Honda Civic vs. Hyundai Elantra
Sure they may sell 100,000 Elantras this year but the Civic still sells 3 times that not to mention all of the used Civics that are sold in a year, and with a new model on the way it's sales will increase even more.
As I said, I may view Hyundai differently in a few years but right now I think the Accord/Civic are 2 of the best, most reliable sedans in their respective categories. Maybe the next generation of car buyers will not attach the same stigma to the Hyundai name and Hyundai will be regarded as more reliable than Honda, who knows? But by the time that happens my walker will be a little hard to navigate around the lot so I doubt I'll be selling them.
Yes, I would hope so considering it would have cost you more. So in the end it evens out.
"CR's recommended
small car, the Mazda Protege, sells (according to
CR) for $17,000 - half again as much as an Elantra,
double an Accent."
The Protege is an excellent car, but with that price it is hard to justify. The Protege is not 4 to $5,000 dollars better than the Elantra!
The Accent has been out since 1995.
The newly designed Elantra has been out since 1995.
The Sonata has had different model changes, each step with vast improvements, since 1989.
Yet, all the Hyundai models have "insufficient data".
Even still, Consumer Reports only do "predictable reliability rating".
Thus Consumer Reports is not a good source to find reliability data on Hyundais or any other models for that matter.
J.D Powers which put Hyundai ahead of Mitsubishi, and in the territory of Chrysler and GM, maybe a better indication of reliability. But they only measure initial quality. Toyota Corolla tops out the economy class in initial quality, but as Car Point's reliabilty rating link shows, Toyota's quality becomes worse and worse as the cars age, which JD Powers does not measure. That's why you saw millions of Toyota Corollas 5 years ago. But today you only see the new Corollas while the ones built and bought 5 years ago have mysteriously disappeared (probably languishing in nation's many autoshops).
Make:Honda
Model:Civic
NHTSA CAMPAIGN ID Number: 94V063000
Potential Number of Units Affected: 191289
Year of Recall: '94
Summary:
A retaining clip that connects the transmission
shift cable to the shift lever actuating rod can
have insufficient retention pressure and may
eventually come off after repeated shift lever
operation. If this happens, the position of the
shift lever may not match the actual transmission
gear position.
This could result in unanticipated vehicle
movement and accident.
SYSTEM: POWERTRAIN; TRANSMISSION; AUTOMATIC.
Year: 1994
Make: Honda
Model: Civic
NHTSA CAMPAIGN ID Number: 93V208000
Potential Number of Units Affected: 31
Year of Recall: '93
Summary:
The passenger-side air bag modules contain
incorrect inflators which are out of spec.
for the passenger side air bag.
In the event of a collision, the air bag may not
provide adequate protection to the passenger.
SYSTEM: INTERIOR SYSTEMS; PASSIVE RESTRAINTS; AIR BAG; PASSENGER.
Year: 1996
Make: Honda
Model: Civic
NHTSA CAMPAIGN ID Number: 96V106000
Potential Number of Units Affected: 160689
Year of Recall: '96
Summary:
A soapy lubricant was used to insert the check
valve into the vacuum hose which causes the brake
booster check valve to stick.
This condition can cause a loss of the brake's
power assist resulting in a reduction in braking
performance increasing the potential for a vehicle accident.
SYSTEM: BRAKES; HYDRAULIC; POWER ASSIST; CHECK VALVE.
Year: 1996
Make: Honda
Model: Civic
NHTSA CAMPAIGN ID Number: 99E015000
Potential Number of Units Affected: 935167
Year of Recall: '99
Summary:
Equipment Description: Accessory driver-side floor mats used in 1996-1998 Honda Civic vehicles.
Due to the shape of the floor on these vehicles, a mispositioned floor mat could interfere with the accelerator pedal.
The floor mat could prevent the accelerator pedal from returning to the idle position.
Year: 1996
Make: Honda
Model: Civic
NHTSA CAMPAIGN ID Number: 99I002000
Year of Recall: '99
Summary:
The accelerator pedal feels rough or notchy when you press it.
It may feel like the car is not responding properly when traveling at low speeds and are required to move the accelerator pedal to make slight speed adjustments.
Year: 1997
Make: Honda
Model: Civic
NHTSA CAMPAIGN ID Number: 97V193000
Potential Number of Units Affected: 9558
Year of Recall: '97
Summary:
The front passenger air bag modules have been improperly assembled. The cloth flaps covering the folded air bag may have been tucked in too far.
