What is that "catastrophic engine failure" that cause the fire? Broken fuel/oil line?
I have my 2004 S80 @111000 miles and going very strong. Interior is clean and solid as new, no rattles.
So, I would like to spread a word that Volvo builds very good cars. And I do thank Ford for bringing more financial stability to the great company and allowing the development of different vehicles - XC90, C30, for instance, that would not be feasible for Volvo alone.
P.S. It was enough for my wife to run over some "left-over" construction defects in our drive-way alley @ about 40-50 MPH to shut both front struts dead. The reason was that the interior insulation is such and the overall "bump absorbsion" performance of S80 is so good, that she did not feel that she was inflicting damage to the front suspension.
Volvo can call it a safe car only because it's in the shop more than on the road. Do Not Buy A Volvo
The transmission replacement @27,000 miles should be free, unless there was an extremely serious reason to void the warranty, in which case, I would not blame it on Volvo.
Same with the engine mounts - there was a recall for the sub-frame bushings, and the replacement should be done at no cost, unless, once again, there was a serious reason to void warranty.
Non-warranty oil leak repair for over $1700??? Sounds wrong again.
It seems to me that Edmunds attracts a lot of Volvo-bashers (e.g. "trolls"). I read other boards too, and do not see such amount of opened anti-Volvo propaganda anywhere else...
I wonder why....
How can I tell what needs to be done at this service (I guess the 67,500 mile check) and does a dealership have to do it?
I bought my car in Germany (but it has American specifications) and the Service Manual I have uses KM instead of Miles and essentially uses every 10,000 miles for the checks. At "70,000 miles" it tells me I need to complete the following:
* Oil/filter change
*Coolant, level check
*Battery, acid level check
*Power steering, check oil level
*brake fluid, check level
*brake pads, check
*parking brake, check
*gearbox/rear axle, check seals
*Front/rear suspension, check
*brake and fuel lines, check
*cabin air filter, check/change
*Fuel filter, replacement
Most of these seem like they can be "checked" at my local quick oil change place, right?
In Germany I was routinely paying $150 and up for these routine services and I don't want to pay a Volvo dealer just because they are a Volvo dealer.
I live near Dothan, AL and there don't seem to be any independent mechanics that work on "them foreign cars."
Thanks for any help you can offer.
They wrote: !!customer declined 15k service!! on service writeup. Looks like intimidation.
Really no problems. Love the car! Its my second S80 T6; the first was a '99 but I missed all the transmission problems. It needed three air mass systems and at 100K needed some expensive repairs ($2500) but I gave it to my daughter and those repairs were cheap insurance.
We are on our 8th Volvo. My wife has a '04 V70; she would like it to be as big as her 960 wagon, but that's not going to be. She feels safe and some bugs but no big problems.
Thought someone would like to know they're not all big problems!
This car was a money pit. All I can tell you is RUN AWAY, DO NOT buy this car...
Bought a 2005 VW Passat TDI Wagon, and what a joy it is not to have to repair your car every month!
The trick is to clean the wheels every week so the dust doesn't build up.
1. I use an air compressor to blow the brake dust. It's much easier than washing the wheels. This only works on light brake dust.
2. I never tried this, but many people said ceramic brake pads can eliminate the dust.
Ceramic pads save pads and eliminate dust at the expense of rotors and braking distance.
The soft pads are used on purpose...
These bulbs are referred as tail bulbs 4/5 in the owners manual and it is on page 94 in my manual, under Replacing Bulbs/Tail lights.
I can't get the message light to de-activate when I start the car, except by manually reading the message every time that I must renew my OnStar account. Is there any way of permanently de-activating this message?
(Dealer says it would cost hundreds as they would also have to remove the built in telephone apparatus)
Thanks for any help!
My suggestion is to keep the phone and you can still dial 911 with it even without activation.
I'm considering buying a 2.5T S80 with about 25K miles - obviously still under warranty, so that mitigates reliability concerns for a few years. I have a tendency to keep cars for 7+ years - will this thing make it (probably an even mix of highway/city driving)? From everything I've read, the S80 has improved dramatically since the 99-01 years is the 2005 2.5 a keeper? Also, this car doesn't have the incredible Dolby stereo. Is the regular stereo still pretty good? Would speaker upgrades help? Is that even possible? Any feedback is appreciated. Thanks!
Runs great and very stable ride at high speed (>80 mph), so much difference from Honda Accord I used to have.
I encountered one glitch at the very beginning (93 miles): check engine light on, which was easily fixed by software update.
Fuel efficiency is better than published numbers (20/27), I easily achieved 29 mpg on a 465 miles highway trip this July.
The up-to-date average number is 24.8 mpg.
I commute everyday (6.5 miles one way) with lots of steep up/down hills and lights.
Standard speaker is already good enough, no need for upgrade.
It is also a good idea to have the car inspected by a trained Volvo technician.
Chintan Talati
Corporate Communications
Edmunds Inc.
IIHS complained that the gasses from the bag could singe the hands of the driver, so the bag vents were re-designed.
I had a bad experience last nite when my 1.5 yr old S80 died suddenly in the middle of a drive. This afternoon, I just had a call from Volvo workshop and they told me that this is due to the fuel quage indicator not working - the tank was empty despite it showing half tank. I wonder is anybody had the same experience.
Eric
It doesn't mean there was anything wrong.
The S80 bag was essentially the same as the bag on the 850 and S70.
It served for years without ANY complaint or issue.
The bags only deployed if the seat belt was undone.
The g-load on the sensor was such that the system thought the collison speed was higher than it was, since the driver was unbelted the bag was deployed at low force to keep the driver from eating the steering wheel.
This was only an issue during the useless IIHS bumper test.
sounds like a kid who failed algebra test and told the teacher that algebra is useless. get real.
It has nothing to do with safety.
It just tells the Ins co how much they have to pay to replace a bumper.
Euro cars always do poorly on this bogus test because the European regs require a soft nosed car in order to pass the pedestrian hitting test.
Please do some research before you spout off.
Is the pedal mushy all the time, or only sometimes?
If it is mushy all the time, take a look at the brake booster.
