In any case, I rather make two or trhee trips to AutoZone than pay $100 bucks to learn that my car was misfiring (which was obvious) and to clear the codes...
G.
http://www.obdii.com/codes.asp
IE.
Vehicle Manufacturer: Mazda
DTC: P0421
Reading: Warm Up Catalyst Efficiency Below Threshold (Bank 1)
Not sure how helpful that really is, but it's something.
It still feels the same even after using the handbrake. It is slightly tough to move from P to R and vice-versa. This happens only half the time.
Is this a problem or do other cars also feel the same ?
Can the dealer help/solve it since I still have the bump to bump Warranty ?
Of course!
If there is a problem with the car, by all means have the dealer look at it. Try to get a service adviser or service manager to take a drive with you and see the issue in action. Otherwise, you might get your car back one day later with "Cannot Duplicate Problem" written on the repair order.
As a number of you have mentioned, the CEL turned itself off after ~20 or 30 start cycles. I still think there is a DTC stored inside the ECU, but at least I don't have to see the stupid light reminding me to fix something I already fixed.
While trying to get the codes read, I came across this, which may be of use in future CEL episodes (at nearly 60K miles, they will be more likely...). It's a nice/simple/cheap OBD-II to RS-232 interface:
http://www.scantool.net
You can buy it assembled, or buy parts and build it (what I'm going to do as my weekend project). Hope this is helpful,
G.
Quick question. My dealer want's an obcene ammount of money for a distributor cap and rotor for my 96 protege. I checked with Trussville Mazda in AL, usually very cheap source of Mazda parts, and they don't have them in stock and don't know when they may get them.
What aftermarket brand would you use instead of the Mazda OEM part? Would you even use a non-Mazda distributor cap/rotor? I saw a Beck-Arnely one that looks pretty sturdy for aprox. $25 (cap) and $15 (rotor button). Borg-Warner's were more expensive (comparable to the dealer's...).
G.
The wires go through the top of the head and down into the block. After a while they start to break down (from heat and moisture) and start to short from the wires to the metal tunnels surrounding them inside the cylinder head. And just like the guy said, there's no warning. I'd just driven to my girlfriend's house to pick her up, and it started when I got back out to the car and restarted it. I sputtered to the dealer thinking I was in big trouble, but he installed a set of wires right there in the drive-up bay and I was on my way for about 60 bucks.
I recommend replacing the wires along with the plugs every 30,000 miles. Don't have my manual right in front of me right now, but I thought the manual recommended this interval too.
Meade
Also, thanks for the info on ignition parts. I think I'll go with Beck-Arnley, as a friend of mine can get them cheap from a part store here in town.
G.
Our 1999 Protege ES 5-speed (last year for 1.8 liter DOHC engine) is doing very well at 78,000 miles! Outside of regular maintenance, the only issue we have had (besides a freaky broken water pump fin at 5,000 miles-replaced under warranty) was having to replace the alternator at 68,000 miles. Even better is the fact that we did not have to replace the ORIGINAL front brake pads until 72,000 miles! And the original rear brake pads are still in fairly decent condition.
My only depressing thought, after reading some of the previous posts about timing belt replacement, is that we had the timing belt replaced at 75,000 miles, as the Mazada dealer told us he had seen several Proteges come into his shop with broken timing belts (and destroyed engines, of course) at only 65,000 miles. Now I feel he was simply trying to make a service sale and it has me very mad! The timing belt replacement cost around $400, which was money we did not really have.
So, for anyone living in the Nashville, TN area, I would avoid the service department at the Mazda dealership in Franklin, TN, as I feel they cannot be trusted.
We plan to keep this Protege (I had a previous 1992 model that was flawless) for quite some time!
Very interesting post. My 2000 ES has 53,500 miles on it, and it too is still on its original brakes! You just made my day; maybe there IS hope that the brakes will pass state inspection next month after all. I've been meaning to pull off a wheel and check them, but frankly I've been scared to look!
I usually try to arrange having my timing belt replaced at the same time I do a major service where I plan to replace all of the belts. It's the labor that makes it so darned expensive. I remember one year, while in college, I told my dad I wanted a timing belt (for my Hyundai, by the way) for Christmas. He didn't understand and actually went out and BOUGHT the belt and wrapped it! Upon opening I said to myself, "gee, thanks a lot for the $45 belt" and then went off to find the 250 extra bucks I needed to pay for the labor. Thanks Dad ... ;-)
I also owned a 1992 LX (two of them, actually) and it was running like the proverbial top at 83,000 miles when I (stupidly) got rid of it. I'm hoping my 2000 does at least as well as yours. BTW, how much did the alternator replacement set you back?
Cheers,
Meade
sound like??.....THEY DID SCREW HIM.....
Funny - That is where Mazda American Finance is located, or least where I send my payments.
Nice -- my Protege's financed at a local bank. I make drive-thru payments (or sometimes while grocery shopping since they're teamed up with the city's most popular supermarket chain) and save a stamp, and my payment never gets delayed by snail mail! Heck, I even got a free interest checking account and free checks when I got the loan!
