95 Oldsmobile Cutlass Supreme Problems
tjmeyers
Member Posts: 6
I own a 95 olds cutlass supreme with 104,000 miles
on it and lately when I am driving it the car
tends to chug. I watch the tachometer needle jump
around and sometimes the car dies. The oil light
comes on saying to check oil level. I've done this
and the oil level is full. I have changed the oil
on a regular 3000 mile basis(sometimes less than
3000 miles). I've owned the car for about two years
and this past summer is the first time I've had
this problem. I've had a mechanic pull the valve
covers off only to find that the valve covers were
caked with crusty black gunk and the drain ports
were almost solid to where the oil wasn't able to
drain back into the crankcase. The guy cleaned out
the drain ports and the problem stopped for a while
but has returned. Is there anything else that
would be inexpensive that I could do to fix the
problem (besides pulling the motor and rebuilding
it).
it).
So what to do... I'd check and clean the PCV system, run some Moto-Flush, and pray.
husband always did that. Now I am on my own and
checking a '91 Olds Cutlass Supreme, low mileage
(40K) and one owner who had it dealer maintained.
What kind of problems should I expect from this
vehicle? I have had three Honda Civics over the
past 15 years (all used) and loved them, but don't
want to spend over $4000.00 for a used car. BTW,
the previous owner of the OLDS is asking $3800.00.
I expect ignition and possibly brakes to be problematic, based on the age of the vehicle, but
I want to be sure that I am not getting an oil-burning, gas guzzling machine in several more
years. I want to hang to this car until I can
afford something better, but realistically I am
looking at 3 years.
Thanks to all who respond!
Also, the 3.1 engine tends to leak in a certain area. It is a relatively cheap fix. Read more about it here:
http://townhall-talk.edmunds.com/engaged/edmund.cgi?c=Maintenance&f=0&t=1380
BS
Does anyone know where to get the backlight bulbs for the auto climate control? Too bad GM had to kill Oldsmobile.......
Are you saying the lines where the rubber and metal tranmission lines join are leaking?
John
There is a site that charges $19.95 and you get unlimited access to your vehicle's information for one full year.You have to enter the year,make,model,engine size ect.You can print all information.There is an example vehicle on the site so you can get an idea of what kind of information you can get.The web-address is
(www.alldatadiy.com).
Nick
P0300 Random/Multiple Cylinder Misfire Detected
P0301 Cylinder 1 Misfire Detected
P0302 Cylinder 2 Misfire Detected
P0303 Cylinder 3 Misfire Detected
P0304 Cylinder 4 Misfire Detected
P0305 Cylinder 5 Misfire Detected
P0306 Cylinder 6 Misfire Detected
Nick
