Obviously baby the tranny. We flushed and replaced my son's and it now works great. We also added Lubegard.
Obviously baby the tranny. We flushed and replaced my son's fluid, and it now works great. We also added Lubegard.
1998 Mazda 626 LX 62,500 miles (bought new)
Issue #1 Check engine light has been on for about 1,500 miles (It has been on before and goes out after a week or so).
#2 Radio/CD stoped working LCD display on radio is out. When the headlights are on the buttons light up.
#3 Dome light is out. When I manually move the switch to the on position the door open light on the dash goes on it goes off after about 30 seconds.
#4 The trip odometer resets to 0
#5 When the car is turned on the the defroster button is on.
#6 When I turn on the car it cranks way too long when it starts it has a rough idle for about 45 seconds.
#7 The power door lock switch only works when the car is on or the key is in the assecory position.
#8 The remote for the alarm and the trunk release no longer works.
#9 Since this happen the check engine light has gone out.
All these things happened at once. then radio stopped working and then I notice all the other problems.
Could it be something is not grounded?
If someone can give me a general idea I would greatly appricate it. I shudder to think what the Mazda dealer will tell me.
Thanks for any and all help
Mark
Additional ideas are very appreciated.
My factory warranty for 626 (2000) is about to expire and, naturally, I was wondering if it's worth to buy an extended one (like Warrantybynet or Warrantygold).
Anybody has an experience with those or similar services?
Annually I do approx. 22k highway miles and I have auto 4 cyl in my car (that I love a lot).
I'll appreciate any feedback !
Thanks for the heads-up on the Mass Airflow Sensor. Do you have any idea how to clean this beast? My previous car, a crappy '96 Jetta, had to have it replaced at a cost of $400. I don't want to go throught THAT again!
Could the Mass Airflow Sensor be causing problems or confusion with the sensor at the catalytic converter?
By the way, I had the tranny fluid changed when the transmission shop replaced the main seal. It was leaking a bit. Cost me $300 to get it fixed with a $5.00 part. All labor! However, I feel much better about the thing now that I don't have to keep track of the fluid all the time.
http://www.geocities.com/adamk01452/MAF2.html
http://www.edmunds.com/advice/buying/articles/45498/article.html
For me it would be a no brainer. Mazda all the way, especially when it was only 500 bucks difference.
The mechanic said that my battery was basically dead due to a weak alternator. He said I needed to get that fixed but I should be able to drive on a new battery for at least a week. I got the car started with the new battery but hadn't gotten more than a quarter mile before the engine died again. I got it started but it died again about a minute later.
Is this mechanic right or is there something worse going on here? I'm scared to death of taking the car back on the highway.
There's a distributor issue on '93s. More precisely, there's an issue with the ignition module, which is integrated with the distributor in these cars. http://www.bradbury.cwc.net/probemx/p_p4.htm has the gory details.
* I found them dead at the same time
* all other lights are working
* is it easy to change the bulbs by myself if it's because of dead bulbs.
thanks for any help.
thanks.
I think windowphobe6 probably nailed it. That's a pretty expensive fix but my car still isn't costing me a monthly car payment, yet.
For the past week when putting into gear the engine would rev way past 5,000 RPM in the past 2 days it quickly got worse to the point were it is now.
#1. Is 63,000 miles about the time to replace the clutch anyways?
#2. How much $$$ should is expect to part with for this.
#3. Anyone elese with a manual transmission experice the same problems if so how at how many miles?
Thank you for any and all help
Mark
The major expense is not the clutch itself, but the five or six hours it takes to install it.
I just replaced mine at 10 years ('91 GT) and 117,000 miles. They were making noise over speed bumps and I found the rubber spring seats were cracking and squishing out of place. I bought KYB GR-2s from BAP and so far they feel like OE.
Dave
This doesn't sound too normal to me. Around 45 mph, you're at the point where the torque converter is locking/unlocking, which isn't the most seamless of operations but doesn't really feel like either a surge or a miss. (The A/C makes its presence known, but, at least on my car, it's barely noticeable.) And anyway, if the fuel trim were enough out of whack to push the oxygen sensor out of range, you'd get a code of some sort. Maybe I'm just, um, insensitive, but I'm not buying this.
The gas pedal on these things seems a bit hyperactive to me; if you're going over a teensy rise, the subsequent descent may jar your foot ever so slightly, and the transmission will duly interpret this as a request, whether you wanted it to or not. If your roads are as crummy as ours, maybe this is what's happening to you, in which case you probably should move.
My Mazda mechanic has done this to Mazda transmissions for 20 years. He believes that it avoids most automatic transmission problems.
If it still has the problem you have protected your transmission anyway. Change fluid and readd lubegard every 15,000 miles.
Could it be the transmission? Maybe. Even with recent upgrades, this is still not one of the sturdiest of slushboxes. And stretching out its lifespan has to be considered a Good Thing, even if it's not the immediate problem.
Like if I had a burned out bulb, but I don't.
Also even without turning on the blinker, the indicator on the dash lightens up when pressing the pedal. And this is for the right one only.
So it's an electrical issue and might be something like shortening a circuit or grounding or ... but any more concrete ideas ?
Yesterday it drove fine. Today it won't start, even with jumper cables. When the ignition is turned on, there is no sound. The only thing that works are the headlights--no radio, no interior lights, etc.
I did leave the key in the ignition last night, and I may have left it turned partially on (to close the windows).
Any diagnosis or thoughts? We are perplexed by not being able to jump start it at all.
Auto Wreckers often have special booster cables that are much stronger than an ordinary car jump. If it does start with this, then you will need to use a battery charger to charge a long term charge. Alternators don't fully recharge.
