Mazda Protege Maintenance and Repair
1116117118119121
  • autonomousautonomous Posts: 1,769
    You might want to get it scanned for a problem code to narrow down the possibilities.
    You mention spark plugs being replaced; did you also check the condition of your wires?
    Finally, a common problem in the Mazda Protege is a dirty / clogged EGR valve; it may be worth a look see.
  • This sound like ignition coil/Wire problem. to check, start car and then spray water on the wire and plugs/coil, distributor and best if done at night so you can see if you see any sparks arc-ing where they should not be. Give it a try, it is free and let me know.
  • jrdwyerjrdwyer Posts: 168
    I have a '95 Protege. I have recently noticed (in the last half year) the fan switch malfunctioning on a few ocassons. For example, the switch can be on fan level 3 and the fan will not blow. If I then move it to 2 or 4 it will work. If I move it back to 3 it will usually work.
    I believe the contacts in the mechanical switch are probably corroded or worn out? and the switch is open and not allowing the flow of current. It hasn't occurred often enough to warrant me pulling off the plastic cover and examing the switch.
    edited October 2011
    I bought this car new in March '96. It has 230K+ miles. I believe the engineers who designed the seats probably did not anticipate a 220 lb. man using this car. Just recently, the metal seat rail broke where the bolt connects to it. A small piece of rail snapped off on the driver's front left side. The bolt at this location connects upward into a pivoting metal bracket while cinching against the rail. The bracket is connected to the frame of the seat.
    Thankfully, I found several good scrapped Proteges at our local pull-a-part junkyard. I got the part for $2.50. It was an easy removal/fix. I just pulled the whole seat out through the back door, turned it upside down, replaced the part, and reinstalled.
    I'm in this car for the long run. I need to attend to some rust in the rear fender wells. Will sanding down to metal, prime, and spray paint take care of it?
    I really don't have much clear coat left on the paint, so matching shouldn't be too big of a deal. The car actually looks very good when washed and waxed. The white color helps. I like the satin or matte look of the finish when cleaned, as opposed to the plastic shiny look of new cars with the clear coat. I may repaint the car down the road. I have a home-made paint booth in the garage and I have become handy with the purple $10 harbor freight paint gun, which is quite good for the price.
  • I"m loosing break fluid, and Im not sure where it's going. I recently replaced my master cylinder, because the seal was bad and it had been leaking into my booster. Days later, my break light came on. When I finally looked under to hood, the master was almost dry. Here's what's weird: Im loosing fluid, but I don't know where. I can pump the peddle up, but it will slowly drop. I can't see any signs of were the fluid might be going. If there was air getting in the line, then the peddle should be junk, and stay junk until I bleed the line out. If the master gets really low, the peddle is junk until I add more fluid. I am totally confused as to what is going on.
  • Mr_ShiftrightMr_Shiftright CaliforniaPosts: 53,925
    sometimes the brake fluid can be burned through the vacuum brake booster.
    MODERATOR --Need help with anything? Click on my name!
  • i have replaced the TPS sensor which is what that code is for and reset the car but code still comes on and O/D light still flashs 98 Protege LX 1.5
  • Changed the TPS sensor and still getting a P0120 and O/D light flashing...... any thoughts?? 98 Protege 1.5
    Could be your MAF sensor, and could be a wiring defect between the TPS and the ECM.
  • Hi!
    Long time... but did you ever figure this out? My 2000 protege is doing the same thing and I can't get it to pass inspection since it's unreadable!
  • Ok, so I was reading up on some of the Over Drive problems as well as the O/D Off mixed with the Check Engine light problems. Here is my problem, I have both O/D Off Light on (it blinks on and off constantly), and have the check engine light on. I have no problem, however, driving free-way speeds (65-85 MPH). What are some of the things I should look out for? And some places that do free diagnostics (without having me pay for the repairs right after doing the diagnostic, for they will charge me for the diagnostic check otherwise).
