Subaru Impreza Outback Sport & TS
Do you really want a carrier or are you just looking to use the coupon to get something? You know, you could just get a bunch of oil filters. I just bought about 6 of them and would have loved to have a coupon to apply toward them.
By the way, switched to Mobil 1 about 1,000 miles ago and get around 1 mpg more on my mileage, now.
Oh yeah, brekke, remember how crummy and old our driveway was? Were're having a brick lined horseshoe driveway put in this week and then will put in landscaping. I'll send you a pic when they get finished. Right now I've been having to park my little guy out on the street so can't wait to be able to use the driveway.
-mike
No job leads at all. I am thinking of moving...
I don't remember your driveway that much, just that there was a shiny OBS on it! I've been seeing more black OBSes around here, too.
For my OBS, I've been using an 8 cu. ft. Kanga Typhoon soft pack. This was pretty much the only closed carrier that would fit the pre-'02 OBS.
Since it fits directly on the roof, I can't use it on my wife's OB nor '02 and newer Imprezas (no rails directly on the roof as before).
I've already purchased a Thule Excursion for our next trip in the wife's car. I paid $230, which was $20 off the retail price. That's over $100 cheaper than the Subaru box.
-Dennis
Nippononly: Actually the information I passed on was advice given to me regarding the Outback Sport, and this was to tune the car for someone that did not need the tightness used in racing. I had told Mike Shields that I didn't want a real stiff, hard suspension, so that advice he gave me was to keep the ride quality near what it is.
However you are right about some folks upping the rear sway bar on the WRX. Some are upping the front one also, I think to a 22 from a 20.
By the way, thanks for backing me up in that Matrix vs. Vibe forum. I just wanted to see if I would get a reaction from anyone but didn't expect a favorable one! Do you own an OBS?
So from what I am reading, you would recommend some suspension upgrades even for a non-racer like me, huh? You are right, I had assumed you were talking about mod'ing a WRX. But that is good to know...
Stephen
-mike
Stephen
-mike
The Impreza TS wagon also has drum brakes. But I imagine the clutch and shifter linkage are the same.
-juice
Celeste:
Mike Shields (great guy, BTW) is absolutely right, flatter cornering and better steering response. The front bar upgrade really affects the steering response as does a front strut bar. The rear swaybar seems to affect more in terms of flatter cornering, as does a rear strut bar.
Stephen
BTW, how come all this time there has never been an option for a sunroof in this car? That would be nice too.
Now the alloys are back, plus they are 16". I hope Subaru makes 4 discs standard across the board, though, like they already did with ABS.
-juice
Or was there a '95 that I do not know about? The oldest OBS I have seen had 14" wheels, instead of 15's. And had wheel covers too.
When was the first year of OBS?
Bob
"The bushings are hard rubber which oddly enough is better than poly. You put the bush in and the clamp crushes it down tight--it is not going anywhere. They are exactly how we use them on our rally car. Ply would not last two hours, and rubber will run forever. Poly was used for cars that had soft fubber bushings in them. Subaru makes and uses much harder bushings throughout the car than most manufacturers and has an even harder set for rally use. For example, the excellent steering feel the car has, is due to the hard rubber mounts of the steering rack. Do not worry about not having poly bushings--we do not even sell them. We do sell special rubber rally car bushing kits for the WRX, but we do not change the sway bar bush, because it is hard enough already!"
Nippononly: I believe you could switch out the drum brakes for disks if you wanted to go to the expense and the trouble. I don't have any complaints about the braking though, and have had to apply the brakes hard in several situations. So I guess I'll put my money toward the bar and then the tires.
Someone on the OBS club was just talking about how his 97 (or was it 96?) OBS had 137 hp, which was upped to 142 hp I think in 99. So give the OBS enough time and maybe the engine will upgrade to the present WRX?????
By the way an article was referenced on i-club about a redesign of the headlights on the current Impreza that will debut at the Paris auto show this year, or maybe next year. Anyway. Bye, bye bug eyes. I just got used to them. They are different from all the clones out there and I think give the car a distinct personality.
-mike
Thanks celeste, I would not go to the trouble and expense of trading out the drums for discs, it is just that I have always wished for a stronger-feeling set of brakes on my OBS - since they were new, I have had to press the pedal fairly hard to get a strong response from the brakes, although they were always very good when I really needed them. So it would have been nice to see them go to the rear discs on the new OBS, since most of the other imprezas have them.
They bolt right up, bleed the brakes and you are away.
You trade up to 2 pot calipers instead on 1 pot which gives the pad a better grip on the rotor. The rotors and pads are bigger so you get more swept area that increase braking force and dissipates heat better.
An excellent low-cost brake upgrade.
The next mod is to change the pads for something higher performance.
