Saturn Maintenance & Repair
The battery has been replaced with a new battery with an indicator light to eliminate the easy solution.
Have any of you experienced similar problems?
Did your car fail to start for the tech? My problem is intermittent and my not occur in the shop
BUT after the repairs were done i havent had trouble starting my car. its worked every time since. it seems the only problem i have now is that the security light comes on and then the service engine soon light... but ive had that happen from the begging, but i dont believe that has to do with the repairs that were made...
now if your going to do the repair i would double check with someone before hand, just to make sure that we are talking about the same things.
i really lucked out on the cost, it was a $700 + repair and i payed $7, we argued it out, i only had the car for like a month so i thought it bs that i had to pay that much.
I would like to have a repair completed for $7.
Besides the initial cost of a repair, I am mainly concerned that since the problem may not occur in the shop I will end up with a number of parts being replaced that are not required. It could easily cost 4 figures and require multiple visits.
My car was purchased new in the summer of 2004 so I don't think I will qualify for the $7 special. What was the best point you made to win the argument with the service manager.
i'm thinking it is your steering wheel mounted switch that may be broken / not working.
here my problem in detail. my girlfriend owns the car. she has complained to me that on occasion (5 times in the last month) she needs to get jump started at work when she is going home. *** note I bought her a new battery about 2 months ago.***
Everytime when she gets home I check the car and everything seems fine??? but this morning We woke up and her car was dead. I tryed to jump it but the battery would not hold a charge.
So I tried to charge the battery. I've got a fancy battery charger that had a diagnostic code that said the battrey was bad. no prob, I have seen this before. So I went to NAPA and bought a new battery.
Here the current prob. I hooked up the new battery. went to crank the car over and the was a click and everything went out. no power, no accessory, no headlights, nothing.. (however the time was on the stock stereo!). I took the neg off the battery to see if it would reset anything and reconnected it nothing, same problem totally dead.
I check all the 30 & 50 amp fuses all look good. it is my suspesion possible a relay is bad???? when I reconnect the battery I hear no clicking from any relays.
Any suggestions are very appreciated.
johnb
I connected a brand new battery and waited 15 min
I turned the key and nothing, no power to anything,no accessory, no dash lights, no lights nothing. in the dark when I turn the key. I do see a very faint light for the heater come on of a half of second then gets dim(this is so faint I cannot see in the day). the stereo clock LCD is on????
I pulled ever single fuse and check and reseated them. all is good. I pulled and reseated all the relays.
Can someone tell me what could cause a no power problem like this??? bad ignition switch???
thanks,
john b
Is it possible to remove and replace the bulbs, or is this deliberately designed to be a "Saturn-service only" procedure?
Many thanks for your advice.
30 Minute Learn Procedure
1. Turn ON the ignition, with the engine OFF.
2. Attempt to start the engine, then release the key to ON, vehicle will not start.
3. Observe the SECURITY telltale light, after approximately 10 minutes the telltale light will turn OFF.
4. Turn OFF the ignition, and wait 5 seconds.
Repeat steps 1 through 4 two more times for a total of 3 cycles/30 minutes, the vehicle is now ready to relearn the Passlock Sensor Data Code and/or passwords on the next ignition switch transition from OFF to CRANK.
Important
The vehicle learns the Passlock Sensor Data Code and/or password on the next ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle.
Start the engine. The vehicle has now learned the Passlock Sensor Data Code and/or password.
It started after my car was recovered from being stolen.
My car idles fine when at a stand still. When i drive and push in the clutch the rpms stay above idle rpm which is about 7 or 8. If i push in the clutch or put it in nuetral while moving my rpms drop slowly to about 11 or 12 and dont go to 7 or 8 until i come to a complete stop. My car also makes a whining noise in low gears while accelerating. I was told this could me my alternator diodes going out. PLEASE HELP!!
We have an attorney working with us. Call 1-800-my-lemon these people are great and will get you results. Look on the recall bulletin board for Saturns also some of these issues may be there.
I have a manual 1995 Saturn SC1 with 124000 miles on it. It has been running like champ. This morning I went to go to work and of course, it doesn't start. The interior lights and dash lights come on, the door chime sounds and the "click" happens when you turn the key. The car even ATTEMPTS to start, but its very, very weak the first time; almost no attempt the second try, and nothing but the "click" the third time. It was ZERO degrees out last night here and the car is not garaged, with wind chill its about -15 or so. Does this sound like it could be a cold weather problem or something more? AND if it is a cold weather problem, would a core heater help with this issue? Thanks so much!
Definitely anything you can do to keep the engine warm (or even just keeping the battery warm by bringing it inside) would be helpful.
i suppose i'd run it over to a autozone or other similar and have them load the battery and alternator.
also - this person should be going for some good long drives with the cold weather to make sure alternator has time to re-charge the battery.
I have complained to the dealership, to NHTSA and to my local news channel. I am having the same experience that everyone else is. The dealership insists that I bring the car in for diagnosis so they can charge me $100 for the repair. I don'te think I should have to pay anything for this malfunction and I am trying really hard to be patient while others investigate this situation. In the meantime is there anyone else I can complain to where I know I will get results. I really don't want to have to pay for Saturns mistakes. and if we all wanted to get together and start a class action lawsuit how can we get the ball rolling on that?
