Ford Escort Wagon
123578
  • spectre3spectre3 Member Posts: 67
    i have had brake problems/noises on my 95 lx, but since i overhauled the rear brakes(new hardware & wheel cylinders) no more problems. the flat piece of metal that runs from shoe to shoe that contains the emergency brake pivot can sieze up and stop the shoes from retracting properly. this caused a noise & warpy feel when applying the brakes.
    have you checked your front tie rod ends?? they can cause a thumping to be heard when they get worn enough. i have went thru 2 sets of calipers on front of the car since new. they stop releasing fully causing rotor warping(and noises), even though the caliper sliding pins are lubed properly and the brake fluid is changed every couple of years.
    my mpg has fallen from a high of 42-44 on the interstate this summer to 35 or 36. suspect my o2 sensor is finally failing, even though no trouble codes are registering yet.
  • thescrollsawyethescrollsawye Member Posts: 1
    Check your oil level and antifreeze level. I get 28-30 city/highway;33 highway. Have 134,000 miles on it and replaced the water pump and timing belt around 70,000. Only major repair and it was preventive maintenance- it had not failed. Will replace it with Focus wagon since they've discontinued Escort wagon.
  • duck68137duck68137 Member Posts: 7
    We bought a new 1999 Escort Wagon SE. Which is the last year they made them. It seems to have quite a bit of power for a 4cyl Auto. But I have never gotten very good milage around town, especially in Winter. Somwhere between 17 & 23. Has anyone else had this problem?
  • wsharonwsharon Member Posts: 1
    The oxygen sensor is often the cause for the Check Engine light to come on. New sensor is about $60 and fairly easy to install; screws into the exhaust and plugs into the wiring harness. You may have to temporarily remove the radiator fan housing to have room to work. Takes about an hour, or maybe two.
  • taichidavidtaichidavid Member Posts: 1
    I'm in process of buying a 97 wagon with automatic transmission with 37,000 miles and am wandering what kind of gas mileage city and highway I might expect.
  • sho94_2000sho94_2000 Member Posts: 2
    This car is a lost cause! When the engine block gets too hot the ignition module fails, a thrity-five doller replacement. You can't go through a car wash, a puddle, it won't start if it is real humid out because something gets wet and it will either die on you or it won't start. My question is, does anybody else have this problem or is it just my car?
    the stalling in humid/damp weather...
    anyone check the coil wire(distributor cap to coil)?
    the ignition is hot enough to actually burn this wire in two in time.
    if you have the original ford plastic sheathed wire it can be difficult to see this phenomena.
    i had an 86 with the same symptom as yours, and thats what the problem was.
    as for the tfi:
    is the plug for your tfi module perfectly clean or corroded?? that can short out a perfectly good tfi module in a hurry.
    also the white goo that come with the module must be used generously, else the heat from the engine will get ya in short order.
    is the engine temp normal??
    lee
  • from_awayfrom_away Member Posts: 12
    Bought a wagon new in 1995. Had some initial problems with fit of the doors which dealer took care of in the first week. Have only had 2 problems. One was mentioned by another poster regarding the speedometer freaking out at highway speeds; only happens when it is cold out. Only other problem was a broken rear spring. Probably my fault as I tend to use it like a pickup. With 102,000 miles and only normal service and maintenance, I'm hard pressed to seriously consider buying anything new at this time. Plan to hang on to it for at least 2 more years. With 5 speed I am able to get 40+ mpg in the summer and around 33-35 in the winter. And by winter I mean northern Maine where daytime highs may only reach single numbers or less. If Ford still made the Escort, I'd certainly consider buying another one. Have not looked at the Focus yet, but probably will when the time comes based on my experience. By the way, this is the 4th Escort in our family. Wife also owned a 1982, 1987, and 1993 before trading to Honda Civic. (She did not care for the Focus; but may have bought another Escort if they weren't phasing them out.)
  • altsuleraltsuler Member Posts: 1
    Hi, I just purchased a 1995 ford escort wagon for 1200.00$ It has a rebuilt transmission (last month) 131,000 thousand miles. How long do you think the engine will last for? Should I change the timing belt?
  • riswamiriswami Member Posts: 192
    I think that depends on the maintenance the previous owner or owners have performed on the car. I have a 93 Escort Wagon with 130,000. Still running strong. The engine has never used a drop of oil.
    I know someone with a 94 or 95 Escort Wagon with over 200k. He changes oil every 3k.