This condition could prevent proper deployment of the air bag. In a crash, an improper air bag deployment could increase the risk of injury to a front seat passenger.
I think you will find ALL manufactures have similar recalls. My 1992 Oldsmobile was recalled because the power seat wiring "can" slip out of place and "could" start a fire or something.
Being a busy person, I looked under the seat, the wiring looked fine and was still fine when I sold the car two years later.
And...horrors! My 1998 Civic EX Coupe was recalled because the driver's floot mat "could" slip forward and cause the gas pedal to stick!!
Well...my floormat does not slip, and I've been too lazy to remember to have the dumb pin installed...maybe someday...yawn...
True, some recalls could involve potentially dangerous situations but most are pretty friviolous. They affect ALL makes and models!
Has Elanta ever been recalled for poor design of
retaining clip in transmission? No.
Has Elantra ever been recalled for defective air
bag? No.
Has Elantra ever been recalled for careless assembly of brake system? No.
Has Elantra ever been recalled for poor design of cabin floor? No.
Has Elantra ever been recalled for defective throttle cable? No.
My 97 in fact had the "factory accessory floor mat could move forward causing gas petal to stick" recall. I didn't have the accessory floor mat.
I thought it was a joke to "recall" a floor mat.
My car has almost 77,000 miles with zero problem from the day it was driven off the lot. $0.00 in warranty claims charged to Honda and $0.00 in unscheduled maintence. Claiming an Elantra or an Escort or a Metro is equivalent to a Civic will not work unless you are talking to yourselves.
But, given enough time, I assure you that they WILL have recalls, so don't get too cocky when posting details of recalls of other makes.
And...most will be frivolous, no doubt, just like the dumb floor mat recall.
I have had 5 or 6 Hondas and they have all been perfect. The 2 people I know with Hyundai's have had myriad of problems and swear they will never buy another one. So again I ask you to show anything that shows the Hyundai is significantly mroe reliable the the Civic.
I guess now we are supposted to wring our hands and run from Hondas like rats from a sinking ship?
Does it occur to you that these examples are meaningless? A car having a "recall" problem and a car malfunctioning in the light of no information about the maintence history are not the same issue. As you know, you can not do things to a car-- which will mess it up and you can do things to a car which will mess it up. The statement I am reading on my screen right now: "...this is common on all civics" is wrong.
You don't judge quality and reliabilty of any car by random owner statements going back to 92.
It would be more helpful to take the consumer complaints of the most recent year and years in a current generation and find out if there are problems that are recurring and not statistically anamolous. www.nhtsa.dot.gov
Korean automaking is not at the level of quality and refinement of Japan if you are talking about Japan's best companies Toyota and Honda. If saving $3,000. makes the car a better value than it is a better value. You'll pay the $3,000 down the road because between 75,000 and 150,000 the difference in quality will become obvious. In truth you'll probably find out the difference long before that. I'm not trying to disparge Hyundai.
My point is that you get a discount economy car for the discount price. Honda has made the Civic since before the famous 1973 Civic CVCC engine, they are leading with ULEV technology, and have the first commerically avail. hybred. www.insightman.com What makes you think Honda is not better at making economy cars than Hyundai.
Warped brake rotors? These are usually caused by hard driving or overtorque on the lug nuts.
And the other "problems" Well...how many miles did these horrible cars have on them? Usage, care?
Give us a break! I wonder how many Hyundai stories of woe a person with time on their hands could drag up?
All cars need repair sooner or later! some just need repairs more often...like Korean cars!
www.jdpower.com
Does this help?
Make: HONDA
Model: CIVIC
Year: 2000
Date of Failure: Sunday, December 12, 1999
Incident: No
Fire: Yes
Number of Injuries: 0
Component: ELECTRICAL SYSTEM:IGNITION:SWITCH
Summary: WHEN THE CAR WAS 2 WEEKS OLD, WE RETURNED FROM A DRIVE AND FOUND THE CAR WOULD NOT SHUT OFF, EVEN WITH THE IGNITION IN THE "OFF" POSITION AND THE KEY REMOVED.
Please do quote the part about the fire.
I don't see it.
Here's an Accord owner who says most recalls
ordered by NHTSA are "pretty frivolous."
Suppose this gentleman gets a JD Power survey form in the mail.
What are the chances of this man, who attributes the warped rotor on Civic to "hard driving" and lied to us on the Honda distributor problem,
answering to the questionnaire correctly and honestly?
