Pontiac Grand Prix - 2000-2005
11213151718145
  • toon1toon1 Posts: 19
    Thanks for the info. I drive 60 miles each way to work everyday on fairly even terrain here in VA. I do tend to "keep ahead of the flow" with regard to speed. Believe it or not, I filled up yesterday with 89 octane and, based on my computer, I jumped up almost 2 mpg. All of the numbers I've used are computer based.
    The specs. say it is an 18 gallon tank, but I find that hard to believe as everytime I fill up, I am on "E" and the low light has been of for 30-40 miles. But, I usually only get a little over 15 gallons in the tank. What do 'ya think?
  • tsjaytsjay Posts: 4,591
    I have noticed the same thing with mine. You get plenty of warning before you run out of gas, but I wish they had made it more realistic. Some day a guy might count on all those extra miles and end up running out of gas.
    I always re-set my trip odometer when I fill up, and knowing the approximate miles per gallon I can count on, I know pretty well how far I can push a tank of gas. Of course, there's that mileage computer that will tell you how many miles you have left, but I don't trust that thing as much as the manual calculation.
    As far as the 89 octane thing, keep me posted as to whether you really get better mileage. You would have to go through a few tanks to be sure that the apparent improvement is real. It could be some other factor if you just see it on one tank. Everything I've ever read on the subject says that you are no better off with the 89 octance if your car is designed for 87, but the "experts" don't always have everything right.
    I think you might be better off doing manual gas mileage calculations rather than depending on the computer in the car. Some of my very best gas mileage figures from manual calculations were higher than what the computer was showing. I don't know how the computer is programmed, but it may put more weight on the most recent miles rather than give a true average for the whole interval since the last re-set. Sometimes it is almost on the money with the manual calculation, and sometimes it's off by a mile or two per gallon.
    tsjay
  • yurakmyurakm Posts: 1,345
    The gauge shows an empty tank when about 4 gallons left not only with GP, but also with my Chevy Malibu. And I had read the same complaints on the Ford boards.
    I have read somewhere, that the modern cars need to have at least a couple gallons in the tank. Allegely, the fuel pump require it for cooling or lubrication or somewhat; otherwise it can fail or wear early...
    By the way, it makes a good sense to refuel often, at least in our places. You never know when and where the traffic will be jammed in CT. It happened with me to get into a jam about 0:30am, in a relatively quiet place, when entered I-91 from I-84. There is no uncertainty only with the I-95: the jams are granted here.
    And the gas runs out very fast in the jams.
    My salesman told me when I bought the car that you could expect about 40 miles left when the light comes on. It will begin to blink when you're just about out.(yea I know it blinks when it comes on). Of course, I called him about another matter Monday and the sales manager told me that he was no longer with them, because of all things... he couldn't tell the truth!!
  • I am thinking about getting another Grand Prix. My 1996 has been a good car but it is beginning to leak oil around the valve covers and my oil pump is about to go to. I was wondering if anything new is going to come out on the 2001 Grand Prix.
  • sunfgtsunfgt Posts: 40
    I also find my gas gauge to be "faulty", even after it was fixed. It appears that the gauge has a fudge factor built into it to persuade you to refuel before things start getting dangerous. I've noticed that my level drops really fast at first, but in the last 1/4, it moves down very slowly. I'm guessing that most people would refuel once it hits 1/4 or lower, but I think there's more like 3/8 still left, so there's a safety margin of 1/8. I wouldn't try to find that margin though, not unless you've got a gas container in your trunk
    If you can't persuade your wife, I'd say keep the 300M. It'll do eveything the GTP does, except that it is a bit slower. Also, since your uncle decided to give it to you, I think he'd want you to drive it.
  • ruskiruski Posts: 1,566
    300M is not slower. It is just not as quick from 0 to 60mph.
    republican - 2001 Grand Prix is alrefy being sold. Check the Poniac web site for what's new.
  • That Lumina SS is nice....
    Why isn't it here?
    Blame the SUV people....GM is going where the money is being made.
