The reason for this is that the cut follows along a depressed line in the dash, so the cut looks like it probably belongs there.
My Cav did develop a problem this year, though--wonder if anybody has some insight. In January, while siting at a stop light, I heard a high pitched metallic whistling sound coming from under the passenger side of the hood. It either went away when the car was going over 25mph or I just couldn't hear it because of other traffic sounds. Took it in and the service guy said he couldn't locate the source of the sound and it went away when he took the car out on the highway so it may, in his opinion, just be from driving the car in the city on a really cold day (10 degrees and no parking garage at work). Sure enough, when the weather warmed up the noise went away. Yesterday it came back after I sat in backed up traffic for 5 minutes waiting for the police to deal with somebody's fender bender. So much for the cold weather theory. Anybody know what it might be? It's seems loudest when the car idles, doesn't change when in neutral.
~ Cary
You might want to try a very small amount of "valve grind compound" on the belt. Do not use "belt conditioner" ---- for some reason, that stuff does not work as well in stopping belt noise..
~ Cary
In both cases, your compressor was putting a load on the engine -- and on that serpentine belt. (You ever tried to turn an a/c compressor by hand, without the belt attached? WOW!)
Chances are, you'll only find the belt squeaking when a load is placed on it. Just to make sure, though, you might have them check your power steering pump -- which is also belt-driven -- while they're replacing the belt.
Meade
~ Cary
Could somebody give me a hint?
Thanks for your time!
I did it this afternoon and everything went fine!
Nothing I see indicates a need to "drop the engine".
The steps are: Disconnect negative battery cable, raise vehicle, unplug fan electric connector, remove fan assembly mounting bolts, remove assembly out bottom of vehicle. Replace fan motor.
Reverse above to install. Torque mounting bolts to 53 in-lbs.
Apparently the larger Cavalier engines involve draining coolant, etc.
running in first speed. Is this a resistor design, and is it replaceable? Any help would be appreciate!
Cavalier 2000
Thanks again!
Stef
First of all, it's not my car, it's my brothers. It is a 98 (?) Chevy Cavalier. He is on vacation and left his car with me for the next two weeks so that I would have one to drive while he is gone. Before he left, he got his oil changed and the place put on his receipt that he needed his transmission fluid flushed and valve cover gasket replaced. The car ran fine for two days. One day on a quick run to the store I noticed the "CHECK GAGES" light come on. I do not know what that is (I couldn't find the manual in his car). So, I was afraid to drive it. I let is sit there for three days and someone told me they didn't think it was a problem so I decided to drive it again and run to the store. I started the car and put it in reverse, the battery light came on and the light that looks like an oil can came on too. I tried to go in reverse by pushing on the gas, but nothing, the car just rolled out of my driveway. I could barely turn the wheel. I turned it off and restarted it. When I did that, the same thing happened but I put it in drive. I did not have the parking brake on in case you are wondering. Nothing happened again. I turned it off, said a quick prayer (lol) and it started fine and I drove it back up into my driveway and parked it. I told my husband about it later this evening and he went outside to drive it around the block. It worked perfect. No disturbing lights, no stalling, no nothing. Frustrated, I decided to see for myself. I drove the car to blockbuster and back just fine, roughly 6 miles. No lights or anything. I will have this car for the next week and need to use it for appointments and such but am afraid to use it b/c I am 8 months pregnant and have a 1 year old daughter. Should I be concerned? What do you think the problem is? If I get the transmission flushed and the valve cover gasket replaced like the oil change place said, will that solve my problem? I hope someone on here can help me. Thanks. Melissa :confuse: :sick:
i am really glad that I found somebody who has had the same problem i am experiencing now. my cavalier ('02) stalls and runs like it is choking on something. It happens after a heavy rain or while driving in a heavy rain. Lately it has been happening in high humidity. I read what you posted about the intake system and the weep hole in the air box. I will have to check them out and see if it is like what you say. Have you been able to overcome the problem or have you just had to deal with it. Because I don't have a garage at my house I imagine this will always be a problem. What advice can you give??? Thanks in advance for any additional help that you could give.
Boy, did I get a surprise! When I did my first oil change, the one-gallon catch container I have always used before severely overflowed (luckily I had newspapers and a plastic sheet underneath the container).
I forgot to exactly measure what it took to refill my engine, but I would guess it must have been close to 5.0 quarts. How in the world can GM screw-up the Owner's Manual in this way (this is not a newly-introduced engine)? Has anyone here measured the exact refill quantity required for the 2.2L engine?
I will fix it this week.
stef8
I did searching came up with this post number: 1362, very good reading up on this problem.
