Mazda MX-6 1994 4 cyl. 2 plug MT Distributor #DTR58761
and order online?
i found a new one on web
but it cost about $178.00
Thnx
:shades: Just picked up a 1993 626 ES (Chronos) with 160,000kms (100,000 miles) and want to ensure that it runs reliably for a long time. I've got a few questions for which I haven't been able to find answers using Google. The car is in great condition. The only faults I'm aware of are: cracked windshield, a few nickel sized dings, power antenna stick going down, questionable water pump, low rear pads.
:confuse: Is it possible to get computer codes in this car without a code reader? Where is the OBD connector?
:confuse: Is there anyplace to find instructions for some of the repairs on a 626 ES? The water pump is questionable on this car. If I'm going to the trouble of changing this, what else should I consider? I'm thinking that the timing belt is something to check. This car doesn't resemble a Ford Probe - Is the Haynes/Chilton book really common between these cars?
:confuse: Can anyone suggest an automatic transmission cooler? Any preferred mounting location on this car?
:sick: My power antenna grinds when coming down. Is there a "quick fix" or "lube" that I can do? It does not appear to be bent. I have disconnected the power to it to save wear on the gears. \
...any comments/suggestions/etc. are appreciated!
At 120K I will replace spark plugs (got them from sparkplugs.com), plug wires, accessory drive belts, and rear sway bar bushings. Just installed a new set of Michelin MXV tires. The car still runs and looks great at 117k miles. No other problems so far.
Thanks, D
I believe the book calls for the timing belt to be checked at 60,000 and changed at 90,000.
Take care, D
Take care, D
Also, how do I tell for sure how big the engine is? The manual documents 2 different refill capacitites based on engine size. Are there 2 sizes of 4-cylinder for 1998?
Craig
The special tool is just the filter wrench, I'm sure.
And that sound you hear when you press the brakes is normal. I noticed it too when i first bought my car. I was reading a review of the car when it was new and that sound was mentioned as one of the Cons.
Edit: You should only hear that sound when you are in Park and possibly neutral. You shouldn't hear it when you are actually braking to a stop.
I have had no trouble at all so far. It pulled a little to the left but new tires solved it. Then the Check Engine light came on from me not tightening the gas cap, and I fixed it (with the help of this forum) by disconnecting the NEG battery terminal for a bit. The fit and finish is supurb. The handling is great and the power is just fine. (170 HP) Enough considering the light weight of the car. It has all the bells and whistles of more expensive cars and so far, (touch wood) it runs perfectly with good gas mileage. (averaging about 99 cents a litre here in Vancouver right now, which is, I think ... about 3.75 a gallon ouch!)
I had an '89 323 until it sadly died and it was such a good car I felt obligated to buy another Mazda. Also, I am amazed by the Mazda paint job, it is comparable to any BMW. (I have owned 3 BMWs) I didn't get an owners' manual with the car and am curious to find out if it might have the built-in remote power locks, nothing came with it. But I THINK they came only on the ES model. Anyone know? Or if I can get the remotes for it?
130 ponies bridled to a left-leg flexor came with remote door/trunk lock. One should be able to pick up a module (ebay,junk yard) and take to a Mazda dealer
for programming. For the money spent we are thoughly satisfied with purchase. We have put 60K miles on it with just regular maintenence and last tank of fuel was 29mpg. Thanx Edmunds
I bought a 96 626 with 80k miles on it and now its at 104k. Fantastic car. My 93 had 135k miles on it and ran strong until it's death at the grill of an 18 wheeler. My next car will definately be a Mazda, but due to the fact that the late model 626s look like [non-permissible content removed], it will be a millenia.
I positively adore this car and wish I could have owned it since its 'birth'. After all these years, the interior still looks brand new. The paint has really held up and shines like you wouldn't believe.
My 93 was a DX with no options. But my 96 came with everything and it has really spoiled me something awful. When I go checking out new cars, I cant help but compare to my Mazda and I'm always dissappointed. Power antennae, gorgeous alloy rims, Lincoln-quality horn, Map lights in sunroof/moonroof controls, Trunk release on the remote...all these things I now look for in a vehicle and in my price range, they are just not there.
I love everything about the car except the 4 cylinder engine. Even the remote looks great compared to the ugly red and grey button ones they are making today.