    That was what I meant. 300M feels fast, but I'm sure it doesn't compare with the GTP on launch. I'm sure 300M has a higher top speed anyhow, especially with the removal of the speed limiter with your PHP package.
    Don't they realize that there's a lot of money to be made in the sports sedan field? I've never seen an ad for GTP, by GM or by a dealership. That means that GTP sells too well for GM to waste their advertising money on it. I have seen GT ads, but the GTP is a complete bargain for only over 1K more, so I can see that people would spend a little more and add the P, leaving behind a lot of GTs.
    actually the top speed of 300M is pretty much the same as the top speed of GTP without the speed limiter.
  • graphicguygraphicguy SW OhioPosts: 8,840
    kazz--up're right...we're car people. And, as such, we like to look at performance capabilities as well as how the car looks/feels/drives. My wife looks only at how the car rides and how many "doo-dads" the car has. She would be happy with a 100hp, 4banger in the Avalon as long as it "floated" over bumps. The wife has a '99 Avalon. A lot of her love for it has to do with the fact that it's the first car she bought herself without me "tagging along" to help her buy it (at her request). She picked it out, negotiated the deal. This sounds sexist, but in all the years we've been together(going on 15 years), she always asked me to help her pick out a car and help with negotiations. She did the Avalon on her own and has a sense of pride in it. She's had some re-occuring brake problems with it, but loves it all the same.
    ruski--my wife looked at a Park Ave. (really wanted a Riv, but they didn't make'em anymore). The one she wanted was $35K. We have a rule in our home...."no cars that cost over $30K" (used to be over $20K, then $25K). We can afford more expensive cars, but believe that past the $30K mark, diminishing returns kick in.
    sunfgt--the GTP is faster off the line than the 300M. 300M has a great, smooth kick at highway speeds. It puts power to the pavement in a much smoother fashion. Top end on both is pretty comparable (but who ever goes over 110 MPH anyway in this country).
    I've decided to sell my beloved GTP and keep the 300M. This is as much for emotional reasons as anything else. I don't think I'll be disappointed with the 300M. I've only driven the GTP once since inheriting the 300M. I'm surpirsed at the thoughtfullness of some of the features I'm finding with the 300M (stereo controls on the back of the sterring wheel instead of cluttering up the front...why didn't someone think of that before).
    I'll miss the way the GTP gets up and hauls with little provocation. I'll miss the HUD. Stereo is better in the 300M. 300M is beautiful both inside and out. My 300M had a little sticker on the door that said the quality control people had pulled mine off the line to test it, making certain it was screwed together correctly (and it is).
    Thanks to all for the advice. I'm selling my 2K GTP (with 1SC, Bose, hi-po wheels and all zaino'd up). It has 34K miles (I drive a lot). Put a "for sale" sign in it yesterday and put an ad in the local paper that ran this a.m. Asking $21K (will take $20K). Already have 3 people slated to come take a look at it today. It's a great car that someone will get a good deal on. I'll hate to see it go.
    so where do you live?
    Toon:
    Have you tried actually calculating your mileage and comparing that figure with your onboard computer gas mileage? If you do this for a few consecutive tanks, then I think you will really know what your mileage is.
    I forgot to mention in my earlier posts that I use Mobil 1 full synthetic oil in my GT, and I honestly believe this helps my mileage by a mile to the gallon or maybe a little more. I used regular oil for the first 5K miles (changed it once about 2000 or so and put regular oil back in it that time), then at 5000 I had Mobil 1 put in it. I have been using 5000 mile oil change intervals with the Mobil 1, since almost all of my miles are highway miles.
    I started using Mobil 1 on my '94 Z28 Camaro, and I KNOW it helped my gas mileage on that car, since I had been checking it on each fill-up. It also gave me a quieter cold start on that car.
    tsjay
    Recently my wife and I have bought a Regal GS. Basically the same engine as in your GP GT. Will change oil for the first time soon, probably tomorrow, at about 2k. The next time, at 5k, we plan to switch to Mobil-1.
    May I ask you, please, what grade of Mobil-1 do you use? 5w-30 or 10w-30?
    Hi Yurakm.