  • fredshirleyfredshirley Member Posts: 1
    Our 1997 Escort Wagon gets excellent mileage on the highway, around 30-33 mpg, but only about 19 mpg in town, esp. in winter when "oxygenated" gas is mandated in our area, as it is in most metro areas. The additive used here in the Eastern U.S., MTBE, not only reduces gas mileage but pollutes the air and water; research has linked it to cancer and neurologic disorders.
  • cnsjjccnsjjc Member Posts: 3
    I have a '97 wagon which I purchased as soon as they were available - one of the first off the line. I couldn't be more pleased with its performance and reliability. It now has 74,000 miles and has had no problems except rear spring replacement - probably because I overloaded it several times. Why did Ford stop producing the Escort? Is the Focus wagon as good? Any recommendations for a wagon to supplement and eventually replace my 1997?
  • wendy123wendy123 Member Posts: 1
    Had my car in for inspection yesterday and it didn't pass due to the fact that both rear coil springs are broken (exact same places). The mechanic informed me that their Ford gararge has seen alot of these in the Escort Wagons. I called a few other Ford garages in the area to inquire about this and they too said the same. Question is "What is Ford doing about this?!" Seems to me if this is occuring so frequently that they should announce a recall. Has anyone written to Ford to complain? I'm planning on doing this myself. Sure would be nice if Ford would announce a recall and save me $240!
  • compensatecompensate Member Posts: 212
    Well, after reading many messages about the Escort Wagon, I did the deed and purchased a used 1998 5-speed model with 36,000 miles on it. I traded a 1995 Toyota Corolla that had 106,000 miles on it, as we needed more room.
    Outside of a few burn marks and stains in carpet/seats, it appears mechanically sound. However, as I inspected the car from underneath (it was lifted at the dealer's garage) I was concerned about some black colored metal around the bottom of the engine where the transmission housing meets the engine. It looked like some sort of burn, since it was soot black and did not rub off. I also noticed a little dryish dark substance around the bottom of the transmission and suggested to the mechanic that it might have a very small transmission leak. The mechanic said not to worry about it, because the substance wasn't "wet".
    Should I worry? Has anyone seen this before?
  • maryjoe1maryjoe1 Member Posts: 1
    I'm trying to change the oil on my mom's 98 Escort Wagon, but cannot find the bolt that unscrews from the oil pan to drain out the old oil.
    Could use some direction. Thanks.
    The owner's manual with my 1998 Escort Wagon showed an incorrect location for this drain plug, which may be causing the confusion.
    If you are lying on your back, lookin up at the bottom of your engine with feet pointing out toward the front of the car, the oil drain plug will be just to your right on the back side of the oil pan (the side of the oil pan facing the rear of the car).
  • wileylaurawileylaura Member Posts: 1
    I'M CONSIDERING PURCHASING A 93 LX ESCORT WAGON. FROM WHAT I'VE SEEN, THEY LOOK PRETTY RELIABLE WITH OCCASIONAL AIR CONDITIONING AND IGNITION SWITCH PROBLEMS. JUST LOOKING FOR ANY FEEDBACK FROM OWNERS OF THESE CARS AND ANYTHING TO LOOK OUT FOR...
    YOU CAN EMAIL ME AT WILEYLAURA@HOTMAIL.COM
    THANKS!
  • pocahontaspocahontas Member Posts: 802
    If you don't get a response here soon, you may want to post your question on our Maintenance & Repair Board. Put the word "escort" into the Board Search to see what kind of Ford Escort discussions are on that board.
    Also, you may want to check with the nhtsa website, or alldata.com to see what kind of complaints, service bulletins, and recalls are listed for your 93 Escort.
    For future reference, you can also find a direct link to the NHTSA's recalls and tsb's in Edmunds.com's Safety section. Good luck and please keep us posted.
    Pocahontas
    Hatchbacks/Station Wagons Message Board
    Hi, I've owned a 93 Escort Wagon since August of 92. Mine is a 5 speed. I've had the following repairs:
    Water Pump - 77,000
    Radiator - around 100k
    Tie Rod Ends - 121k
    Ignition - 125k
    Still have the original exhaust. I replaced the original battery in November of 2000. The battery hadn't died, but why push your luck. I live in Rhode Island; didn't feel like jumping the car and then changing the old one in the cold.
    I paid 8,788 for the car. Remember looking at a Corolla Wagon when I bought this car. The Toyota sticker was 16k.No one would the Toyota have been a better purchase from a cost standpoint.