Another thing, earlier we've looked at Carpoint's link which clearly showed Hyundai Elantra/Sonata as very reliable over the years. You are all probably mistaking Ponies/Excels/Stellars which have all been out of production for years, with Hyundai cars. I suggest you all keep up to date,
we're not in the 80's anymore.
So your assertions that Hyundai is "worst in its class" is certainly false, and at worst, complete lies.
JD Power long term dependibility does not measure initial quality. They do have an inital quality survey also. www.jdpower.com
The most recent study is 99. Car has to be 5 years old. Toyota's Lexus has won for five years running. In fact Hyundai sold cars in 94. I looked it up. Hyundai is not worst in its class.
Kia is worst in its class. I think Hyundai bought Kia. Kia is the worst car being sold in the US
because we don't have the Yugo anymore.
I guess I'm not going to hear about the fire.
Brake rotors are warped by overheating, or by over tightening the lug nuts. Any mechanic will tell you that.
I "lied" about distributor problems on Hondas?
I'm done with you!
Enjoy your Huyndai!
Boy, I wish I would have kept those numbers that convinced me that Hyundia is no joke any longer. All I remember is their sales have double, customer satisfaction has skyrocketed. Honda is surviving on one thing alone, its reputation. What happens when people start to realize they don't have to pay the extra 3K for reliability?
i bought a 99 Elantra Sedan in which i was involved with a headon collision at 50 mph. i did not have a scratch on me. I think Hyundais are excellent cars. Between my parents and my brother and i, we have owned 10 since they have been brought to the US. We all whole heartedly recommend them to anyone.
After the accident i bought a Kia Sephia to replace the Elantra. what a horrendous car. The brakes shudder like crazy, the passenger side window has extreme trouble going up all the way, and its only getting around 22mpg on the highway.
I am shopping around for a Civic to replace the Sephia. I think that the Hyundai Elantra and the Honda Civic are two of the best small cars out there.
It's insulting, isn't it? And isn't it more objective, in spite of how the different owners of cars might feel, to think that Hyundai sells at $3,000 less for objective reasons, not because Honda and Toyota buyers lack judgement?
Honda is leading with engine technology, ULEV, VTEC, Insight (www.insightman.com). You think the quaility, the efficiency, the long term durability of the Civic engine and the rest of the car are not better? Sometimes you get what you pay for.
I don't know what a better value is for someone else but what I know is that there is a huge difference between a car running to 80,000 miles with oil changes and having a car that falls apart or fails. Hyundai may have improved its reliablity but it still isn't famous for it. At any rate, shoppers should also consider that for not much more money (or less) you can get the lowest trim level Civic ($9,999), or a Toyota Corolla or Echo.
If you take the base Civic or Corolla and add air conditioning, then consider that you pay invoice + a %, not MSRP they might not be as expensive as you think. I don't think Hyundai is any kind of joke.
"according to www.nhtsa.gov, complaints filed to
the nhtsa for 1999 are as follows: Toyota
Camry-117, Honda Accord 83, Mitsu Galant 26, Kia
Sephia 158, Hyundai Sonata 5, DAEWOO LEGANZA 1. For 2000, so far; Accord 25, Camry 12, Galant 2,Sephia 12, Sonata 2, and DAEWOO LEGANZA 0."
Since Hyundai is so unreliable, they've had 5, complaints to nhtsa for all of last year. Of course you'll say there are more Hondas on the road, but look at how many Kia's are on the road and see how many problems they have. Shouldn't Hyundai be like a Kia at least if some of you guy's theories about Hyundai being unreliable is true? Thankfully for Kia, Hyundai bought them out recently.
The #1 selling car in 1999 was Camry. The number approaches 500,000. The number # 2 selling car was Accord. I haven't said Hyundai is not more reliable than Kia.
reported. Look at the ratio and tell me Hyundai is
not reliable.
I remember Vince8's link which stated something to the effect that after one year the number of Hyundai vehicles with problems were only a few percentage points higher than Honda's.
Cars selling at high volume have a high number of NHTSA complaints. Cars selling at a low volume have a low number. It proves nothing. Kia's numbers are incredibly high because Kia is the problem child of the auto industry. Kia is owned by Hyundai (doesn't inspire confidence to me).
You haven't proven that Hyundai is as reliable as Honda. Why do you want to think a Hyundai is as well made as a Civic which is easily one of the two best cars in its class the other being Corolla. You got a discount car for a discount price so be happy the price was fair.
You said it. I got a discount(and very good)car at a discount price. I just want to let others know that they do not need to pay premium price for a discount car (Civic).