    I use the 10W-30 Mobil 1. Look at your owners manual and go with whichever viscosity oil it recommends for the expected temperature range where you live. In my case, living in Ky., the temperature range my car will see fits the 10W-30 category. I suppose a guy could switch to 5W-30 in the winter months, but I don't know yet if I will do that or not. I would definitely do what the owners manual recommends.
    In the Grand Prix owners manual it says that 10W-30 is recommended unless the car will see temperatures below 0 degrees F. It hardly ever gets below zero here. The owners manual also indicates that 5W-30 is not recommended above 60 degrees F. According to that, I could use 5W-30 during the coldest part of the year around here, so maybe that's what I'll do next time I have it changed (I'm due in 2000 more miles, which for me is only about a month's driving).
    tsjay
    Yurakm:
    I just looked at your profile and saw that you live in Connecticut. I suppose that means you will see lots of temperatures in the single digits and even below zero. You might want to consider getting a block heater for your car.
    I think you can hook it up to a timer so that it will start heating your engine coolant for you an hour or two before you start the car. Your car would then warm up immediately, avoiding a lot of engine wear (I have heard that 80% of all engine wear occurs during cold starts until the engine gets up to normal temperature.), and your heater would work as soon as you get in the car.
    At any rate, I think your owners manual will tell you that 5W-30 is what you need for the winter months where you live.
    By the way, congratulations on that new GS. Those babies are nice!
    Hope this helps
    tsjay
    We live in OH. Sold the GTP yesterday to the first person who showed up. There was actually two people who showed up to look at the car at the same time. One person saw the "for sale" sign in the GTP window, the other responded to the newspaper ad.
    I told both that I was asking $21K. Both drove the car and wanted it (see what a good Zaino job will do to sell a car). I had it spotless...newly washed with a Z6 wipe down.
    Both asked what I would take for the car. To be fair, I told both that they could put their bid in an envelope and I would accept the best bid. I opened both bids with everyone present. All agreed that was fair. 2nd guy bid $19.7K. First guy to show up bid $20K even (which is what I wanted). 1st guy took it. He gave me $500 in cash, went to the bank. Came back with a cashier's check for the rest. We went to the notary...got the title transfered and he went on away happy. If there wasn't such great deals going on with new GTPs, I probably could have gotten a grand more.
    A 3rd person showed up in the early evening...told him it was sold.
    Still will miss the GTP...great car!
    Thank you so much for your congratulations, and for suggestions!
    My car manual also recommends switching to 5w-30 for the temperature below 60F, and not to use 10w-30 when it is below zero. In the 0-60F range, the both grades are OK for the 3,8l GM engine.
    Then enters the New England climate. At summer, the 10w-30 is no brainer. But, with the Connecticut winter, it is impossible to predict, if there will be several days above 60 or several nights below zero. Even while, most probably, 95 percent of time the temperature will be in the 0-60F range, where the both 10w-30 and 5w-30 are OK.
    This is one of reasons why I tried to break-in the engine while it is still warm outside. I put 2k miles in three weeks. Almost all with the longer weekend trips, including one to the Niagara Falls.
    The winter is the main reason, why I want to switch to the synthetic oil. I also planned to change oil for the first time after 2k, and go to synthetic after 5k. But, with the winter pending, I started to think about switching to Mobil 1 even sooner, with the first oil change.
    My car is not equipped with the engine block heater. I believe, the heaters are very unusual in CT: they are probably available for the build-to-order cars only. The winter is generally mild here, not like Maine, or Minnesota, or Canada, or Russia.
    Any case, we are renting an apartment, in a 6-building complex. Almost 500 apartments here, with even more cars on the lots (mostly two-car families). Would be impossible to connect the engine heater(s) to electricity.
    Hello again, yurakm
    I think the 5W-30 will be your proper oil for the winter. You may have a few days (VERY FEW,probably) during the winter months when it will get close to 60 degrees, right? I'm sure a little driving when the temperature is in the sixties with 5W-30 won't hurt anything. Remember, it's when the engine is below normal temperature that most of your wear will occur, and that's where the 5W-30 will help you in the winter.