    From what I've heard they are reliable. Not exactly a good performer and some may consider them unrefined, but I'm not going to get rid of mine anytime soon. My A/I still works fine. Car still gets 30 to 35 MPG and I don't baby it.
    If you found one that is well maintained then I wouldn't hesitate buying it. I not aware of anything to look out for.
    Happy Motoring! ;-)
    Pocahontas
    Hatchbacks/Station Wagons Message Boards
  • habrocket9habrocket9 Member Posts: 1
    My wife and I are considering purchasing an escort wagon 1998 or 1999 model. I have been a Honda owner for the past two decades, but didn't feel like taking out a second mortgage to buy a decent car. We have a 19month old as well as one due in May, thus the wagon. What do you people think? Here in Western New York, I am hoping to spend $8000-9000 on this. Any feedback will be appreciated.
  • mowslawnmowslawn Member Posts: 11
    I bought my 1995 wagon new in 1996. It is an LX with a 5 speed. It has been extremely reliable. The extra space has been very useful. I have 202,000 miles on it. I drive a lot of highway miles. I have had the radiator and headlight reflectors replaced (they get dim with age). I follow all of the regular maintenance. When I get the camshaft belt replaced, I also get the water pump replaced. The speedometer gets eratic above 60 MPH when it is cold, but it gets better as the car warms. I get mid 30's mileage. The car tends to ping some in warm weather; this may be due to gasoline mixture change by the oil companies in warm weather - so I have to run high test every other tank in warm weather. My original tires lasted about 50K miles. The second set, Goodyear Weatherhandlers, lasted 120,000 miles. The engine, transmission, suspension are all great. I replace all coolant/radiator hoses every 100,000 miles. I expect the car to go another 100K miles at least.
    mowslawn,
    is your escort unstable on the interstate when it is very windy??? my tie rods are new, new struts at 63k. the front end is tight enough to do alignments without a problem. i wonder if there is a worn spot in the power steering rack about midpoint.
    if i get 200k out of my 95(currently at 87k) i would be delighted. i also commute over 100 miles per day to work.
    the jumpy speedo,
    mine does the wavering/noisy thing above 50mph, hot or cold. i have a replacement, waiting on the time to install it.
    see you,
    lee
    lee,
    I don't notice any problem in windy conditions, but the winds in my area are not that strong. The car is pretty light, so I guess it could get knocked around. I have always had econoboxes, so maybe I just don't notice it.
  • wchauwchau Member Posts: 2
    habrocket9,
    I have a 99 Escort Wagon and I am satisfied with my purchase. Here is a short list of the things I like and dislike about my car.
    1. It is small so it is easy to park and it gets good gas mileage.
    2. It has a good reputation for reliability.
    3. It is inexpensive to insure. (Who is going to drive this type of car aggressively?)
    4. It can carry a lot of cargo.
    5. The engine has adequate power.
    Dislikes:
    1. This car is no hot rod (only 110hp) but I guess if it was a hot rod it would not be very cheap to insure and fuel.
    2. The engine is rough when it is idling and it is pretty noisy when driving at speeds above 70 mph.
    3. The low-beam headlights are not that powerful on a rainy night.
    4. An econobox wagon is not the ideal vehicle to own if you are a single male. :-(
    (But you don't have that problem.)
    mowslawn and lee,
    I have felt my car pushed around by the wind on the freeway on a VERY windy day about three times in my 20 months of Escort ownership but I don't consider it a problem since it happens very infrequently.
    thanks so much for the comments..
    it is nice to see the escort thread isn't completely dead.
    best wishes,
    lee
  • dogfacedgrmlndogfacedgrmln Member Posts: 1
    I've looked all over and haven't been able to find what all the colors on the back of the radio means for a 91 and a 94 escort. The radio is bad in the 91 and I got a 95 radio, but the clips don't match. Does anybody know what the colors mean EXACTLY? The 94 radio (which I paid $5 for) has more pins in the clip that the 91 does.
    Thanks for reading,
    on
  • pbb98pbb98 Member Posts: 19
    Red= Power
    Black = Ground
    Yellow= Constant power(for clock and preset stations)
    The rest are speaker wires (2 for each speaker). I forget exactly which wires go to which speaker.
    Does the clip plug directly into the back of the radio? If so, maybe you can get a plug out of a junk yard and match up the wires. A lot of Fords use the radio I think you're talking about so it should be easy to find one. Hope this helps.
