Last night I changed the oil and filter, installed new plugs, air filter, and replaced the leaking #1 fuel injector. (Over the last year, I had already replaced 3 of the 4 fuel injectors, due to leaking.) After all of that was complete, the engine initially did not want to start. I finally got it started, but it stuggled somewhat, and the check engine light was blinking. I rechecked my plug wires to make sure I had not mixed them up, and I'm 99% sure they are correct. I started the engine again, and it ran better, but the check engine light is now lit steady. I test drove the car, and it stalled as I was slowing down and starting a turn.
I'm going to drive it to the auto parts store to have the code checked, but I wonder if any of you have any ideas or have experienced similar performance??
KJ in Orlando
Could it be the same thing? :confuse:
However, her code no longer works. I know she has the correct one because we used the year she was born and we did it together, wrote it down, and put it in the car file.
So, took it to a chevrolet dealership who said she tried so many times it is in "super lock" and gave me some instructions to try to get some codes of the radio. They aren't working.
I'm not asking for any information on how to get the codes off the radio...but do you think I should go to another dealer? I have tried what he said several times, which involves several hours of leaving the car on in the auxiliary mode and it just isn't working.
Thank you for any advice.
Here's EVERYTHING you should need to know about them:
1. If you remove the factory radio from the car.. you will lose your factory door chimes and OnStar (if you even have it). That's it!
Removing the factory deck will NOT affect your airbags (it's a separate circuit entirely!), your DRLs (also separate), your cruise control (again, separate), your oil change light (you don't even have one!), your sex life (well, maybe)...
If anyone tells you otherwise.. THEY ARE WRONG! (Feel free to tell them this.)
2. If you WANT to keep your factory door chimes and/or OnStar... you need to either relocate the factory deck using a T-harness or replace the factory deck with a new module for the chimes and OnStar speaker.
3. If you don't give a crap about factory chimes.. you can buy a $15 harness and hook it up using that! You don't have to spend $100 or more on a T-harness and relocate the factory deck. Your airbags WILL still work.
Of course.. you'll also need a deck mounting kit.. and a GM antenna adapter.. and whatever harness you choose that you need.
Hope this helps explain it for you.
Could the overheating be caused because the relay for the fan does not work properly, therefore not turning on the fan to cool the engine, causing the car to stop or is there another reason for the overheating and for the car to stop after such a short period of time? Does this kind of overheating cause the car to stop? While it is hot, you can actually turn the car on, but when you put it in gear it stops. It will idle in park for a long period of time without stopping, but on the road and in gear it will stop when it heats up.
If it could be the relay, is there a place were I can find a schematic of the relay for my car so I can fit it myself.
If it is not the relay, what else could cause this problem with overheating and the car to stop completely when in gear?
While stoped at a light my car will idle at 600 then start to pulse and then shut off.
I have changed the plugs, wires, fuel filter, and radator.
I have also cleaned out the butter fly flap and put a thing of fuel injection clean in my tank.
And it also seems to have a brand new o2 senor in it.
If any one knows any information that would help me out please respond back you can also email me at seanfriss@franklinfirstfinancial.com
Thank You very much
Clayso.
I need this car for another year, I just graduated and can't afford a payment but don't want to keep sinking money into a car if it's not reliable. I have had it since day one, only major repairs besides normal brakes, etc. was the computer. What are common problems with the 96 cavalier? Should I expect to dump a bunch into it? Or should I just sell it? Thanks for any advice/info. you have.
I have a '98 Z24 that's been giving me problems for some time. My current problem is with jerky acceleration when accelerating hard (for example when merging into high speed traffic on a highway or freeway). The acceleration seems fine at typical lower city speeds (like accelerating from a red light, etc). It also seems to be worse in the mornings.
I didn't think it was much of an issue when it first started happening, so I left it (thinking it was maybe bad gas from the gas station I usually fill up at). Then one day on the way home from work the car basically died on the side of the road. The dealership said the ignition cassette was shot and needed to be replaced (apparently only two cylinders were firing). The catalytic converter also needed replacement as a result.
About a week after those repairs, the jerky acceleration started again. I took it to a different dealership who said the fuel filter was completely plugged and that this was the cause of the problem. It was replaced, and the car seemed to run fine for a few more weeks.
This morning, it started again! The problem is frustrating the heck out of me. I can't trust the vehicle any more, as I don't know when it might 'die' again. I'm thinking there might be a bigger problem at play here and the dealerships have just been fixing symptoms.
Any advice or help would be greatly appreciated!!
Corey