    I don't know what kind of neighborhood surrounds your apartment complex, but if there is a residential neighborhood nearby, you might find someone with a garage that they would rent you. Then you could buy an aftermarket heater of some kind. Parking in a private garage would probably save you some knicks and dings on your car also from stupid people who throw their car doors open against the car parked next to them.
    tsjay
  • I think you are being to extreme recommending a block heater for someone living in CT. If they lived in Maine or North Dakota, then you would have a point.
    CT just doesn't get that kind of extreme cold. When I talk extreme, I am talking about winter temps that dip below zero on a regular basis.
    You could probably count the # of times that happens in CT on your hand each winter.
    I think engine wear isn't a major factor when it comes to the 3800. The 3800 is probably the most reliable-under-abuse component of the GP. I don't hear to many stories of cars dying because of the 3800...even when they are poorly maintained.
    I guess CT winters are not as severe as I thought.
    I have never been there, but I had a mental image of a very cold winter season.
    A block heater still might not be a bad idea, if for no other reason than quicker heat from the heater for the comfort of the driver and passengers and a quicker defrost of the windows. It would be up to the individual to decide if it's worth the trouble. I probably wouldn't do it myself, since I have a garage and don't have to worry about icy or frosty windows in the mornings.
    Later, greywolf
    tsjay
    You're awful quiet lately. Can't you stay out of that GT long enough to tell us how you are liking it now that you've had it a few days?
    Let us hear from you!
    tsjay
    I agree with greywolf:
    Probably about a million cars are in use in our state, year round, and nobody even mentions the heaters. I think that, would they be really useful in CT, the dealers would sell them. And many families would not buy the cars without heaters.
    I live in CT for five years and did not saw a single advertisement of an aftermarket heater. Not like alarms, stereo subwoofers, etc. No demand.
    The oil change businesses do not offer 5w-30 oil in our town, only 10w-30, year round. Most simply have no other oil: "bring your own and we will gladly put it in".
    Looks like I am just became too much excited with the new toy.
    Yurakm:
    If you are going to use Mobil 1 oil, you will be much better off buying it yourself at a Walmart or some other discount store rather than buying it at an oil change facility.
    Those oil change businesses charge MUCH more for Mobil 1 than what you can buy it for yourself. You can get it at Walmarts around here in Ky. for about $4.25 per quart. You can still have the oil change business change your oil- just take your own oil with you, and they will knock something off their price for the oil change, since you brought your own oil (they won't knock off much, though)
    I still think you would be ok using 5W-30 in the winter months, but it may not make all that much difference. It depends on your weather, of course. I think even in a normal winter you are closer to the 5W-30 temperature range than the 10W-30 temperature range.
    Like I said, I would go with the owners manual recommendations.
    tsjay
  • hengheng Posts: 411
    are not as severe as in upstate NY. I run 10W-30 (non-synthetic) all year round. No problem.
    Then you don't have to change oil when the weather changes.
    Thanks for following up. You were correct, the octane thing was a fluke. When I posted last, I had just filled up with the higher octane and checked it on my way home from work. At that time, the computer was showing 27.8. By the end of the tank, I was back to 25. something. I haven't tried the manual calculation yet.
    The car had about 3,500 miles on it as a demo when I bought it. I wonder if the salesman driving it "broke it in" properly and if that would have something to do with it. The tire pressure is okay and I had it aligned right after I bought it because it was pulling to the left. So, I am still getting about 25.5 mpg according to the computer. I know I am getting less than 400 miles per tank, so depending on the tank size, that's about right. I'll keep watching it and let you know.!!
  • wkawka Posts: 14
    I'm looking at buying a new 2001 Grand Prix GTP. I think I'll like the super charger even though I'll have to burn premium. So far I really like the value of the Grand Prix and feel like I'm getting a lot for my money. Good safety specs, nice feel, interior is good and low maintenance features. I'm tempted to get the GT and not have to worry about premium fuel. Anyone feel the GT is a better value?
Pontiac Grand Prix - 2000-2005 - Page 15 - Car Forums at Edmunds.com