(I could opt for direct withdrawal from my account, making the whole payment thing totally transparent, but I don't like people's electronic hands in my electronic pockets. Besides, I enjoy the "countdown to zero" feeling I get each time I tear off one of those payment coupons. Only 26 to go ...)
Meade
Well now I have $500 invested and still the noise. I returned to the dealer today who says I'll have to leave the car as "it will take time to isolate the noise". Has anyone experienced this problem? Any suggestions?
DTC'S P1633, P1631, P0173 UNSTABLE IDLE/STALLING
Applicable Models
Model
Starting S/N
Ending S/N
1999 PROTEGE
00000000
ZZZZZZZZ
2000 PROTEGE
00000000
ZZZZZZZZ
0003500 Dealer Repair Information
Customer may experience one or more of the following:
* Charge light on
* DTC P0173 (caused by excessive noise in O2 sensor circuit)
* DTC P1631
* DTC P1633
* Unstable Idle (Surging) under electical loads (cooling fans, rear
defroster, headlamps,ect.)
* Stalling coming to a stop or at a stop, due to the unstable idle.
Condition may be caused by excessive voltage spikes and/or noise
produced within the alternators that had an incorrectly soldered
condencer and were installed in vehicles produced in March,
April and May of 1999.
If you incounter a vehicle with this concern replace the alternator
and verify repair.
Copyright © Mazda North American Operations
If the pump is weak or low on fluid, or the belt is slipping, yu can get noise at full lock, although this does not sound like bad bearings or a bad CV joint.
I have a 01 Pro LX 2 litre auto trans with 21,600 miles.
I recently noticed that after I start the car and just drive about half a mile, the indicator for engine temperature goes up to the 9 O clock position immediately. Is this normal ?
I think this used to be near the bottom (6 or 7 O clock) most of the time.
Please let me know.
Dinu
Please let me know.
9 means engine temp is normal.
Yes, I remember you. Life has been a whirlwind of job changes and family events and I've had little time to visit Edmunds. The current job is so demanding I am about to lose my mind!
About the alternator, I had it replaced by a non-Mazda garage. The alternator cost about $210, with about $75 labor.
I also wish I had never traded my 1992 Protege! It was problem-free for the approximately 60,000 miles I owned it. Bought it for $1500 under invoice, too. The seat fabric was the best non-leather fabric I have ever seen - durable as heck! Oh well, we live and we learn.
Good luck to you!
And, protege_fan, I am pretty certain that my 1.8 liter DOHC is an interference type engine. Maybe the newer 2.0 liter version is a non-interference type (like the old 1998-2000 Ford Escort 2.0 liter engine). I could be wrong. . .
So No. You do not have an interference engine.
The 1.8L and 2.0L in 99-03 Proteges are essentially the same engine with different stroke lenghts, both are non-interference. The Escort 2.0L engine is not the same engine as the Protege 2.0L.
Also, while accelerating I occasionally feel like something is holding the car back? Like someone is pushing against the front as I accelerate?
Does anyone have any thoughts? I was wondering about the differential? I have had the car in the shop twice over the past 3 years for them to check out a "clunk" sound I get on the 1-2, and 2-3 after the car is warm. Both times I have been told it is a normal sound. I have service tickets from both appointments. The car is under warranty until 7-20-03.
Mark.
Meade
(My 2000 ES 5-speed is at 54,000 miles and doing just fine!)
Meade
http://www.gates.com/downloads/download2_common.cfm?file=GatesTBR- - .pdf&folder=brochure&CFID=214427&CFTOKEN=22025634
However, I also noted the same feeling of resistance when accelerating and lower mpg's due to spark plug wires. How many miles do you have on your current set of plug wires?
G.
that might help u rule out the brakes angle.
or is the brake fluid tube getting pinched when u turn full? that may cause it to push the calipers?
Well, that is good news. I don't guess we'll worry about replacing the next timing belt until the new one breaks (which may not occur for quite some time).
Bummer on my Elantra GT, though! Interfence engine and 60,000 mile service! Arrgh!
We have a VW Passat now, and I just read on another site of a guy whose timing belt prematurely failed. Lucky for him, his warranty covered the $3,500 to $4,000 cost.
Mark.
If I release the brakes very slowly while starting to move OR if I apply the brakes very softly while bringing the car to a gradual halt, the brakes make a slight clunk sound or groaning sound. This always happens on an inclined plane.
I have also unconsciously mastered this and I can make it groan or not if I choose to.
I am worried about this sound. What is causing it and how can I solve it ?
Will the Mazda dealer solve this free of cost since it is still under the bump to bump warranty ?
Kindly advise.
-Ramprasad S.
nothing to worry about.
Thanks for the info about engine heat also.
Normal ? I am surprised; but also glad.
I have driven other cars like Corolla, Camry, Civic - each for about a month while we rented them or friends' cars. They don't make this noise.
