...at 6-7pm Pacific/9-10 pm Eastern. Hope to see you there!
http://www.edmunds.com/chat/subaruchat.html
-juice
maybe try a new battery for them too - especially if they're the original ones.
-Brian
Plus:
1. Handling is great, as good as my V6 Honda accord.
2. Room is good, though one may think it is small from the outside, just get in and feel the room.
3. Comfort is very good, leather seats feel good though they are hot in the summer as expected.
4. Engine is powerful, I just passed the 4K rpms today's as I passed the breakin period. The speed was at 85 MPH ( on the highway) and still feels like there is a considerable amount of power still left.
5. Sound system is good (not great) and more then sufficient for me.
6. The two sunroofs are excellent.
7. As expected, car is very tight.
Minus:
1. MPG average around 22.
2. Acceleration is average which can create a problem when darting out of traffic such as a highway. It certainly is not on par with my Accord V6 acceleration. But then again, it isn't supposed to be!
3. 6 Disc CD changer. Had to get this removed after 2 weeks as one disk refused to come out then, the whole unit refused to play a disk. First recall, I am not a fan of in dash 6 disc changers as then are more prone to failure then the cartridge type units in trunk or under a seat.
4. Driver power seat adjustments: could use more space for a man's arm the adjust the controls. I'm 6' 205 lbs, and my arm hits the door.
One question: Has anyone had these vehicles in the sand and can you relate your experiences such as tire pressure, sand depth, and overall driveability. Thanks.
Try this, get inside the car, lock the door. Now manually unlock the door. Do the rest of the doors unlock? Try it from the outside with the key (with sec system disarmed). If you have problems here then it is probably the switch.
If this works then its probably something with your sec system
The sand conditions were not good 18 inch deep light powder superfine sand. If it was snow it would have been skiers heaven. It wasn't. Walking in the stuff you sink in past your ankle.
Tire pressure was not something I knew about. I had them at 30. 10-15 would work much better.
Handling was not very good. The main reason being the 18" ruts that we constantly had to go across. The lack of ground clearence was a factor. It felt a lot like driving a boat. We got stuck once because of the lack of ground clearence. You essentially plow your way through that sand and once time we slowed down a little too much and high centered. That 4wd has great traction but it doesn't do any good if the wheels are not touching the ground. Took around an hour to dig the car down.
Gas milage sucked bad, maybe 7mpg because your plowing so much sand.
I had the front and rear undergaurds. If your going to be going through sand that exceeds your ground clearence you might want to remove that plastic undershield. I doubt that it is going to survive being dragged through the sand and being struck by the occasional hard object.
These were some pretty tough conditions though. Regular 4-6 inch sand shouldn't be a problem if you lower your tire pressure (though I would still worry about the plastic bottom if there is debris).
Cheers!
Paul
I had my new Bean (1000 miles) in sand just a couple of weeks ago (Font's Point in Anza Borrego State Park). Consists of about 3-4 miles up a sandy wash to a point overlooking the "badlands".
Conditions were not as bad as described by evilizard, but there were a couple of deep stretches where it felt I was driving a boat with delayed steering response. But last year I drove a Jeep Wrangler through the same section and it felt just the same. I followed the same Jeep this year and noticed that because he was fully loaded, he had less ground clearance than my Bean.
I had just myself and some gear in the car. Felt no problems driving, AC worked fine in 108 degrees outside, and the CD player didn't skip a beat. Would do it again anytime.
Steve
Huppert
Greg
We cannot understand why this vin number showed up on the computer in the autobody shop as having 5,000 miles on it and my odometer shows 600 miles--help anyone???
Do you think that 28k is a good deal for a '01 LL Bean w/ L06 Pkg? I know that the '02s will arrive soon, so I was just wondering.
- Approximately 80% city driving, short trips
- Live in the Chgo metro area so we are subject to the "winter blend formula" in northeastern Il
- Tires inflated to 33F/32R and checked once a month
Here is what I have experienced:
Average mileage across 3,900 miles = 20.44 mpg
Best tank mpg = 24.4 (represents a mostly highway trip of over 300 miles.)
Worst tank mpg = 14.7 mpg (This could be a fluke but I HAVE double-checked it. If I throw this "outlyer" out, the next worst tankfull was 17.8 mpg.)
It should be noted that through mid-April my mileage average was generally BELOW 20 mpg. From May on however, mileage has generally been above 22 mpg (with one exception)
Conclusions:
1)Winter blend mixes have a major impact on the mileage you experience.
2)This vehicle can experience significantly different MPG based upon city vs. highway driving.
I hope this helps people out there with mileage questions on the H4 OB.
RR
If it works with the engine running, I'm lost there.
Otherwise, maybe they forgot to connect them.
I have a very small air compressor that I use. It does run with the ignition in ACC/ON but it runs about 5 times faster when the engine is running.
If it doesn't run with the engine running then you've got a loose connection.
I live in SE Wisconsin (Kenosha) - we too are subject to the same gas blends as you. Coincidentally, our Outback has about 10k on it now and is averaging 22. The lowest I got was 17 (in December [it was really cold] and March). Our highest is 28. My driving is mainly city - my workplace is only a few miles away - so I expect my mileage to be low. We also regularly travel to my parents on the weekends, so it gets to 'open' up after a week in the city. I tend to drive our Outback hard (well, at least not gentle on the pedal). I also manually shift the automatic a bit. I also like to take the RPMs up into the 4k range every once in a while.
