Chrysler Town and Country EX/LX/LXi/Limited
thks,
Pete
Pete
The airbag warning light comes on in our Ltd shortly after starting. It stays lit for 5-20 sec. I took it into the dealer on Friday for a check and was told my Airbag warning light was caused by the "clock spring". I was told that they are on 'colossal back order', especially for steering wheels with the radio controls built in. He said expect it in 1-2 weeks - that doesn't sound good. I expressed my concern about an airbag misfire or failure to fire and he said that the airbag is deactivated when the light is on - wont' fire - but as long as the light is off it should work fine. Also there shouldn't be any risk of misfire. Easy for him to say - it's not his wife behind the wheel!
Anyone out there have any knowledge of this? Sounds like the 'clock spring' is a growing issue for DC.
grh7 any input here????? Thanks!
Drive the popular PT Cruiser, the new Sebring lineup, and other extraordinary Chrysler vehicles at the Chrysler Proving Grounds. It's a free test-drive event that allows you to wind through a series of slalom turns and then pick up speed in a straight-line acceleration test. But, what's really exciting, this is not a sales event. There'll be no salespeople on-site. It's a simply a rare opportunity to drive some of the most innovative machines on the road.
The fun doesn't end on the course. After you've put the vehicles through their paces, there'll be interactive displays to enjoy, activities to participate in, and a full line of Chrysler vehicles to check out. Concept and historic Chrysler vehicles will be on-site, along with a golf range for you and putt-putt golf for the kids. A new PT Cruiser Tent will be set up this year. And, if all that isn't enough, you can drive the new Jeep Liberty at the Jeep 101 off-road course adjacent to the Chrysler Proving Grounds.
Chrysler Proving Grounds takes place August 16 to August 19 at Philadelphia Park. Sessions will be scheduled hourly from noon to 7pm on Thursday and Friday; 10am to 7pm on Saturday; and 10am to 5pm on Sunday. Choose the day and time that works best for you, and plan on making a two-hour time commitment. You must be 18 or older with a valid driver's license.
Space and time are limited. Call 1-888-TEST-CHRYSLER before August 10 to register.
Directions: Take the NJ Turnpike to Exit 6 (PA Turnpike). Follow west to Exit 28 (Philly, Route 1). On Route 1 South, proceed 1/8 mile to Street Road East (PA 132). Take Street Road for 2 miles to the track entrance (on the left). Follow the signs to event parking.
http://dailynews.yahoo.com/h/nm/20010717/ts/autos_crashtests_dc_3.html
Note that the crash test is rated POOR because of a gas leak that occurred. The reason for the delay in announcing the results (originally scheduled for March) was to allow DC to fix the problem (which they claim they can't duplicate). For 2002, the rating is ACCEPTABLE, and presumably also for 2001 cars that have the recall applied:
http://www.iihs.org/vehicle_ratings/ce/html/0102_02.htm
http://www.iihs.org/vehicle_ratings/ce/html/0102.htm
A view of all minivans in the offset test is here, the T&C falling just below the MPV:
http://www.iihs.org/vehicle_ratings/ce/html/summary_passvans.htm
FWIW, I posted here a couple months back about a complaint on the NHTSA site regarding the leak after the crash test.
Would I make a different decision today given the crash test results? Probably. The T&C has been great, but I'd characterize the NHTSA and IIHS results as "sub-par" given that DC had time to study the Ford, Toyota and Honda results while designing this minivan (I'm taking into account the recall for the 2001 van in this assessment). If I was to do it again I'd either compromise on space and go with the Sienna or on comfort and go with the Honda.
As always, drive carefully.
Steve
1. Wind Noise - sounds like it is coming through the driver side window. I had it checked once and the dealer said they couldn't find a problem. I found a link in an earlier message about a TB but couldn't find it at the site.
2. Noisy idle - sounds like it might be the serpentine belt problem talked about. It hasn't ever come off but it sure is annoying and my feeling is when you spend 36K on a vehicle, it shouldn't idle like an old junker.
3. The emergency brake keeps needing to be adjusted. It wouldn't even catch at first. The dealer fixed it but it keeps messing up (the pedal goes almost to the floor before it holds)
4. The brakes have always squealed. Again, shouldn't have to put up with in an expensive car. Now, there is a rubbing noise when I brake.
5. Recently, when braking at freeway speed, it's developed a shimmy.
Any suggestions on the best fix for these problems? I'm hesitant to take it to the dealer until I have a solid idea of the origins of these problems because I don't want them gouging me.
Kathy
Require a Recall for the fuel tank - Submit a form today http://www.nhtsa.dot.gov/hotline/
From the above link, you will be able to see the detailed injury and cabin intrusion measures from the IIHS test and compare them to the other minivans. While this doesn't give the entire story, it does give you a good idea of why the IIHS assigned the ratings that it did.