The first is that my keyless entry has stopped working. It will lock all the doors but only unlocks the driver door. I've changed the battery but that didn't work. Anyone know how I fix this?
The second issue is that my car stalls all the time, usually when it's cold. I literally have to drive around with one foot on the gas and one on the brake to keep it from stalling every time I stop. Autozone ran a diagnostic check and it said there was something wrong with my idel control but they couldn't tell me what that meant. Any advice here?
2). hmmm, yeah an idle air control valve (IACV), something that provides a bypass around the throttle valve, when the throttle is all the way closed. maybe your's can be cleaned. maybe there's a broken hose.
another possibility, when you changed the battery, you messed up the idle. maybe your vehicle, like other vehicles has an idle "learn" procedure after replacing the battery.
more googling.
I'll google the idle control and see what I get.
We purchased ours new from Saturn of Fairfax in June 2001, after the change had been made, but ours had been manufactured in November 2000, part of the increased failure period.
The above notwithstanding, Saturn has offered an insulting 15% off of a warranty price on a new engine - admitting responsibility but not wanting to pay the cost or even willing to make it reasonable for the customer - who in their right mind would sink $3k into a vehicle whose trade-in value is less than $5k?
Futher details on http://dontbuysaturn.blogspot.com/ - we were die-hard Saturn loyalists, having bought four Saturns (a 2000 SL2, 2001 L200 and two VUEs, 2003 and 2004) within a 5 year period between 1999 and 2004. The treatment during the process has been about as bad as the "final" word from the last-name-less area manager at Saturn. A four-page letter, along with 9 pages of email-thread with Saturn, and 12 pages of NHTSA printouts was fedexed to the head of Saturn Corporation, General Manager Jill Lajdziak, on May 23, 2007, and copies were sent by certified mail to G. Richard Wagoner, Jr., Chairman & CEO of General Motors Corp; Troy A. Clarke, President, GM North America; Mark R. LaNeve, Vice President, GM North America, Sales Service and Marketing; and Tom Tellepson, General Manager of Saturn of Manassas. These copies were sent on Friday, May 25, 2007. No response has been received from Saturn, and none of the reply cards have yet been received from GM or the local dealer.
The gloves have come off, and I am telling this story far and wide. Saturn has done a lot these past 7 weeks to keep us from ever purchasing a Saturn or GM product again. They seem not to care about losing my business, or that of anyone who hears this story.
I know you'd like to have a new engine (heck, who wouldn't), but just what is their responsibility in this? What is the published warranty on this product, 3 years and 36K miles?........which would put your vehicle at twice both the years and miles?
What would the cost be to pull the engine out of a wrecked car, and put it in yours (an engine from outside of that higher defect timeframe)?
I think your options are to:
- Continue to try to rattle the cages, which will probably have minimal chance of success. My opinion is that you are so far out of the warranty period that any reasonable third party person would come down on the side of the dealer as being fair.
- Swap out the engine with a previously totaled vehicle, guessing it would cost ?? 1K ??, then either continue to drive it or sell it at around it's value of 2.8-3.5K.
- Accept their offer of 15% coverage, spend 3K for a new engine, and then drive it till the wheels fall off (since you'll have a new engine good for another 80K miles).
- Unload it as is, take about a 3K loss.
I think I'd be looking for a replacement used engine.
I personally had a similar situation. Transmission went out on 11 year old 85K GM Suburban (our road trip vehicle). Turns out that they made a model year change to a transmission part, and didn't spec it as being made out of hardened steel any longer. These things are failing right and left, obviously a manufacturing weakness. Vehicle is worthless in broken condition, and way outside of warranty even though it's a previously recognized problem. This is a significant repair I ended up eating.
I'm sure you don't want to hear this, but I'd suggest channelling energies to finding a more reasonably cost solution than a full new engine replacement. You got dealt a bad hand of cards, make the best of it and get on with life. You'll look back at this in 5 years, and it will be a blip on your radar screen.
In its ODI filings, Saturn claimed the failures never happened during operation. Wrong. The failure due to a manufacturing defect could have resulted in serious injury, and I am not alone. Saturn used to value the "100,000 mile club" - a wall of poloroid photos at each dealer of Saturn owners and their cars that made the 100k mark. They used to value the customer - now they'd rather throw them under the bus. A timing chain should have lasted more than 200,000 miles, not fail at 84,700.
So is the care package a legal warranty specifically covering parts and labor, or a service package covering normal maintenance and serviceable items....in your terminology "acting as" an extended warranty? If the original 36K package was was purchased by you (as opposed to a warranty which is included in the sale of the vehicle), it sounds more like the service packages that dealers have which cover oil changes, brake pads, etc. Does it use the words warranty?
Been thinking about your situation some more. What exactly is it that you are asking for from Saturn? What is it in your eyes, is a fair resolution to your situation?
Is Saturns' logic on their offer of 15%, that you drove 85K miles of the 100K miles that gets your picture on the dealership wall....therefore you were short 15K miles or 15%?
Now I don't know what the actual statistics would prove (as opposed to marketing/sales hype) as to the average mileage of Saturns before they are retired....but I'm betting that most people would think by the time an average GM vehicle is at 100K it's taking it's last breaths. There's always the stories about someone making 250K, but I'm talking about the actual average mileage @ retirement.
