I'd never allow them to rebuild a transmission - install a NEW one possibly.
GM builds the best automatic trannys in the industry (which is why everyone uses them). If mine broke, I can assure you I wouldn't settle for less than a new one.
This sounds like an occasion to be very firm with the dealership, zone manager, etc.
-Dan L.
'00 BMW 528
'01 Montana
Anybody know where I can get a drain plug with a magnet on it to replace the plain steel one that came with the van?
Just curious if anyone has seen the AWD models on any lots?
Most posts that have to do with water leaks have focused on the rubber boot that goes form the body to the tailgate at the top as a source of leaks. What area is getting wet in your Montana? Has it had a Windshield replacement? Where has the dealer been looking?
Thanks!!!!!!!!
I find your last post interesting. "..yes, I expect perfection from a new car but they all have their problems". Several posts ago, I thought you said the car was a former rental car in Canada, and you found broken glass in the car. I think it makes your car a used car with a questionable history. On way anything rusts is being exposed to weather when it wasn't designed to be. Could it be possible that this Montana has been in an accident? Improper installation on the tailgate window may cause a leak but it would not wet the headliner. Look forward to you post about the leak fix and more details about the smoke fix. And when you post back could you include the last 6 numbers of your vin so others can see how their build sequence compares to yours, in case they have simular issues.
JC
A 2001 is a 2001, so yes it is a new car. You must be a Pontiac rep or something to take these comments to heart. At first they were helpful but I didn't mean for anyone to take it personally. If I think my van is a heap then goody for me. It is one thing after another and I am sick of it. Now it smells horrible like something electrical is burning when A/C or heater is running. Pontiac 800# is dealing with it now and mentioned getting us another. AMEN...Peace, Love, and Pontiac.
I was only writing to see if others had the same problems. No harm meant. I still dig the van.
Also, has anyone found a good deal on an extended warranty? All the electronics kind of bother me w/ this car.
Agree the windows on the sliding doors as opposed to the very rear do rattle, and it was the same on our Lumina APV.I do not think the hinges give them very good support. Personally, they are not worth a light and rather have the a/c on and keep them closed. This apart from the fact that they are pesky to open and close and good for taking off your finger nails They are a cheap non solution, whereas the Mazda MPV has regular roll down..about the only minivan that does.
Barry
Drew
Getting any other goodies (and when is the delivery eta)?
And, anyone, why is there a $69 New Jersey surcharge for this van?
Steve
Steve
I do not have a clue when it may be built. The thunder package may be a problem. I heard (on this list) that AWDs were being produced.
Also, I am in Tx and we have extremely hot weather. This causes the glue on the head lamp outer cover to fail eventually and it will fall off. If you are lucky you can catch it before it falls off. (Check it every time you wash the car) Remove the head lamp assembly, carefully remove the cover, and clean all the old epoxy off the cover and also clean the reflector housing and inside of the lens cover. Mix up some new JB Weld clear epoxy and put a thin bead all the way around the reflector assembly where the cover attaches. Reattach the cover and wait for the epoxy[ to cure before reinstalling the assembly. This costs you about $5 versus about $150 for a complete new assembly. (I didn't catch the left one in time!)
A new problem I haven't seen on any post yet is a slumping rear passenger power vent window. When opened it would drop down slightly and when one tried to close it, it would close on the body lip and not properly seal. The short term fix was to hold the glass up as someone else pushed the switch to close the window(watch your fingers). The dealer ordered the entire glass with hinge and replaced it under warranty. Seems to work fine now. The other nagging problem is the leading edge seal on the power sliding door. I've had it replaced twice since I purchased the van last spring. The latest fix is a completely new type of seal that looks like it should stay in place a little better than the original gluey type. Check it out at your dealer if this has been a chronic problem with you. On another point of interest, we had all the rear seats out a couple of weekends ago to fit in a 4 x 8 sheet of plywood. IT FITS!!! The front seats had to be moved up a little though.
All else is working just fine.
As for the tires, I have not noticed any change in gas mileage. If anything, I would expect the larger tires to help my gas mileage because the larger diameter means I am going farther each time the tire rotates. I would expect that my speedometer may be off by 1 or 2 mph, van is going faster than the speedo shows.
Good luck!
Now I have to find something else...
I'm on my second Montana (a 99 we leased, now an 01 we just got). No leaks, no rattles.
-Dan
-dave
Craig
Thanks Again, Craig
Don't get me wrong, I think the interior of the Buick is fantastic compared to the minivans, and as a people hauler I think they're both great, but when you're carrying strollers, groceries, etc...
-Dan L.
'00 BMW 528
'01 Montana
Craig
Let me ask you one question: Would you buy another Montana tomorow based on what you know today ?
Rattles...have you experienced squeek and rattles ? if any how hard to fix and their location(dashboard,sliding door etc
Thanks for your input
Thanks, Craig
