Chevrolet Lumina
12223242628
  • coderedcodered Posts: 43
    i have a 1990 with 4 wheel disc brakes..i have brake job on the back..now the E brake will not let go all the way.. can smell brakes getting hot.. not sure what a could have done..any help would be great..thanks billy
  • lorettsloretts Posts: 21
    I am new to this forum. I am looking at a 1996 Chevy Lumina, 3.1 V6, 95,000 on the body, with a rebuilt engine of 60,000. Standard features, ABS, AC, driver and passenger airbags,, new battery, new front brakes and rotors, power door locks, manual windows. The previous owner did not keep an eye on engine coolant and blew the engine. A mechanic, (who is now the seller of this vehicle), put the new engine in, as well as the new brakes, battery. He also has done some of the service on the car, the alternator recently.
    I went over the car with my limited experience. Could not drive it on highway off the lot, no plates, but seems fine. Auto trans shifts smoothly. Engine purrs nicely. Interior is a bit beat, dirty front carpets.
    Looking under while on lift, I noticed rear suspension looks flaky rusty, as well as rear brakes drums. Should I be concerned about this? The mechanic said this is normal for a car of this age. However, the front end did not look as rusty, and the 18 year old truck that I drove over in, when I got down and looked underneath for comparison was not as rusty. The car sat for a little while till a new engine came along.
    Rest of car seems clean, except for a small paint bubble on right side lower back end of car. Car fax has no alerts.
    The mechanic wants to get $2500. I would appreciate some feedback about this car, as I have not owned a Chevy.
    hi i have a 1990 2dr with 134k on it...the 3.1 is a good motor . i get 20 to 21 mpg in city..with a/c round 18 to 19..not a lot of trouble just small stuff..if need parts try newgmparts.com...good luck sounds like a good car
  • carnovcarnov Posts: 1
    Hi, I have exactly the same problem with my lumina 3.1, 95 model.
    How did you solve the problem. Was the heater element/air conditioner to blame and if so how do I fix it?
  • fast68fast68 Posts: 6
    i am looking at a 1992 lumina Z34, it is bright red and really clean body but dirty interior than needs cleaned, but good shape otherwise, it needs a head gasket replaced but runs, what would be a fair value on something like this ? especially in a regioin where cars this age are not very common as others are- especially better ones such as the Z34 ?
    thanks for anything
    R
  • My grandson has a 1992 Lumina in my garage. the right side mirror is broken. i have a replacement. I have no idea how to find the bolts to remove mirrow. i removed the small screw but it does not allow acces to bolts. i did not want to break the plastic door panel. help me please.
    Jim
  • I have a 1993 Lumina and I was wondering if the transmission from a 1995 olds cutlass would fit because the transmission I have in my 93' is shot. Would the halfshafts be different in the 1993 than in the 95? I bought this transmission under the impression that the transmission would be completely compatable so if anyone can help I would appreciate it a lot. :confuse:
  • ipm79ipm79 Posts: 1
    Hello, I was wondering if anyone can give me the transmission output specs for a 97 Chevy Lumina (Car) with the 3100 engine. I need the specs for 1st gear, 2nd gear.....etc. Any help would be MUCH appreciated.
  • as long as they are the same model(4T60E most likely) (4 speed auto)and have the same electrical plugs then they should be interchangeable yes
    you could do a transmission search on car-part.com
    alot of the times the car year make and model is listed on the results for parts searches
    good luck
  • hello i am looking for a ASG 5.0L V8 engine for my lumina Z34. and a kick [non-permissible content removed] body kit can someone help me out.
  • Hey everyone I own a 1996 chevy lumina with about 130k miles on it she's a 3.4 V6 she ran great until I notice oil spills and if I passed 60mph, it started to shake a little. Well today I tried to take her apart to change the spark plugs, I have a shop manual and I notice oil in the around the spark plugs and a lot of it I removed the head and two of the seals for the spark plugs where a little twisted out of shape one in the front and the other in the rear where the spark plugs went I was going to remove fuel rail because I notice oil and antifreeze moisture around the area but I'm stuck I don't know what to do the manual does not really tell me anything else ??? :confuse:
  • hi there, oil around the spark plugs is normal and commonly seen, and is fine as long as its in the threads or on the porcelain part of the plug only
    sounds like an external leak, valve cover most likely
    no need to remove the heads
    if you end up finding out the engine is bad then lemme know as i have a good running 3.4L in a 92 Z34 i may sell/part out
    make offer for engine or parts
    good luck
    randy
  • for sale for 650 bucks as is or may part out or trade for a good old work truck heavier the better,
    -needs head gasket or intake gasket it was burning some water, so i parked it
    -has been parked a few months,
    -everything is fine except for the head gasket, and the front bumper top side of it is sun faded, and the GFX below it cracked,
    -and it needs the carpeting shampoo'd
    -no sterio,
    -new windshield it was replaced last year,
    -good tires,
    -factory 16" mag wheels,
    pics:
    http://img.photobucket.com/albums/v298/fast68/randys%20vehicles/Z34Lumina001.jpg-
    http://img.photobucket.com/albums/v298/fast68/randys%20vehicles/Z34Lumina002.jpg-
    http://img.photobucket.com/albums/v298/fast68/randys%20vehicles/Z34Lumina003.jpg-
    it is in central IL on I-55 exit 123 betwene springfield and bloomington
  • ttt still for sale or parts :D
  • my 96 lumina has no ele power to the starter sometimes, it will not start. It has a factory secutiry system and an after mrkt radio. please help
  • 91euro91euro Posts: 4
    I have a 1992 Lumina Euro, I may be getting ahold of the bumpers, side skirts, trunk lid, hood and liscenceplate/revers lights form a 1993 Z34, does anybody know if all of those parts are interchangeable between the two?
