I've got a 2000 Venetian Red T-6 that I just love. I just passed 48,000 miles. I just took it on a 500 mile trip and somewhere I got the front drivers-side headlight lens cracked. The headlight assembly looks to be intact.
When I searched the inter net for replacement parts. I found a lens only replacement at www.importspecialistsofamerica.com. They are offering the lens only at ~$126. When I talked to my dealer's parts guy he was unaware of a replacement lens only. When I gave him the part number from the web site (8662865) he looked it up and indicated it was not for the US market, but he further said it looked like he could order it and couldn't see why it couldn't be used. I decided to order the lens only from Import Specialists.
My question for you savy S-80 owners is have any of you replaced the lens only on these headlight assemblies and is it something that a reasonably handy person should be able to do? To bracket my answer, I can tell you that I've replaced the rear tail light assembly on my wife's 850 and previously on my old 740 TD. The supplier has told me they include the new retainer clips and gasket with the lens. I'm looking to see if anyone has any step by step directions for removing and installing a new lens and relatively how difficult it might be. It looks like the headlight assembly on the 2000 is held by two bolts on the top of assembly. Any hints or things to look out for. Or does anyone know where one could get the headlamp replacement procedure? Of I subscribed to the Volvo on-line manual service is this sort of thing covered in the manual?
Currently there are no incentives on the T6.
The front bumper has to be partially removed on one side to replace a headlight assembly or glass.
Start by removing the upper clips that retain the glass to the headlamp shell.
Next, drill off the 4 plastic-headed rivets inside the wheel well (have new rivets and a rivet gun handy for re-installation).
Remove the headlight wiper arm, the black plastic cover just below the headlight (just pull off carefully after heating with a hair dryer to prevent the brittle plastic from cracking), and the side marker lamp (which is attached to the black cover).
Remove the turn signal lamp assembly (push down on the release tab from the top next to the headlight, then slide forward.
Remove the 2 plug covers in the lower front area of the bumper, and remove the bumper retaining bolts. The bumper will now slide forward enough to remove the remaining clips that retain the glass to the shell.
I would be leery of using a Euro-spec glass, as it may not match the other side. Discount mail order dealers, like Borton Volvo, sell the correct lens for about $125, according to others who have replaced it themselves.
Beats repalcing len covers.
I have "eyeballed" all the steps and they seem to make sense. The "black cover" is a finish molding that runs along the top-front edge of the bumper, starting just to the side of the grille and continuing around to just past the yellow side marker light (which is mounted to it).
I used a long screwdriver to depress the turn lamp assembly release tab.
I feel your frustration. Let me know what you find out.
Question to anyone in northern NJ; Any service experience with Paul's Volvo in Hawthorne, NJ? I can't bear to keep going back to the dealer where I bought the car. Whoever said finding a good Vovlo tech is the key to happy ownership knew whate he/she was takling about.
One owner was able to watch the technician replace his headlamp (the entire assembly; he was told the glass could not be purchased as a separate piece). They completely removed the bumper to gain access to all of the shell fasteners.
My understanding is there are retention clips only along the top and bottom, and it is possible to replace the glass, but not the entire unit, by just sliding the bumper forward enough to access the lower clips.
Volvo's current semi-secret $5K dealer incentive on the S-80 2.9 expires 31 Oct. Dealer feedback is they don't expect any major changes as sales appear flat at best. Anyone heard what programs/incentives are in store and when they'll be released? Real close to buying an '04 S-80 2.9 at $32.8K w/premium (leather & sunroof) & 17's, MSRP of $40.7. Fingers crossed the $5K stays or goes up. Any chance there'll be dealer incentives for the 2.5T AWD version or T-6 perhaps?
Request feedback before I buy one and the headlights crack, then I can't get the bumper off, and then the transmission woes (whooa-Nellie).
