same fix?
thanks rotary.
thanks.
leftover. What's this about Ford transmissions and high rates of failure? The dealer assures me there are no Ford parts in the Mazda. (I hate Fords - had a 92 Taurus and it was worthless and wouldn't run anymore at 99,000 miles). Also, leaking gaskets? I don't know folks. I'm having
serious second thoughts and may pay the extra 2k
for the 04 Corrolla.
Check the main sedans board. No problems in 67K kms on mine.
Dinu
Would this be covered under the Mazda Ext warranty(TotalCare)?
When I got off the highway today, I was waiting to turn and the Protege was idling extremely rough. When I got home, whenever the car is idling, the engine is shaking excessively, enough to feel a back and fourth shaking in the car. Do you know what this may be? Have you heard anything about 2000 Protege's and this problem?
This discussion's title will soon change to "Mazda Protege Owners: Problems & Solutions" and it will reside in the Mazda Protege Owners Club. However, it will also still be here in M&R. If you are subscribed to this topic now, the change should not affect that.
If you have any questions/concerns, please address them to me in email, karen@edmunds.com.
We drove an '87 626 170,000kms on the original plugs and wires so hopefully the Protege can live up that record!!
You shouldn't do that. Preventive maintenance (aka: obsessing over your car) is worth it IMO if you want to keep your car in good shape.
Dinu
Now I know I'm going to take some heat for this, but I think the pre-1990s Mazdas were a lot better than the current ones in terms of overall reliability. We had an '82 and a '87 626 that ran flawlessly for well over 10 years each (the '87 was even "abused" by lack of proper maintenance.) Our two 2000 Proteges have not held up as well in the first three years of ownership, Mazda has been good about changing defective parts, but we still have non-wear and tear related failures that end up being out of pocket expenses (i.e. throttle sensor, oxygen sensor, rusting steel wheels) These were not problems with the earlier models, I realise that the cars have advanced technologically over the years, but this should not overshadow overall reliability.
Although these problems bother me, I would still buy another Mazda. It just changes my perception that these cars can go "the long haul" like their predecessors did.
I'm looking forward to my Mazda3 ES.
I think today's cars need to be more babied than the ones from the late 80s partially b/c of all electronics (sensors, power acessories, etc) and the reliance on the ECU to make decisions about how the car runs...
And yes, I can't wait to get my Mazda3 GS. The GT will be the replacement for the ES.
Dinu
On the other hand, if you use platinum plugs, they can last a very long time.
The egr can plug up, especially if you run high octane fuel and don't use a cleaner [like techron] regularly.
Every auto has peculiarities you can learn. I kept my last car ["79 colt] 20 years and knew what it needed and didn't. It ran like a champ [a pun].
Dinu
Dinu
The problems that I've had should not be occurring until the five year mark. Perhaps Mazda is going the Ford route by pressuring their suppliers to cut costs which in turn produces cheaper and lower quality parts.
Carefully come to a slow stop using only the parking brake and see if you hear the squeal. best way to determine the location of the problem.
I would like to share me experience (rant that is) with everyone about a 99 Mazda Protege and their service warrrant. In the warranty I have had a starter replaced, minor repairs such as door seals, done twice on the same door, trunk seal and now at 60 000K (37500 miles) I have the water pump going bad. Good think I caught it early. Has anyone ever heard of a water pump going bad that early? In the last 15 years I had 5 cars none of them had a water pump ever go at 60 000. I have a 93 Dodge cold with 140 000 K with original pump.
The quality of Mada protege rivals that of ford. Feel free to send this email to anyone. Not a very good endorsement to but another mazda.
If the door seals had to be replaced twice, I suspect the second set wasn't installed properly by the dealer. Since both the door and trunk seals went, I would also suspect a bad batch of adhesive at the factory.
As for the water pump, I had one go bad on my VW Jetta at 8000 miles. That had to pull the whole motor to replace it. As a comparison, I had that car in for warranty work 13 times in 18 months (and 18,000 miles). If you peruse the VW forums here, you will see that sort of shoddy work in not uncommon. My Jeep Cherokee averaged a similar number of failures (5) to yours in a given year over the 5 years I owned it which is also not uncommon for the model.
My point is: while your problems are unusually numerous and not what we expect from Mazda, it could be worse. Be careful what manufacturer you flee to. I wouldn't expect most Dodges, for instance, to be as reliable as your Protege has been.
Ted
Thanks, Greg
Ford parts are manufactured in the US and they are more common than mazda parts which are probably manufactured in Japan and shipped to the US by boat.
At least, I believe that is the reason for the price difference.
Thank you very much
I wouldn't recommend continuing to drive with a failing MAS as it will make your idle uneven and too low. You could get by temporarily by feathering the throttle when idling (as for a stop light) to keep the engine from idling roughly or even stalling.
I have a 01 LX 2-litre auto with 25,000 miles on it.
Problem # 1
I recently noticed oil stains on the floor where I park my car. There seems to be a small oil leak/drip from the front of the car. I'm sure that this was not there before. I parked the car in a fresh spot and the next day there were oil stains there also.
The only maintenence I have done in the past 1 year is oil changes and one tire rotation.
Problem # 2
Recently, a strange vibration sound has started from the front of the car as if something is slightly loose. This usually happens when the car is accelerating and around 2,500 to 3,000 rpm. The same sound comes when I go over potholes/humps at any speed and hence I think that something near the wheels is loose.
Please advise.
-Ramprasad
1. You (or whomever) didn't replace the washer on the drain plug when the oil was last changed.
2. You have a loose exhaust manifold heat shield. Mine is currently missing a screw which holds it in place.
The dealer will be able to tell you for sure, but they sound like minor problems.
Good luck, and let us know how it works out.
Ted
I have always gone to a Mazda dealer(Sterling Mazda, Sterling Heights) and the car is still under bump-to-bump warranty.
I hope that u r right.
Is the "exhaust manifold heat shield" near the front wheel/axle or unde the front hood ?
-Ramprasad S.
Ted