    Is my Over Drive really on, and just have the O/D Off light blinking for no reason? As for the Check Engine light, I have an idea that it may be the Spark Plugs since they do looks rather old, burned out and dirty. But, I wanna know some other known issues if anyone could help. Thanks.
    edited November 2011
    I have both O/D Off Light on (it blinks on and off constantly), and have the check engine light on. I have no problem ...
    The check engine light is a general alert to a problem with a critical area of your car (i.e. the engine). Driving with it "on" can appear to be okay but then again it could lead to a significant problem. A diagnostic that reveals OBD codes gives the mechanic more information to isolate the problem and solution. I believe Autozone provides customers a free scanning service to identify problem codes. However, be warned: the problem with the problem codes is that they, in themselves, may not point to the ultimate source of the problem but rather another symptom (e.g. fuel mixture may be too rich but is that caused by the spark plugs or some other source). Not addressing a problem may lead to a more expensive one (e.g. fouled spark plugs leads to failed O2 sensor). You might also look for related symptoms like burning more gasoline (i.e. less fuel efficient) than in the previous year to help determine the problem.
    If my car had a check engine light "on" I'd take it in to my favorite mechanic to see what he says. At the same time, he might help explain what is happening with the O/D light.
    Good luck!
  • hi guys.. i am a first time poster..i hope you can help me out. So the other day i was driving and i came to a stop light. When i left the stop light i accelerated and the car wold not shift it would just rev out in first gear. the o/d off light came on for a while and then went out..so i limped home and checked the fluid..it was a litle low but i dont think enough to cause it to stop working..i topped it off and it still did not want to shift..the speedometer works so i dont thinks its a vss issue..do you guys think a flush and fill with a new filter would do the trick or is it more than likely a solenoid or something like that. i do not have the money for a new tranny and i wreally need to fix this..thanks in advance..also the car works in reverse and has not yet thrown an CEL or any codes according to my scanner..i have not tried to manually shift the gears for fear i may hurt somethin..any help would be appreciated..
  • replace the alternator (bad brushes):
  • Kirstie_HKirstie_H Posts: 10,997
    Considering you responded to a message that's over 11 years old, I suspect the person has solved the problem by now and/or sold the vehicle. No matter... the info may help someone else, but you might check the date on the message you're responding to so you don't waste your time.
    Share your vehicle reviews
  • I would replace the fuel filter, air filter, plugs and wires, and egr valve. Also make sure your electrical system and spark coils are good. Pull each fuse out and re-insert them one at a time. Check your exhaust pipes for crimping.
  • I myself don't mind time travelling into the past to help somebody out. With all the brake fluid and other stuff I got in my eyes, the vision isn't perfect anymore. Especially for for seeing the date. :-)
    Nothing wrong with a trip in the wayback machine. :) Your response might help someone else anyway, even though the original poster probably isn't around and/or doesn't own the vehicle now.
  • osilkyosilky Posts: 1
    hey pmp3, I would like to clean my EGR valve as well, but seems to me that there seems to be no way around it w/o taking things out of the way. Any suggestions on how to get to it?
  • 1995 mazda protege that my daughter loves and cannot part with. I have had the mass air flow, fuel pump and a couple of other things changed but when the car is driven sometimes it stalls as if the fuel is not flowing and then it will kicks in. I cannot allow her to drive it in fear that someone may ram her in the back or she ram someone because when the fuel kicks in, the car goes forward really fast. No one seems to know what the problem is since I have had a lot of new parts put on. Can someone give me some help since I really don't know anything about cars. Thank you.
    edited February 2012
    This seems to describe a known problem in Mazda Proteges: the failure of the Exhaust Gas Recirculation (EGR) valve. Once the valve is clogged up, the flow of fuel is interrupted which causes stalling and then bucking once the fuel "kicks in". Most Mazda dealerships would be aware of this problem and the solution: a) clean the valve, or b) replace the valve.