Also, anyone heard about possibly phasing out the 2.9 engine? In lieu of what? I hope there's an alternative to the turbo 5-banger and top-notch dual turbo T-6 as although the 2.5T may be stronger than the 2.9 due to the blower, (208HP, 236 ft lbs/torque versus 194HP & 207 ft lbs for the 2.9 6-cyl), it's certainly not as smooth as either six. All are great engines but the 2.5 felt like chitty-chitty bang-bang in comparison. You have to check the tach to see if the 6 cyl is even running.
FYI on headlight protection. 3M makes clear sticky material (like sheets of heavy grade clear tape) that is used to protect aircraft antennas, works great. Still looking for a web source and will post it. 3M, post-it, get it?
The 2.9 is being phased out in favor of the 2.5T variant. Hence the incentive.
Given the declining sales there will be incentives on all versions eventually, but it won't get any better for the 2.9 than it is now.
ipd carries the 3m headlight sheets, www.ipdusa.com
I should get my s-80 back today, and it seems as if a vacuum leak may have been causing many of the problems including the one with the transmission. Supposedly the technician has put over 300 miles on my car after he changed the molded plastic hose that is attached to he throttle body, and the transmission has not had anymore mishaps since this hose was replaced. I saw the hose and it looked like the bottom of it had literally melted. Today will be six weeks that volvo has been working on the car and supposedly they have fixed everything. I am going to get the car back tomorrow and will be trading it in this weekend. Let someone else have the crazy thing. Good luck with yours!
Brian
Volvomax, do you think the 2.5T, even with AWD, will place a dent in XC70 or 90 sales?
But, it won't change any of the sales figures for the XC90 or the XC70. In fact, in the Southwest, the South and the West Coast it won't sell in any numbers at all. In the Northern markets I expect it to do quite well. AWD is only a small part of the decision to buy the XC90 and the XC70, there are a whole host of other reasons.
It the T6 going to be AWD as well? It sure needs it.
Will probably settle for the 2.9 here or jump to the T-6 if I can swing it, partly because of the $5K. Either feels like the best bargain vs. the 2.5T.
Here is what I have been quoted:
S80AWD Includes Premium Package,Metallic Paint, Child Booster Seat
Market Price: 40,995
Invoice Price: 38,595
Selling Price: 38,895 which is less than 1% over invoice
S80 with Dynamic Stability Traction Control includes Continuously
Controlled Chassis
Includes Premium Package, Climate Package,Bi-Xenon Headlamps
17”Alloy Wheels
Market Price: 43,515.00
Invoice Price: 40, 765.00
Selling Price : 35,399 includes $5000 cash back
What is the lowest I could get a dealewr down on a S80 w/ AWD?
DSTC prevents you from running off the road by correcting out of control movements. AWD is useful only in getting you moving from rest if you have differential traction (i.e., better traction under at least one wheel than the others) If you have glare ice under all wheels it won't matter if you have FWD, RWD, AWD, DSTC, etc. because you won't be going anywhere. If you have some traction under at least a wheel AWD can help get you moving. If you hit a patch of ice while underway and start to slide DSTC will correct the slide but AWD won't help a bit.
With a FWD layout I wouldn't be concerned about initial traction for moving from rest. If you can't get going with FWD you might want to reconsider driving. If I had to choose again between AWD and DSTC there's no contest - DSTC wins (of course cars with both like XC90, Audi Quattros with yaw control, etc. are better still.)
-rollie
rdollie@att.net
2.9
Pro:
1.) from personal experience, this is a reliable engine. My 960 (almost the same engine as S80 2.9) is pushing 120k. No engine problem.
2.) 5K incentive.
Con:
1.) not as powerful as 2.5T
2.) doesn't have as many standard features as 2.5T
3.) difficult to find one with DSTC here in the south.
2.5T
Pro:
1.) AWD
2.) more power than 2.9
Con:
1.) higher insurance rate, cuz it has a turbo
2.) turbos tend to "lose" power when getting old, and they may be more expensive to maintain.
3.) I may be wrong on this.... I read that Volvo uses Mitsubishi turbos.
I never had a car with turbos. I know the insurance will be higher, but how much higher??