    Pat
    Thanks for helping dogfacedgrmlin with his radio info.... Happy motoring! ;-)
    Pocahontas
    lira,
    I think the check engine indicator indicates a possible problem with the emission controls. I think the computer turns this indicator on/off. It could be something very simple or something like the EGR, oxygen sensor, etc. If it continues, I would get it checked since waiting might cause damage.
    mows lawn
  • jazzmusicjazzmusic Member Posts: 1
    My wife and I recently purchased a silver Tracer wagon with low miles. We are happy with the extra space and the car runs well for an economy car. But...at speeds of 65mph or higher on the freeway it makes a high pitched whistling sound. The sound seems to be coming from the passenger side door (either the door or the window). Has anyone else experienced this? Any idea what might be causing it?
    jazz music,
    I have never had that problem, but I can try a guess. The sealing material around the door might have a hole or break. You might be able to find this using a garden hose. The window may not close completely. Actually, my window whistles sometimes at high speed when it is not completely closed. Spray water around the edges, and see if any comes in. Then seal that place. Good luck.
    mows lawn
  • bgluthbgluth Member Posts: 1
    I am thinking about buying a minivan so I was doing some research and decided to check the Escort board. My wife and I purchased our 96 LX wagon new. It has the 5 speed manual transmission and I put Thule roof racks on it even though it had a factory rack. The car now has 72,000 miles on it and runs great. I commute to work in it regularly. It has been very reliable and averages about 30 miles per gallon.
    There was a redesign in the early 90's (When the body style changed). Most people that I know who have had the newer design have had very good luck with their escorts if they took care of them. Although most of them agree that the pre 97 automatics are slugs (Get a manual transmission!) I am encountering people that have 200,000 miles on their escorts and the cars are holding up well. I wouldn't buy an escort from before that redesign.
    We have had a few very minor problems and one other problem. The very minor problems were all body hardware problems such as door moulding becoming unglued, a plastic seatbelt guide broke, and the rubber shroud around the stick shift slipped down about 1/2 an inch and won't stay up. The broken seatbelt guide may have been our fault.
    The other problem was that the window gear wasn't installed right and needed to be reinstalled. (The window was difficult to roll up.) This problem was quickly fixed under warranty and has been fine since. I have had to have the car aligned several times but from what I can tell most small cars are knocked out of alignment easily
    I was very apprehensive about buying this car since it is the first and only econobox I have purchased (We own many other cars to compare it with.) I did a lot of research and found out that for the money they are pretty good cars. Sedans in the price range were so small that you could fill up the trunks with one baby stroller. I paid $10,900 including tax and license.
    I have read that the front end design will cause some front end parts to wear sooner than in more expensive cars, but supposedly the replacement costs are not too bad.
    I am not sure what other people are doing to their cars to cause the rear springs to break, but I have had no problem. However, I realize that the car is not a pick up truck. I do haul stuff (a dog, ladders, kyaks, lumber, roofing, tools, sacks of concrete) with it but I don't overload it, and I certainly don't pull anything with it. I do have all of the routine and preventative maintenance done.
    I don't abuse it but don't always baby it either.
    In conclusion, I have taken good care of the car and it has been very reliable, very inexpensive, and very practical, however I wouldn't want to drive across the country in it (I am over 6'1".) I would definitely buy another one as far as quality and reliability are concerned, but I probably won't, because I will get something larger when it needs replacing.
  • escort93escort93 Member Posts: 2
    I bought a 1993 Escort wagon (AT) two month ago. It has 130,000 miles.
    The car runs good but I have a problem, when I run above 60 mph and hit the auto cruise after 30 seconds the engine is loosing power. It's like the fuel supply not right in the engine and the speed decrease. I don't know why. I have replaced the fuel filter recently but it still happens again. Maybe the fuel contaminated with water in the tank?
    Please give me some advices about this one.
    My front windshield has some cracks, Do you know how much the cost for repair it? I live in Seattle, WA.
    Thank you very much for you help.
    Greg
    Sorry, I can't help you with the cruise control.