The most impressive tho is the sound system on this car. Sounded okay with the factory tape deck; but it's amazing what a Sony Cd Player did for the 6 speaker system. The Bass is incredible for factory and no vibration or distortion. What really takes these speakers to their full potential is a set of 15" subs added along with an amp. Of course they add deep bass and a large loudness factor, but they also make the factory speakers sound so much better. There is no need to change them out for aftermarket door speakers and the car came with 2 additional speakers in the dashboard that really take the loudness like pros. Mainstream kid music like rap or Drum and Bass sound great, but instrumental, rock or new age is where is this system shines. Riding around in that car is like riding around in a portable concert or something. And the sound heard from outside doesn't sound like terrible mono like most cars you hear. It has a deep, rich stereo sound that just radiates when the doors are opened. Thank you Mazda for keeping the audiophiles in mind. Now how about paying for my noise ordinance tickets Man I love it.
I decided to tackle this problem myself and this is what I did to fix the problem:
1. Removed the EGR valve. Access to the valve is terrible on a V6. It is located in the back of the engine and there is an exhaust pipe connected to it. It is practically impossible to remove the pipe fitting at the valve (due to impossible access), so I removed the valve with a section of pipe by unbolting the pipe at the header exhaust pipe fitting. This is a 23 mm fitting so you need to get a 23 mm open end wrench because this is not a standard size wrench. The EGR valve on this car is electrically controlled (no vacuum line or vacuum diaphragm on this one), and it has an internal cooling jacket, so you must disconnect two coolant hoses going to it. Removing the valve with the exhaust line attached to it is difficult and requires a lot of patience to get it around the exhaust pipe to come out. I almost gave up on it when I decided to try one more time, twisted the EGR valve just right and the thing came out.
2. I tested the solenoid coils of the EGR valve. All checked out OK per the shop manual spec (22 ohms resistance approximately). There was very little carbon buildup on the valve itself or inside the pipe attached to it. I did not remove the pipe fitting connected to the valve as it would have been impossible to tighten it later with the valve in place.
3. I unbolted the throttle body and cleaned the two EGR exhaust passages in the intake manifold. These are located just past the throttle body on the bottom of the intake manifold throat. The holes are about 8 mm in diameter and they were completely caked with carbon. The best way to clean them is with a gun barrel cleaning brush soaked in carburetor cleaner.
4. Scraping off the old gasket from the throttle body and exhast manifold was the worst part. Took a long time with a razor blade as it was baked on to the aluminum surface.
5. I blew compressed air through the EGR valve port and it came through the two passage holes in the intake manifold.
6. Reassembled all of the components, the problem is fixed
The cost of materials: new EGR valve gasket, new throttle body gasket, carburetor cleaner, roll of paper towels, about $ 12 total. Beats replacing a $ 350 valve(plus at least $ 200 labor), especially when there was nothing wrong with the valve itself and it would not fix the problem anyway.
Suggest cleaning the EGR ports in the intake manifold about every 30K to avoid this issue. It may be possible to clean these even without ulbolting the throttle body by holding the butterfly valve fully open. Throttle body removal requires disconnecting the electrical connectors to the throttle position sensor and the IAS valve, as well as two collant hoses becuase the throttle body has an internal cooling jacket.
Also, did they still use that horrible Ford transmission behind the 4-cyls. in '01 and '02?
I would be greatful of you can post programming instructions for the keyless remote of Mazda 626. the car i have is 1997 but it think the same remote as 1996 model.
Simon
I believe that the Ford CD4E transmission was in use in both of the years you mentioned with the 4 cylinder motors. There is a Mazda designed automatic that is paired with the DOHC V6 motor.
I have an '01 626-ES-V6. It has 70K miles on it. I had to replace the radiator due to clogging, other than that it has been an excellent car. My teenage son now drives it. I would say get the V6. You can expect gas mpg of between 20 and 24 mpg depending....
I do not know if quality of 00-02 models is better. On my car the paint is of excellent quality - still shines like new, and no rust anywhere on the car..
My son picked up the car...it ran fine for one day...he drove it to work but it would not start after his shift.
Any ideas??? We are desparate.
Madmom2
The car starts for the mechanics....