The tires must be matched. Damage one and you have to replace all four. This has been an unpleasant surprise to many of the XC and V70-AWD owners.
Planet Houston out...
Volvo newbie here in Houston, TX. Does anyone have any experience with any of the Dealers in the Houston Area? I currently have mine in the shop for a once over since I just bought it. It has been acting crazy of course right after I bought it. Warning lights going off, AM radio working like crap, Transmission shudder when shifting gears during hard acceleration. All the usual S80 issues. I have 48K on the car, but the time on the warranty ran out in June. So I am basically stuck stuck with a bill. The service writer told me to get an extended warranty and bring it back to get fixed. Does anyone have any experience (GOOD) with the warranty companies. They all seem "seedy" what about ease of use when you take it to the shop etc. ANy input would be appreciated. Take care. Planet Houston ....
The AWD vs. S-80 prices posted above sound good. The 5-cyl felt choppy to me at idle in the S-60, can't imagine it got better in an S-80. Your thoughts on this impending deal are appreciated:
'04 S-80 2.9, Prem, 17" wheels, mudflaps on all 4, metallic paint, MSRP 40,670 (thereabouts), will sell for $7350 off down to $32,800. Sounds like a great deal to me, your thoughts?
I would like to add the -801 stereo, reverse sensors, and maybe DTSC. The $7350 discount still stands no which I choose from this particular dealer, others hem & haw. The dealer offering this isn't real local which isn't a major problem if the price is right. Anyone have pos/neg experiences buying from another dealer and getting serviced locally?
Also, the pearl white sounds interesting. Can't find a vehicle picture (not a fob or sample) anywhere. Anyone able to post or e-mail me a photo?
Good luck in Houston.
It almost seems like its the death knell of the car.
Perhaps Volvo needs to do more than just refresh the car after 5 years.
XC 90 prices are high only because they all fell of the boat into the North Sea. There is some demand for the S60Rs I guess.
Oh, I had a bad knocking noise, like valve tap or a sewing machine. I read somewhere that it was the O-rings in the oil pump. Sure enough that was it. So my 99 S80 lives on, quiet as new.
I had a Cross Country XC70 loaner and it had the 2.5 all wheel drive.
I kind of liked it. The AWD gives the sensation of sure footedness. My wife took it on a long trip. She had some complaints about swaying and vertigo from her passengers, but perhaps this station wagon AWD is more raised up than the S80, it must be. It looks so anyway.
Sadly, the car continues to suffer from its launch reputation.
The S80 was a very ambitious project for Volvo, one that they lacked the resources to bring off.
Volvo is at least 2 yrs away from a new S80 and I don't think anyone wants them to rush it this time.
The new AWD is a very nice car, much more stable than the fwd variants.
I would give anything to have an awd T6 though.
BTW, the ship sinking had nothing to do with the XC90's popularity. Only 900 or so XC90's went down with the ship.
The myriad of awards and recognition plus the overall good design and thoughfulness of the Swedes is what keeps that car hot.
Hopefully the new S80 will benefit from the XC90's success.
There is a factory-to-dealer price incentive of $7000 in my area (Northeast). It does not pass directly to the customer like a rebate, so you have to negotiate to get it.
The price mnus is getting in #1373 is high IMHO. Here's what one dealer put in writing on a T-6 trumping that deal heavily: '04 S-80 T-6 ($44,525), White Pearl ($600), Climate Package ($650), Bi-X headlights ($500), 4-C chassis ($995). Destination ($685) is included for a total MSRP of $47,995, discounted $7350 ($5K of it from Volvo) for a before tax total of $40,644! Tax here in NW FL is about the same as Jacksonville.
As you can see, this has $2,745 worth of options and is only $257 more than your current deal. If you can figure out how to e-mail me I'd be glad to fax it to you along with other similar ones. Even with such a deal the wifey is shying away from the T-6, just too much oomph, I'm just about shedding tears. We have similar offers from the same dealer with the same discount as I rambled about earlier. I would like to find a car like the one you're looking at in one of the neutral metallics.