I agree the winter blend does impact the MPG that our vehicles (and practically ANY vehicle using it). Our average for November through March was 20 - for the same exact driving I'm doing now. The average from April through June was 23.
I think I've heard here that the 'sweet' spot for highway MPG is right around 65-70 mph. Go above or below that and your MPG will not be as high.
FWIW, I always use 87 octane from Amoco, Mobil, or Shell. And after every oil change, I add a bottle of Techron.
-Brian
Greg
Ross
-Brian
At low setting, it warms up gradually but quickly. On high setting, it HEATs up in a minute. In the summer with leather seats, it FRIES. Accidentally hit the switch one rainy day... my butt was dry and every where else was wet. :-)
-r
Don't you wish they would just deep six the winter blend stuff?
RR
I used 18psi on the sand and that seemed to work well. I felt like I could have gone lower, but the 18psi worked well even on the deep, soft sand leading up to the beach.
-juice
PS That was my Forester with 225/60R16 tires, same as on the new Outback
If not then maybe another part of the front suspension, I'd guess.
Just drive fast! ;-)
-juice
This time:
*The brakes. One has to push the pedal near the floor to get any kind of stopping power. Go here: http://www.nhtsa.dot.gov/. It appears other have already complained about the same problem.
*There is a loud rattle when accelerating (sometimes). I dont think its engine knock as its much louder. It better not be the transmission.
Still like the car but the reliability has been horrible.
bit
I'm not sure if SOA heat cures, but chances are 30 days pass by from the time your vehicle gets it's paint until it shows up on your dealer's floor.
Bottom line -- wax away! Frequent washing and waxing is the best thing you can do to keep your paint job sparking!
Ken
The car was made in late January, and I brought the car in late March -- so that is approximately 60 days. But the dealer (Don Jacobs in Waukesha, WI) told me that they do this in their normal 'prep' for all new cars...
Sorry to hear that, nematode. Please keep us posted, and we'll put Patti on their backs if the dealer is uncooperative.
-juice
Greg
Hmm, I can't find a photo of the front sway bar, not in my photo album, nor on i Club. Here is my rear sway bar, though:
It's a curvy black metal bar. On the sides, it bolts to each side of the suspension. Further towards the middle, there are two rubber bushings (inside the metal cover I am bolting on in that photo) that allow the bar to slide side-to-side as the suspension flexes. Note that mine are greasy around where they meet the rubber bushing - I put lithium grease on the rubber bushings so they can move around without squeeking.
Or let the dealer have a look-see, just mention it to him as a possible cause (along with other components in the front suspension).
-juice
PS Elsie: I would change dealerships. They do not deserve your business. I bet it was damaged at the dealer and they tried to hide it.
Other than the brake pedal though, after 11 months, I still love my 2000 base OB.
Mark
-juice
The squeaking noise may very well be the Anti Roll Bar binding a little in the bushings. It is a five minute job at a dealer to lube it. I had this problem when new. Its not however an item to get hung up over. It is just one of those things which happens in assembly like when you buy a new shirt and find the label rubs your neck. Irritating but easily fixed
Cheers
Graham
One of the major amusements of watching Americans (if you come from somewhere else) is the unthinking rush to lawyers when things are even a little inconvenient. We can't figure out why apparently intelligent people have not figured out that you do better by talking directly to the supplier, resolving the issue without someone else taking a cut from the dispute. You get better results that way.
Don't you think it would be smarter to call Subaru and outline the problem. Patti Mickel of Subaru posts regularly on these pages and the Subaru Club - meet the Members pages. Why not try that first.
Cheers
Graham
It happened when removing a NEW, in the box, lawn mower purchaed from Costco. The over sized box was slid over the back bumper.
Damage: noticeable scratches and a big chip.
Where can we find Outback paint to cover this up?
What can be done about the scratches?
What can be done to prevent this from happening again?
When buying your car, where you warned about little things like this? If so, what?
Another note: After two days of ownership, the dealer has not processed our paper work with Subaru. Which is preventing us from becoming members of the Subaru web site. How long did it take the dealer to process your paper work?
he,he,he - only kidding. However, I do agree with you. Although there are appropriate times to use their service, they are used to often many times because someone cannot take responsibilities for their own actions. (Sharon - this is not intended for your post, just a general statement. It seems SOA is working with you so hang in there. Everyone I know who owns a Subaru says nothing but good things. I wish you well)
Jack - Sorry to hear about your first scratch/chip. I had mine only a week when I went through a construction site and a stone gave me my first chip on the hood (although it is very small). I now have a hood deflector installed. You can get touch up paint at your dealer. Maybe some wax on the scratches will help. As far as it happening again - there are no promises, but some here think it adds character and goes with the OB image. Paperwork - 2 days is not enough. I believe I got my initial paperwork in the mail with my ID 4-6 weeks later. Have some patience and enjoy driving your new Sub. Welcome to the club.
Greg
Ouch! Sorry to hear about that. It's always the first scratch that hurts.
Fine scratches can be removed fairly well using wax. I'd first clean the area and apply some wax to it to see how it looks. Deeper scratches and chips will require touch up paint. You can buy this from your dealer in little containers. When applying the paint don't use the built-in brush. It's way too big and will leave globs of paint. Buy a very fine brush to do the job instead.
Ken
Dealers have touch-up paint for about $5, if you do end up needing it.
-juice