    If I was planning on keeping a car, and it had cracks in the windshield, I would probably get the windshield replaced. A cracked windshield might break more easily - a dangerous thing, and cracks tend to run. The last time I had a windshield replaced, the prices ran about $150 to above $300. It pays to shop around. I think I got mine replaced at SafeTLite.
    mowslawn
  • isabelquinonesisabelquinones Member Posts: 1
    I own a 92 Escort LX wagon. I would like to update the radio to include either a cassette or CD player. What would be the price range for product/installation? Is it a do-it-yourself project? Thanks.
    isabelquinones: A cassette player can cost as little as $50 or so while a fancy CD player can cost $400 or $500 so it really depends on what you want. A nice CD player should be easily under $200 though. Crutchfield is a good place to see what is out there and how much it costs. I think installation usually costs like $20 or $30 but it's pretty easy to do yourself.
    escort93: Did you try posting your problem in a Maintenance & Repair topic?
    I was wondering if anyone knows of any reasonably priced aftermarket rear coil springs for a '93 Escort wagon that hold up better then the stock ones. I have broken two of them in the two years that I have owned the car and I understand that it is not uncommon for them to break, especially on the wagons. Thanks in advance for any help.
    I have original speakers in my Escort 93 and the front speaker (left) has broken. I want to replace it with the original one.
    I've been looking at many stores but I have no luck.
    Do you know where I can find it?
    When does the water pump need to be replaced? mine has 138,000 mileages and no problem so far.
    Greg
    My pump was replaced at 77,000. The bearings froze.
    It gave me plenty of warning - but I didn't get to the mechanic in time. The timing belt also drives the water pump. You may want to consider replacing it when you have the timing belt replaced. The mechanic will be right there. Or you can take a chance and leave it alone. Who knows it may go forever.
    I would probably go to a junkyard for the speaker. I would test it in the car before you do your reassembly so that you could get another one if it didn't work right.
    The water pumps that I have had have generally lasted 70-80,000 miles or so. That is why I get them replaced when I get the timing belt replaced - every 60,000 miles. Like riswami says, there is less labor if you get them both done at one time.
    However, if my water pumps consistently lasted more than 138,000 miles, I would wait until they went bad. No sense replacing it if you don't need to. That hasn't been my experience though.
  • johnc19johnc19 Member Posts: 15
    I just discovered a broken rear spring on my '95 Escort wagon. I bought the car new and have driven 72K since then with no problems until now.
    I've heard this is a fairly common problem for these cars and I'm interested in hearing how other Escort owners have handled this situation.
    Has anyone gotten help from Ford?
    If not, how much should I expect to pay?
    Are there any related parts such as struts that will have to be replaced along with the springs?
    Is it dangerous to drive until I have it fixed?
    Any thoughts on this would be greatly appreciated.
    anyone have any trouble with an idler tensioner? This is on a 93 with a little over 60K miles
    I had one replaced around 100,000 miles. The serpentine belt would slip - even new belts. Replacing the tensioner fixed the problem. They aren't expensive to replace.
    well the belt doesnt slip but it making a very loud noise at idle.
    They arent expensive got one for free today (its for my gfs car).
    I think the noise may be caused by slipping.
  • budmelonbudmelon Member Posts: 27
    I have a '95 Escort wagon. Bought it used and so far no problems except that the temperature gauge seems to be on the cool side. It will only rise a little bit and not even close to the center mark. I had replaced the thermostat already and it is still the same. There is heat when I turn the heater on but it seems to take awhile before I can actually feel the warmth. Winter is coming and it would be nice to get some heat fast. Anybody has this problems or any ideas as to why?
    in the winter, my 95 lx has ample heat after about 3 miles of driving, with no warm up beforehand.
    my temp gauge never rises above 1/3 of the way from c in any weather.
    i hope that helps.
    if your heat isn't sufficient, the only thing left is the heater core or heater controls, if you don't have enough heat after a warmup and have changed the thermostat.
    is the temperature range of the new thermostat normal specs?
    with escorts of our vintage, you have to remove the dash assembly to change the core, according to the factory shop manual.
    that is a shame, my 1986 escort's heater core was easy to change..
    there is a good bunch of people in the ford escort owners association message board, if you ever have questions.
    hope to see you there.
    good luck,
    lee
    Thanks for the info. This owners association message board can be found here on Edmumds some where? Sorry, very new to Edmunds.
    Thanks again.
  • sebringjxisebringjxi Member Posts: 140
    Robbed an overhead console off an Escort in the salvage yard (sorry, no year identification!) and need help on how to set it. It has a clock with date and ET functions. Three switches on one side select whether you want it to display the date, elapsed time, or clock. Two switches on the other side pause or reset the ET function. I've got it working--display lights up and clock, calendar and ET all function, but I can't figure out how to set the blasted thing!
    Hal
    (you can post, or e-mail me at home--faulkner@hesenergy.net)