I believe in fair dealer profit but consumer info/research warehouses, namely this site, are a great help in saving at least a few hundred bucks. Dealers don't have to disclose there's a $5K incentive. I imagine some non-web researching customers are gloating they haggled down 2-3 thou after viewing the invoice price and because they're uninformed allow the dealer to pocket all or most of the 5 grand. In slang Latin terms left up to your interpretation, "Carshopus Saveabundle Dealerrectum" ;o]
Keep posting the bargains, I will too.
Haven't been able to find out whether that's local, or Volvo/Ford wide. Nothing on AARP's web site about it either.
The dealer is also offering a $200 dealer loyalty discount (we've bought there before). The non-negotiated price (they don't negotiate) is $2000 off MSRP. Add it up, and that's $8200 off a $40,825 MSRP car! The same discounts apply to the T6 if I could justify it.
My wife's company (quite large) has an employee discount with Ford (including Volvo), and that program's price is about $125 above what the dealer has offered; however, under that program you don't have to pay for processing and document prep fees (about $275)...so that's even a bit better deal.
My company offers a discount through Ford on Volvo's, but I don't know if I can get a better deal right now simply by going in and negotiating myself.
I had a chance to deal with a Jaguar dealer with the X-plan (something similar, but I believe Jaguar has a different name for the plan). The salesman wasn't too happy when I mentioned that I would purchase the car with X-plan. I called and left him a message days after the test drive. He didn't even bother to call back. Not sure why... maybe they won't get that much profit from X-plan? ... just something interesting experience I had
tpc
To Tcormier: the $5000 rebate isn't valid for the AWD, only the 2.9, 2.5 Turbo, and Premier. For the AWD, I would expect only $2000-2500 off MSRP.
You won't find the $5K incentive anywhere but on websites like this one. Dealers will probably tell you the scoop if pressed but they aren't obligated to share that money with you. If you notice, it doesn't apply to the AWD S-80 2.5T. This was no mistake. I think Volvo is leading us toward that S-60 powerplant because maybe next year the 2.9 will go away and the T-6 will be AWD if they can figure out how to do it. This is purely my speculation but would give Volvo two 4WD powerplant choices in its top-notch sedan.
rick-va,
Ba-Bam grandpa! Nice job, makes me look silly with a $7350 discount, I wish I was older. The T-6 is just so much fun to drive, if it's in your budget with all those stacked discounts, I highly recommend it, you won't be sorry, insurance isn't but a few bucks a month more over the 2.9. What colors are you considering? I finally got White Pearl photos thanks to one great dealer. Even a basic T-6 was a stretch and with my list of options, just too much money as the 2.9 is plenty zippy (OK, I'm rationalizing away my pain). Our local dealer has exactly what her first choice is and my second; Gold 2.9, Premium Package, 17 inch rims and variable speed assist steering (better this year with a ZF unit), Warm & Climate (dealer claims the IR reflective windshield is great), On-Call Plus, MSRP $42,660, discounted well to $35,300 ($7350 off, 2.75% above CRWP), we're going for it! I feel comfy as it looks like Ford is only giving their best pals what we non-X-plan eligibles can do on our own, I did that well on my Ford Expie Eddie B here too.
Next issue, I know extended warranties are well regulated but anyone care to share what they paid or what I will should pay for a 7 year, 100K mile, $50 deductible VOLVO plan? Thanks for everyone's help and feedback.
If you get the factory installed Stentor 17 inch rims you get the ZF variable assist rack & pinion steering too on the 2.9. It is standard on the T-6. If I remember right, it's on the window sticker listed like "(includes speed sensitive steering). Not sure if that's true with the optional rims on the 2.5T version.
have u driven each of these? could a T-6 with traction control negotiate a steep, snowy, hill from essentially a standtill as well as the new AWD in your opinion?
Yes, you are correct. You get speed sensitive power steering with the 17". That's a nice surprise