Any insight would be appreciated. :confuse:
If you had a really bad transmission, typical symptoms would be slipping, hard shifting, or not shifting into higher gear, abrupt downshifting with a loud clunk, etc. or the car would start, and simply not move when put in drive or reverse.
Surely the people who replaced the trahnsmission gave you some warranty? Hire a lawyer and go after them if they refuse to fix the car.
The shifting rod end, which enters the transmission, has a rubber boot on it. Pull the boot back, clean the polished portion of the rod, and lubricate well with wheel bearing grease. Push the boot back on, making sure it latches on correctly. That's it!
Note: You need to jack up the car to access these components.
I carefully inspected my shifter linkage and could not find anything else wrong.
This question might seem almost off-topic, but I hope it's not.
My father offered me his old car, 1993 Mazda 626 with 110,000 miles.
First thing I did was have the timing belt checked....and I was told that
I would need to change the belt, because the main seal is leaking on it.....
and that I would need to change the main seal.
The car's not worth the $700.
I was thinking of converting this car to an electric car.
It just passed NYS inspection.
I saw an article on successful conversion of a 1985 Mazda 626.
The question for the forum is this:
The "donor" car has an Automatic Transmission. I need a stick.
I only need second gear and maybe reverse, no clutch pedal needed.
My regular mechanic told me I would need to replace all the linkages,
including the axles, because they are different in a stick.
My project was complicated enough.
Also, the project costs enough already. The batteries & motor are $1000 each.
I thought I would check here in case someone has a secret insight.
I have a friend who is a fly-by-night mechanic...didn't get to talk to him yet.
SR in North Jersey
PS transmission issue aside, do you think I would be able
to find someone willing to take the engine, exhaust system, radiator, etc.
for free? (i.e., they get the parts I don't need :-)
Or are the parts simply not worth the effort?
Or is it worth it to pay a mechanic I trust? (Ch-Ching, Ch-ching :-)
Anyone want to trade an automatic for a stick ?
We had a similar problem with our Nissan SUV (I know different car). But, it too would cut out intermittently , stranding us places. And like you the mechanics we took it to could not get it to "not" start and so couldn't ever diagnose the problem. Yes they suggested many things and replaced many things and nothing helped. Finally we discovered that it was the "starter". Also might be your ignition switch (I think that's what it's called - it's where you put the key in to start the car).
The down side is that we now have two keys for our car (one for ignition and the other for doors, etc.). The up side is that it's fairly inexpensive and our car ran great after we had both replaced!
Hope this helps.
P.S. Make those morons that misdiagnosed your car pay for all of this!!! Our mechanic did!
Thanks! :confuse:
If not, or you can't find it, you have to remove the lower hose (because removing the upper hose will only allow the radiator to drain until it gets below that hose's level). Just pull the lower hose off the radiator side and leave it attached to the engine.
Please let me know if you find an answer to this problem. I may try to replace the starter and the ignition like the other post says if nothing else.
Matt
Anyone know about cleaning fuel injectors??? 99' 626
Thanks! :sick:
Hope this helps!!!
"Can anyone suggest an automatic transmission cooler? Any preferred mounting location on this car?"
For an automatic, a transmission cooler kit would be a very big benefit. The one most commonly used is the Hayden 404, and can be purchased for ~$40 at your local Pep Boys. I've heard they're pretty easy to install.
"My power antenna grinds when coming down. Is there a "quick fix" or "lube" that I can do? It does not appear to be bent. I have disconnected the power to it to save wear on the gears."
Definitely grease that puppy. That's the way they come from the factory. Again, do research to find out which lube is best.
I guess it hasn't been long enough to know if the car is going to give us anymore trouble starting, but it seems good for now.
Hope you get that 626 fixed "Mad Mom" and thanks for the help madcrasher.
Advice: When your electric cooling fan quits running, disconnect the fan motor connector and then apply 12V battery power directly to the connector terminals by using two leads with alligator clips. If the motor is good, the fan wil run. Then your problem is probably the fan rellay. Each fan has its own relay and they are located in the engine compartment.
Also, I've read the keyless entry remote posts on the message board and I'm very excited. The dealer told me he would order the remotes for me, but again, he conveniently could not. I have looked at a couple on ebay. Should I spring extra for a Mazda 626 remote or just buy a standard remote?
Thanks very much in advance!