Obviously as little cabin intrusion is best, and as low as possible injury indexes are the best. HIC is the Head Injury Counter; the IIHS can tell if the person would get a light concussion (Are there any light concussions? Probably not. All concussions are bad.) or a serious brain injury from the accident, if it was a real person instead of a dummy in the driver's seat.
Doesn't look like Chrysler will be recalling the vans because they think that the fuel leaks from the fuel pump/tank are not severe enough to warranty that.
Drew
-Adam
But, I do plan to take it to the dealer after I take it to a reputable tire/brake dealer and have it looked over.
Kathy
- Question: is Chrysler providing an extra incentive (beyond the $2000 rebate) for existing Chrysler owners who buy/lease a Town & Country? In essence, is their a "loyalty program" in place?
Steve
we were able to get $900 off MSRP on our EX which apparently no rebates/incentives are in place for.
It took time and [only] 2 lots. At the first lot the dealer said selling at MSRP' and walked away.
[Lot 2 beat carsdirect quote by $227 yet according to Edmunds we could of maybe done $780 better.]
hope this helps some...
heir website 7/18/01 9:06 Am
I just learned of the Insurance Institute's recent crash test study and retest where they indicated that the 2001 Chrysler Town & Country and Dodge Caravan's had the potential for fuel leakage upon a crash. I also learned that you have corrected this problem on all 2002 models but will not be recalling or repairing 2001 vehicles. As the recent purchaser of a 2001 Chrysler Town & Country Lxi AWD, I hereby request that you recall all 2001 Dodge Caravans and 2001 Chrysler Town & Country vehicles and repair this potential problem at your expense. Since this potential problem is now public knowledge, DaimlerChrysler will be fully liable should a crash and a subsequent fuel leakage occur that results in serious injury or, god forbid, death. I bought a Chrysler Town & Country because of your promise of safety. To not repair a potentially deadly error such as this is negligent and short sighted on your behalf. Please recall my vehicle and all of the other affected DaimlerChrysler products as soon as possible, or you will forever lose this customer and tens of thousands of other potential customers. Please do not repeat the mistakes of your predecessors. As one should realize from the recent Ford/Firestone controversy, courts will take a very unfavorable view of automobile manufacturers who fail to correct mistakes that they have been made aware of.
Please contact me at your very earliest convenience, as I fear for the safety of my wife and our 21 month old child.
Thank You!
Here's the latest:
http://dailynews.yahoo.com/I/pa/20010717/as/daimlerchrysler_gas_leak_1.html
CRS Market watch story
Drew
Vans, Subs, and Aftermarket & Accessories message boards
Transport Canada:
http://apps.tc.gc.ca/roadsafety/Recalls/recintro_e.htm#If
DC Canada Customer Assistance:
http://www.daimlerchrysler.ca/corporate/en/assistance.html
My wife called Chrysler today, and here is a transcript of the telephone call.
Wife - "I am calling because I recently saw numerous reports on the potential for a fuel leak in the Town & Country minivan, and we recently purchased a Town & Country minivan. I want to know what you are going to do about this problem."
Mathew Long from the DaimlerChrysler Recall Center - "this test wasn't done by Chrysler. It was done by an insurance company."
Wife - "Not an insurance company, by the Insurance Institute for Highway Safety."
Mathew Long from DaimlerChrysler - "Chrysler has tested the car 50 times and was unable to replicate the results. There is no problem, and there is no action to be taken."
Wife - "Well if there is no problem, why did you redesign the 2002 model?"
Mathew Long from from DaimlerChrysler - "For safety's sake."
Wife - "That is exactly right, for safety's sake."
Mathew Long from from DaimlerChrysler - "Well we are always redesigning cars for safety's sake. We are always making them safer."
Wife - "I have had the car for 3 weeks. I refuse to drive it. I am not going to explode in an impact. I can not get my daughter out of the car seat quickly enough. I want to know what Chrysler is going to do."
Mathew Long from from DaimlerChrysler - "Nothing."
Wife - "So you are saying that for safety's sake it was redesigned, but you are going to do nothing."
Mathew Long from DaimlerChrysler - "I am sorry, but it is our position."
The DaimlerChrysler recall center then gave my wife the number 1-800-992-1997 for customer service in Detroit. I have called the dealer to return the car. Luckily, the dealer had a 30 day/1,000 mile return policy. Needless to say. They are very unhappy with me and said that the report was media induced, yada, yada, yada.