The entire world including Mercedes Benz
is involved with price points for parts suppliers and Hyundai can magically make the same car for less money? Or Honda is a total scam on the public?
Why do need to trash Civics to feel good about yourself? Forget Civic. Compare Hyundai to Kia if you want to feel good.
yourself? Forget Civic".
I think this question must be answered by the Honda supporters as well, except switch the word Civic with Elantra. If I remember correctly it was a Honda owner who first said Hyundai's are trash because they are unreliable which Hyundai supporters with links and figures, are saying that is not true. I haven't seen anyone trashing the Civic.
because I like cars and I like all cars.
I was reading Kia posts and and I found
one that said "KIA, Kind, Industrious, Automobile"
Here were 1 in 3 posts saying it stranded me 4 times in 2000 miles and it's the biggest piece of junk in the world! and still someone had kind, temperate, loving words for the car.
All I'm saying is the cars in this topic are at different price points and really isn't because anyone is stupid or anyone is getting scamed.
70k and 80k and $0.00 warranty repairs charged to Honda and $0.00 unscheduled maint.
The check transmission light came on. I had spilled soda into the shift assembly.
The wiper motor broke a few weeks ago. I had
turned it on with snow and ice covering the blades.
There was a recall. It was a floor-mat that was getting stuck on gas petals. I didn't have the floor-mat and so it didn't apply to my car.
The car is 100%. It shows every sign of going to 150k with oil changes and the scheduled timing built.
It was worth it to me to pay for it. I got what I paid for.
The Koreans are industrious but they have not achieved what Japan has yet. In the case of Honda and economy cars ULEV engine develpment proves
Honda's engineering superiority. Build quality is higher because of price points for suppliers is nothing else. You can't sell a car at the bottom of the market and put the same material quality in it. Honda Accord is having a huge reliablity/ reputation crisis (Edmunds Accord Topic, NHTSA
leading complaints see above). When the same happens to Civic then you can call it a rip-off.
In the US:
Kia is a joke (I like it but it is a joke)
Hyundai has stabalized its reliablity
Daewoo is unproven.
same or near same reliability and quality as a
Honda, as you have talked about, but for thousands
less? If you take the early Hyundais like the
Pony/Stellar/Excels of the 1980's out of the equation, Hyundai has actually has been good reliable cars. The numbers of repairs indicate that which we have already seen. Even my local
newspaper did a nice article on the 1995 Accent
which was praised for its near Honda-like reliability minus some refinement, but for thousands less. Major complaints with this car has been far and few in between, except for few niggly little problems, according to the newspaper.
I dare you to go over to the Sonata vs Camry vs Accord page, and start reading from post #7.
This person did a heck of a job comparing OBJECTIVELY, the cars involved. And guess what,
a Hyundai came out on top, tied with Toyota.
You say Hyundai isn't there yet. But I say they are already there just in terms of quality and reliability. How much more do you really want from Hyundai before you give in and give some credit where credit is due?
Useless for everyday driving. Noisy.
ULEV: 2000 Civics are not ULEVs.
Anything else?
>blades.
Here we go again. Faulting the driver.
Remember the posts on the warped rotor? What did the Hondaman say about the cause?
In this case,
Something is wrong with the motor and/or related
components.
If there's a overcurrent, the fuse protecting
the wiper motor circuitry will blow before
the damage is done to the motor.
answering survey questionaires correctly and truthfully?
Most people are too smart to fall for such rubbish!
The 2000 Civic HB replaced a 1990 Civic HB with over 230,000 miles. I spent very little on repairs; in the last 80,000 miles or so, I spent amazingly little on maintenance.
In other words, that car saved me thousands and thousands of dollars. So we bought another. Was it overpriced? I won't know for ten years or 200,000 miles.
For me, reliability means going 10 years/200,000+ miles with relatively few problems. While Hyundai has apparently improved significantly, I don't think you can say Hyundai is there with Honda until the newer and better cars are still performing well after ten years.
It is interesting that Honda is dropping the HB's for the new model. I think this means the entry level Honda will be even pricier, conceding the low priced car market to Hyundai etal?
Finally, I am in the engineering/construction business. For the construction of pressure vessels, the Koreans are bidding at half the price of the American shops. We have some in their shops, From what I here, it is going well so far.
In the six years I had my Honda, I went through three head gaskets. Honda replaced the first one at 35K miles. The car chronically would run hot and every dealership indicated that they could not duplicate the problem. Buy a quality car.