    I know the reverse lights and bumpers are different, but the Z34 liscenceplate holder and reverse lights should bolt into place of my original revers lights and fit because it will have the z34 bumper right?
    I dont see why the side skirts or front bumper or hood wouldnt bolt up, but it anybody has any ideas or suggestions that would be great!
    thanks!
    i have a 90 Lumina.....it has a noise that kicks in round 40mph......its not there when wheel is pulled to the right...i was told driver side wheel hub...but still not fixed .....any info would be great...thanks
  • deborahfdeborahf Posts: 15
    Hey Everyone,
    I recently purchased my Lumina. Had the oil changed. That's not the problem. After purchased (from Step-dad)I looked under the car and noticed that is had a bunch of oil underneith. It also drips a few drops after I drive it. Slow drip. When I had the oil changed I asked the mechanic if he would look at it. He says he "thinks" it may be the Valve cover gasket. How do I tell if it is that or if it is the head gasket? The car seems to be running fine and makes no unusal noises.
    Another question: I looked in the "Reserve tank"...for the antifreeze. It is extremely low and looks nasty. Planning on getting a flush. Can you tell me exactly what is done when they do this.
    I apprieciate every anwser. I am a woman and would like to go into this knowing like I know something about what is done. Thanks
  • jpfjpf Posts: 496
    Is the coolant green or red? I believe GM did not switch to Dexcool (red coolant) until 1996. Dexcool has been the subject of many complaints. I would get the flush and new coolant. If the leak problems persist (oil and coolant), I would get an oil analysis to make sure the coolant is not leaking into the oil. This would cause major engine damage. Also, GM vehicles with the 3.1 liter V6 engine tend to have a leaking intake manifold gasket. Most Lumina models used this engine. If this is the problem you need to get it fixed as soon as possible. Good luck.
    jpf....Thanks for replying. I checked the color in the reserve tank and it looks like it is supposed to be green. I rubbed between fingers and it feels pretty oily. :cry: It probably shouldn't feel that way...that's my guess. We are probably talking big bucks getting a dealer to repair...
    Deborah.
    Does anti-freeze feel oily to the touch? If I needed the intake manifold gasket replaced, should this be done before the radiator flush? Is there any other parts that would need to be replaced while repairing the above? Radiator hoses? Thermostat? Also...when checking the air-conditioner, what does that involve?
  • annalynneannalynne Posts: 1
    I need to remove the back spring system from my neighbors car. Dose anyone hava clue on how to do it, where the bolts are? What does it involve? Is it hard? Please help. :sick: The rear end of the car almost touches the ground and makes for a rough ride.
  • jpfjpf Posts: 496
    The best way to determine if oil is in the anti-freeze is to have an analysis done. If the oil and coolant are mixing you need to find the problem and have it fixed right of way. I suggested a leaking intake gasket may be your problem because this problem is common with GM's V6's. Changing the coolant without fixing the problem is just a short-term fix until the coolant got contaminated again. I would also change the hoses and thermostat. Good luck.
  • Does anti-freeze feel oily to the touch? If I needed the intake manifold gasket replaced, should this be done before the radiator flush? Is there any other parts that would need to be replaced while repairing the above? Radiator hoses? Thermostat? Also...when checking the air-conditioner, what does that involve?
    deborahf,
    when I replaced my intake manifold gasket, I had them change my thermostat as well. Only adds a couple dollars to the job.
  • peter6f2peter6f2 Posts: 1
    95 Lumina sedan.
    not able to put the transmission in Park any more.
    key cannot be removed from ignition.
    anyone know how the lockout device works and how to repair it?
  • jwtee1961jwtee1961 Posts: 4
    my buddy and I just bought a Lumina here in the uk,it went great for about 6 miles then cut out no amount of persuasion would make it start sounds like a sensor to me anybody got other ideas. p.s no bad noises or grinding or
    gnashing of teeth when she gave up the ghost p.p.s this vehicle has to get us from uk to the gambia(africa)any tips/advice?
  • mindmeldmindmeld Posts: 4
    So my wife has a 98 Chevy lumina which is up to about 210,000 miles now. Just yesterday she went to start it and all the electronics came up but it didn't start. The third try it started fine. When she was home from work where this happened I went out and tried my key with the same issue. The security light was coming on during these tests and a look in the manual pointed to a possible issue with the security system between the key and the engine.
    I've noticed some other posts on here with something similar although I am seeing people having replaced thier starters. It sounds like this is not as critical as I had originally assumed however has anyone else dealt with this and know a fix. Am I looking at just needing to clean the ignition where the keys go and then being fine. Or do I need to replace the starter or the security sensor? Thanks for the help.
    Addition to my last post,Lumina now starts but when put into drive it cuts again(do these things have "sense of humour" chip installed by chevrolet?).The only thing I can put my finger on is when she starts she is pulling about 2000rpm.Is there an inbuilt safety device to stop her taking off like a "scalded cat"?.Any help would be greatly appreciated.
    I had similar problem with a Ford here in the UK.I was told that when you insert the key the transponder tells the security system "Hi it's me", but the system is saying no its not.I know this sounds silly but the guy at the garage thought I was a retard.It boiled down to some water having got into the ECU I had to get a recon one and get it re-coded
    What was the cost on that? I think i could replace one myself easily enough but recoding sounds pricy.
Chevrolet Lumina - Page 26 — Car Forums at Edmunds.com