  • Hi,
    I have a 93 Mazda Protege DX 1.8 SOHC . I recently re-did the entire exhaust system (after letting it run for a while with a few holes here and there), put on new spark plugs & wires, gave it a new oil change & filter, and a new tie rod end. After finishing up, I took it for a drive, it sputtered and lost power (completely). I checked under the hood once I got home, and saw a spark plug wire had come off of the distributor cap. I fixed the problem, and it seemed to work fine. I noticed later that when I start my car, there's a bit of white smoke coming from the tail-pipe, but it seems to clear up pretty quickly. When I drive it, it seems to do just fine, until I get to a decent hill. My car loses power almost immediately, to the point where I wasn't sure if my car WOULD make it to the top of the hill before it just stopped or started rolling back down. I've checked the transmission fluid, it's still a nice, bright red, doesn't look murky or anything. I made sure the terminal connections on the battery were good, which they are. I switched out the fuel filter, even though it really shouldn't have needed a switch. I made sure there was nothing wrong with the muffler and the rest of the exhaust system, and I'm still having issues losing power up hills. Any ideas???
    You may want to check the fuel tank for condensation or corrosion.
    You could bring it into a garage to have it diagnosed for OBD codes.
  • Mazda 2002 Protege 2.0 litre w/120,000. On cold mornings the vehicle starts but idles horribly, when it's put in drive it barely moves. After approx 6-7 miles it starts to loosen up and then will run like its brand new. If it's 50 degrees or more, vehicle starts right up and drives with no problem. I've had a diagnosis run on it, changed the front oxygen sensor on the manifold, changed the egr valve, new timing belt and water pump, new plugs and recently new hose between the manifold and air intake filter. My mechanic had the diagnosis completed and the pistons cylinders are all at 200 plus psi but the vehicle is running lean. The spark plugs look like they're brand new after a thousand miles. No one can figure this out.
    How about a coolant temperature sensor? If that was defective, it would approximate all your symptoms---just a guess, but....
    The theory is that a defective coolant temp sensor would tell the computer that the engine is already warm, thereby not enriching the mixture for starting; as the engine warms up, it is more compatible with the defective sensor's default reading.
    One thing to check is defective spark plug wire(s). This will cause cutouts when driving, but ususally it will only last a second or two. It occurred at 40-50 MPH for me.
    Other possibilities include a crack in rubber air intake hose/snorkle from the air filter to throttle, defective engine coolant temperature sensor, defective fuel pressure regulator, and water or other contaminants in the fuel tank.
    I got lucky when the upper radiator hose partially broke recently. It didn't lose all coolant or strand me and the car never went past its normal coolant temp. level. So I changed both hoses with new Gates versions (Made In USA, O'Reilly Auto Parts) and looked at my records to see how long the old ones lasted. The answer is 8.5 years! I have slacked off in keeping up on some maintenance with my 17 year old Protege. This car lulls you into complacency due to its good build quality and many excellent parts (origninal clutch, alternator, ps pump, starter, etc.).
    Also, I have been using long-life orange Dex-Cool (Prestone Version) on this car since 1998 with no adverse affects. Radiator is always clean with no gunk and I flush the coolant every 5 years. I just switched to yellow Peak global coolant because of a sale. This stuff says lifetime, i.e. no need to flush, and thus just top it off. We'll see.
    We also own a '01 Olds minivan and many people with GM minivans refer to Dex-Cool as "death cool" due to poorly designed intake manifold gaskets combined with Dex-Cool and the coolant getting into the engine and causing failure. Well, we did have the bad gaskets replaced twice under warranty (3rd set is a redesigned version), but since then no problems and we are still using orange Dex-Cool changed every 4 or 5 years. The van is 11 years old and has 130K miles on the odometer.
    That's reassuring to hear.
Mazda Protege Maintenance and Repair - Page 121 — Car Forums at Edmunds.com