Rear discs are more of sporty marketing thing on small cars that don't do towing or track racing. Drums are quite effective in the rear and are much lower maintenance. They definitely don't look as cool though. My 2 cents.
Linsavy: Sounds like good advice. They have a green pad that is dustless and I hear they're pretty good. Thinking of trying those when mine give out. Heard of em'?
"THE BRAKING SYSTEM OFTEN FAILS WHEN THE BRAKES ARE APPLIED WHILE TRAVELLING OVER A ROUGH OR BUMPY SURFACE, REGARDLESS OF SPEED (I HAVE HAD IT OCCUR SEVERAL TIMES, FROM 5 TO 35 MPH). IN THESE CASES THE ABS IS WRONGFULLY TRIGGERED UNDER MILD BRAKING, THEN THE VAST MAJORITY OF BRAKING POWER IS LOST AND THE CAR BARELY STOPS AT ALL. THIS BRAKING IS COMPLETELY DIFFERENT IN FEEL AND PERFORMANCE FROM THE ABS FUNCTIONING PROPERLY ( I.E. VERY HARD BRAKING ON A SMOOTH SURFACE. THE BRAKES WORK FINE IN THESE CASES.). THIS IS A COMMON PROBLEM THAT I AM HEARING ABOUT FROM OTHER 2002 IMPREZA/WRX OWNERS."
Have any of you had this problem? Please reply.
Thanks, Heather
Porterfields are near the top in quality but cost alot. Carbontech and Mintex make some good stuff.
Heather, I have heard of the ABS issue before. "often" is a relative term. The key is "bumpy" roads. If you brake hard on a washboard gravel road. ANY ABS system is going to have a difficult time with it. The ABS is tricked up by the dumps causing the wheels to lose traction. The subaru system will do better than most given that it is a 4 channel system with sensors at each wheel. Some systems are only 2 or 3 channel and will brake the rears or fronts together instead of independently. I would only worry about this if the took different cars over the same section of road and found the Subaru to be worse than the other.
ABS is not a perfect saftey measure as it increases stopping distance in snow and loose gravel situations. Some people even turn the system off in winter by pulling out the fuse. I think the thing to remember is to not over-drive the conditions. Bombing down forest roads may be fun but is harzardous for amatures.
Heather: I've heard of one such case, so it's not unheard of but definitely not common.
-juice
Was reading in the OBS club over at Yahoo about a guy whose mechanic told him some 2002 OBS's have had camshaft seal leaks. First I every heard of it--anyone here?? Of course, who knows what number "some" is...
The 2.5l and the 2.2l engines are known to have issues with both crank and cam seals. The best thing to do it to change them when the timing belt is being done. Cheap maintenance. They only cost 100 or so extra at that time.
The rear crank seal is another story for cost, but I haven't heard too many issues with it.
-juice
OBS owners are a fairly small portion of Subaru owners so maybe few have had this issue or have high mileage. It is fairly common to Legacy's from early 90's.
-juice
Of course, I don't fault the car - still a great car, and all the things it needs are just regular long-term maintenance items, or things that are expected to wear with age, but geez, if I had know about some of these a year ago when they started to present themselves, I could have spaced out the $$ outlay!
Funny, that with all the stuff it needs, it still feels to me like it drives like the day it was new...maybe that is a testament to Subaru, I don't know...
My dealer is the opposite. I'm usually surprised at the little things they can find (little things that could have led to major things, actually).
-Dennis
The only suspension work I've had done is a strut replacement before 36k and one at ~50k.
My current dealer, that's been in business about 15+ years, has only seen "a few" Subaru's that needed new struts.
-Dennis
-mike
-Dennis
My wife's 626, at 71k miles, needed struts. But we just sold it.
-juice
If you really need struts I have some suggestions.
$100ish plus shipping will buy you 4 lightly used impreza RS struts and springs at i-club.com. Expect to pay about 300-400 for labour to install. They will lower the car about an inch and give you better handling at the expense of off-road ground clearance. RS and OBS struts are the same, but the RS springs are stiffer and shorter. You could just get the struts for less $. or
Buy some KYB GR2 gas struts for around $300 at p-s-t.com. Same for installation. Somewhat stiffer valve rates but not harsh.
Next up is KYB AGX struts for $390, same as GR2s but you can adjust the value rates from soft to way hard.
All of above are upgrades from what you have for much less than just replacing the struts with Subaru parts.
$1500 is way too much to pay. You could get coil-overs for that.
You have some time before you need to do this stuff by the sounds of it. I would look for a rebuilt alternator to save money. Do the cam seals when you have the money. A little leaking shouldn't be a big problem.
Cheers.
thanks for any assistance.
Just a few thoughts from the weekend mechanic
-Dennis
-juice
Use lithium grease.
-juice
