaining about it, as they don't have enough built-in lubrication to make them happy.
Be leery of anyone wanting to lube them, as they will not react favorably to the wrong type of lubricant. They will then swell, and decompose very quickly and then you WILL have to have them replaced.
Of course, YMMV. Bruce
a long time the front end( I think suspension) makes noise whenever the car has been driven for a long period of time like highway driving. Not heard on highway but heard when on the local streets. Only description sounds like a New York Taxi. If it has not been driven far there is no noise. Complained to dealer several times and twice told me he lubed the steering arm stops but of course this did nothing. Otherwise car rides very well. Any ideas?
Did the rain do something? Does that mean that my bushings are made from rubber and now have soaked up water. Does this mean that they can be lubed somehow?
And by the way, Bruce, I do not know what the initials "YMMV" mean at the end of the post. Thanks, retts
But can anyone figure out Bruce's emoticons in some of his other posts?
Pat
Pat
has developed a clunking noise some where inside it, seems to be coming from an area near the drivers left ear. The dealer has tried 4 times
to repair it with out any luck. They replaced
the seat belt adjuster, and the last time they repositioned a electrical piece. I still have
the noise they tell me I need to wait until it gets worst so they can pin point where it is coming from. Has anyone else had this problem
and if so what was done to fix it?
After engine warmup and at about 1000 rpm and
under light acceleration I have a shrill whistling
noise coming from the engine, firewall area or
dash, can't really tell. It goes away after about
1700 rpm. On slowing down it comes back when almost
stopped and while idling you can press the
accelerator just barely and it whistles.The fuel
press. regulator and IAC valve have been replaced
with no luck. Of course the shop can't duplicate
the problem. Other than that I love the car. Plenty
of pep and good gas milage.The noise is there with
the A/C on and off so not that. Anyone else had a
similar problem??
Taurus' repair and maintenance (Topic #153)
to see if this has been discussed there.
You could also use the Topic Search feature on the left side of the page for Taurus to find any other Taurus topics of interest to you in Town Hall.
Good luck, and welcome!
Pat
Love the car but an annoying low rubbing noise seeming to come from the left front of the vehicle is really getting on my nerves... I have been to one VW dealership and they had told me that the VR6 with the auto tranny has been known to have some drivetrain noise... Does this sound like bs and/or should I settle with that response?
The Honda Factory Rep also said that the noise was coming from the differential and tha t it was normal.
I have asked several other Honda owners if the have this problem and ,so far, nobody has heard of this problem .
Three local mechanics have told me that it sounds like a bearing noise and that this is not a normal sound.
Honda Civic Problems (Topic #912)
and repost your question there.
Town Hall is fortunate to have an experienced Honda technician, auburn63, hanging out there who may have some suggestions for you.
Pat
I described what happens and he states that it's the struts and that they make noise when it gets cold. I recently hit a bad pothole that broke some of the plastic rivets holding the wheelwells on. I fixed these myself and can't find anything else loose on the front end. I also had an alignment/visual inspection done...nothing is bent or broken.
Does anyone else out there have Daewoo Lanos and is experiencing this in colder weather?
I'm thinking it's maybe a bad strut, but the possibility of it being something more costly (eg. transaxle or transmission) is upsetting. It's intermittent (the worst kind), and doesn't necessarily happen whenever you hit a bump. When I had it in for an oil change at the dealer (~6000 miles) I asked them to look for it. They "didn't find anything". Could you let me know your findings? Thanks.
