Acura Integra - (All years/styles)
Same problem occur on my 1990 Intregra LS
Cost of new switch in 2005 was $60 Can
Part number I have for it is 35700-SK7-A01 Swtich Assembly
Hope this helps.
The problem will get worse as time goes too the point that you will also be not able remove your key from the igination because the shifter will not indicate when you are in park.
I am trying to decipher my 94 acura electronic fuse box. I want to install a radio and speakers, but the power line is just not sending any source to the radio... Let me know what you found out or did, please!!!!
Is this something I should be concerned about? Is it ok to just top off the PS fluid. (I think it's a small leak - not more than a cup or so every few months). How expensive is it to fix?
I just bought a bottle of PS fluid for Honda cars (have not added it to my car yet). In the store, I noticed another brand of PS fluid that says it's safe for all cars and that it stops leaks. Is it advisable to use the type that stops leaks? (I'm a bit worried since my owners manual says to use only Honda fluid or else damage is possible).
I've a 94 Integra LS.
First off, the question of which is better, TYPE-R or GS-R?
If you want to stick with all-motor mods(non-turbo/supercharger), go with the TYPE-R, it has a higher compression(11:1).
But, if you want all out power and insanity, go with a GS-R, it's compression is still high at 10:1 but with low compression pistons and cylinder sleeves, it responds much better to TURBO or SUPERCHARGING, mods and is capable of far more power than a TYPE-R.
I do not remember the magazine, but from a shop called ENDYNE in Dallas-Ft. Worth, Texas, they turbo'd a 95 GS-R to 744 WHP(wheel horse power). without slicks it was running 10.01 in the 1/4 mile.
Stock TYPE-R's at 195 hp are faster than Stock GS-R's(170) and will respond better to simple cheap mods.
VTEC in fact kicks in at 4400 with the first lobe, and the second lobe of VTEC kicks in at around 6000.
I own a 95 GS-R got it around 04-05 for 6k, the owner before me added Cold Air Intake, DC Headers, and Borla exhaust. An enormous storm here in UTAH swamped my old GS-R engine because i did not have an air bypass valve(now i know), USDM(united states domestic market.) I imported a JDM(japan(ese) domestic market) engine. it has a higher compression of 10.6:1 than a stock USDM GS-R, and 180hp instead of 170, with mods has over 200 hp.
I haven't topped out my new engine yet, need to fix my front right drive axle first(huge 1-1/2 foot porcupine damaged it) but my old motor with same mods hit 149 on I-215 here in utah.
Take Care All, and please research before giving info.
I'm really looking forward to the drive. I had a 1998 GSR that I sold in 2001 and can't wait to get back behind the wheel.
Thanks in advance,
Dave
New Belt- $799. ( never had it replaced, so probably need it, car bought in 99, new, have had all service done, but never new engine belt.. they are telling me it should be replaced every 60k or 5 yrs.)
Trunk Latch-$468 (latch is sticking, telling me they need to replace whole thing)
Front Brake-$189 (they say needs replacing, ok..break is making kind of hollow sound, so could be true)
Brake Cap-$75
Splash Shield-$117.98 ( hanging down, needs replacing)
Sunroof-$918 (sunroof is difficult to open and they say the whole motor is going and entire thing needs to be replaced) I live in southern nevada, so love having the use of the sunroof with the nice weather, but is it worth to replace or not?
Basic 37,500k service- $79.95
Love my car, have had no trouble since owning it. Replaced battery once, and recently bought new tires. Should I be putting this kind of money into a car that is this old? Should I skip the sunroof repair? :confuse:
Any insight you can give me would be much appreciated!
Brake Cap-$75
The Pedal st a stop will eventually go all the way to the floor. Acura service want 400.00+ for repair of just the Break Master Cylinder.. I can get the part for less that 75.00. Is there a web site I can go to to show me some parts breakdown for the "Switch you refer to and perhaps the Master Cylinder are.. I really Love this car and have had it since the day of it's birth :-)
By the way, I have read many of your replys to folks... I would like to thank you in advance for your support to them and Also to let you know... You have helped me as well :-)
chuchu1
Anchorage, AK
Recently replaced:
Clutch assy
Shift Master Cylinder (was leaking) then not shifting properly
Battery with Reversed leads
Relay (which controls fuel)
ABS master cylinder and accummilator
Break pads
Shouldn't this car be Toast?
:sick:
by the way, my 92 has no badge other than "west" on the hatch. i think it's a gs-it's a 1.8L 3dr. just curious if anyone knows.
The dealer said they cannot find a engine to get replacement parts.
My questions are these;
1) Does anyone know of a web site that has alot of Acura parts available?
2) Can a LS engine be put into a Type-R, will the tranny work?
3) Does anyone know of a machine shop that could manufacture the cylinder?
4) Any known good Acura rebuilders in the NE
I really want to keep this one. The body and interior is truly in mint condition. Please help.
http://www.uneedapart.com/
Regards
Corkscrew
I hope to soon sell (or possibly trade in) my 1996 Acura Integra GS-R (70,000 miles). However, currently it needs a new radiator and other parts. My local auto shop has given me a bid of $700 for parts and labor.
Should I have them repair it before I try to sell or trade it? Thanks in advance for any advice.
-dave
What are the insurance costs like for an 1999 Acura Integra LS sedan with automatic transmission?
Are these costs more than other import sedans like a Maxima, Corolla, or Accord?
I know that Integras (and like other Hondas) are the targets of thefts and also used for street racing.
Sorry this reply may be a little late for you. (Strangely, i bought my car the same week you posted your msg).
Another possibility could be just loose connection at the battery.
I am interested in hearing more on your needs/ideas for the integra - let me know.
I have a 2000 auto in great shape, but would like to hear more of what it might lead to.
SR
To answer your second question the costs would be higher than those for a Corolla or Civic, about on par with the Accord but probably lower than those for a Maxima.
I am new to this forum and looking to buy 1997 Acura Integra LS 4dr (114k on it); the deal I am getting it is $4800; I need help with the following:
- Do you think it's a good deal?
- Are Acuras known for long innings i.e. over 200k?
- Is there anything to negotiate on Acura Integra 1997/any known problems in the car?
- My need is basically a car for daily commute, put really around 70+ miles daily.
Need your help to answer the above. Looking forward to your help!
RK
http://www.youtube.com/watch?v=Jb6t-vK7Giw&feature=related
Bought an Accord and was only paying 900 A year.