Also, does anyone know whether Chrysler has any plans to make parts available to have this problem fixed. I already assume that Chrysler is not going to agree to pay for this. However, I would at least like the option of being able to get this done, even if it is at my own cost. It's one thing to tell customers "we are not going to issue a recall". While this is bad enough, it's even worse to fail to provide customers with the ability to have the problem fixed, even at their own cost.
Look in the drivers side door jam. There is a sticker there that has date it was built along with a bunch of other data.
Kathy
The issue is that by the time we load up the LXi the way we want we may as well get a Ltd.
We have a Limited and 2 kids, 2.5 and 5.5 years old, both boys. So far the suede is holding up quite nicely. We have already gotten food on the suede, but once it dries, it just scrapes right off. I have never tried to take food off while it was still fresh, because I have never seen the kids actually get food on anything. It's always some time later. There are no signs that anything ever happened, which is a relief. We got the blue interior with the boys in mind. We liked the Taupe, but thought the dirt would show up fast and be much harder to keep looking clean.
For us, when it came to decide over the LXi and the LTD, like you, there were so many options we wanted that came standard on the LTD, so we went with that. Another clincher for us, was the memory seats. Because my wife and I would both be driving it, it just made sense.
Good luck on your choice
That's funny. We passed up the blue for the taupe for just that reason. My Sebring's black interior shows dirt readily, and we were sure that dark blue would do the same. The taupe is kinda dirt color already. So far, so good (over two months, nearly 4K miles, several interstate trips).
As for LXi versus Limited, we've concluded the extra features of the Limited are worth it if you can afford it. We really like the memory seat/mirror feature in particular. The only thing we passed up was AWD. A lot of complexity, plus lower gas mileage. I never had a problem in snow with our '96 Grand Voyager.
Basically it had all the options of the Limited but the memory seats and chrome wheels. I figured that I saved about $1,400 dollars going with the LXI and forego the memory seats. I have about 10,000 miles on it and one problem (the steering fix recall). It is a very nice van.
The limited also has some minor trim difference such as heftier mats and minor trim. I felt that even though it was nice to have the extra minor stuff it was not worth $1,400. I also felt that the suede seats looked cheaper than the all leather. I was also concerned with the suede.
After having a 1985 and a 1993 Chrysler mini van which both reached over 100,000 miles with no problems I find that the Chryslers mini vans to be excellent. I have a bet going with my Dad who has a 2000 Honda Oddey van as far who will need work first. Take care of your van and it will last a long time.
Thanks for the other input too. It was funny both reasons for the covering the dirt. I like the taupe interior because of the larger feeling inside.
Hopefully we will decide soon. I am getting tired of all the options.
We just got back from a weekend-trip and we noticed some dripping on the passenger side floor.. seems to be coming from the air conditioner (we did have it running the whole time)
I thought that I had read something on here about this problem, but now I can't find it. Any one have any ideas? I would rather know the fix before taking it in.
Thanks!!
Hope this helps!
Drew
Drew
Many of our neighbors drive DC minivans ranging from a 2000 GC LE to some that are the short, original version Caravan or Voyager. NOT one has had any major problems.
HOWEVER, as with any vehicle, there is a chance of getting a lemon. Our experience has been about 50% of the ones we bought NEW have been virtually perfect and the other 50% had varying degrees of irritations. NOT one of the 19 vehicles we have owned has ever stranded us.
If you asked me about the 2001 model DC minivans, I would say I doubt most would last that long without any major mechanical issues, simply because they are the first model year vans from Chrysler after the redesign. However, I think the updated 2002 models should be even more reliable than the 2001 models. It seems every year we see fewer and fewer problems with DC minivans.
For example, if you compare the problems people had with their 1996 model DC vans to the problems people are now having with their 2001 model vans, you would see a big difference. There would most likely be a much lower rate of transmission and electrical failures in the new vans. However, you might keep in mind that electronic gadgets (power sliding doors, rear hatch) are liable to fail in ANY minivan you choose to buy, including the Honda. In short, I would trust a 2002 model DC minivan to last quite some time.
Good luck with your choice. Chrysler has an awsome minivan lineup and all of their models offer alot of great features that will really spoil you (grochery gag hooks on rear seat, adjustable cup holders, tri-zone auto a/c, powered rear liftgate, power center console, Infinity sound system, ect). In my opinion, they are worth every penny.
-Adam
I am parking my van in front of my office at a busy intersection in Florida with a 4ft. x 8ft. sign that reads 5 Star Death Trap brought to you courtesy of Daimler Chrysler! It will stay there until the vechile is recalled and repaired, I urge everyone and anyone else that can to do the same.
Chryslers lack of response to this issue is unbelievable and will come back to haunt them. They should do what they will eventually do under embaressment anyway and recall these vehicles. Based on the way they have handled this situation, I will never buy another Daimler Chrysler product, it is criminal!!!!!!!!!!!!
