What are your thoughts on AWD? I personally driving city and highway don't believe I need it.
FWD does nicely.
Mackabee
Mackabee
What is happening is that when I select a preset that has a station which is RDS enabled, the radio will start to 'skip' to other stations in the preset list, usually quickly cycling through about 4 presets before it settles on *A different station* than what the preset was for!!!
I have reprogrammed the stations presets, but nothing seems to prevent the stations from 'skipping', other than turning the RDS feature off.
Has anybody else had problems with the RDS feature on the radio? And more importantly, is there a known solution to the issue?
David
OPTIONS: You can use the single or six disc JBL unit. There are also other models that will work. If yours is a JBL, it has an EXTERNAL amplifier. ANY externally amplified unit, with the same (newer) harness plug will work. Simply remove your radio and look at the plug and match this up to pictures on ebay. I spent $230 for a six disc JBL. NOTE: There are TWO plug interfaces on the back of the radio. ONE should be empty(JBL's are usually not connected to trunk changers). If there are two plugs in the back of the unit, the smaller boxier interface is for the changer. Let me know if any Q's...I've done a lot of audio work on the Avy. -nomad-
I have a 2000 Mercury Sable.
I am in the process of buying a 1999 reconditioned Toyota Windom (right-hand drive) from Japan and ship to the Caribbean, but the agent wants to know if I want the 2000cc or 2500cc model. I think the price is reasonable at 890,000 yen.
Much help is appreciated.
bwia, you might want to consider having the Catalytic Converter removed b/c many Caribean nations use leaded gasoline. This way you can use leaded gasoline w/o any problems, although the emissions will suffer, but this is not a priority to many 3rd world contries. Also, you might want to move on the transaction quickly, as the U.S. Dollar is at 3 year lows against the yen or wait for the U.S. to adjust it's currency policy...
What I noticed however, was a robust market for used Japanese cars. I investigated further and realized I could purchase a good used Japanese car at a significant discount.
In today's Wall Street Journal there is a page one article (How Japan's Second-Hand Cars Make Their Way to Third World) that explains this flourishing market.
1) Mudflaps, cheap, may hide little wagon tires.
$100
2) 215/55 H 16 is the way to go for a bolder look without changing wheels and calibrations.
$500-$700
3) New shocks probably more stability in handling
than tire, but nothing for looks. $640
4) Spend big money and go up to The wheels are
ATP 17x8 alloy wheels and some Dunlop Sport
5000 tires ($1600, a poster had pics, car
looked good, but he was selling it?).
$1600
5) Do nothing $0
Any recommendations, anyone go with #2 the larger profile tires? How is it?
~alpha
While not an authority by any means, waiting for the 2005 Avalon is probably an idea a dealership )or Alpha01 might give you. If does not change the inherit weaknesses of the car, as all of them have.
I have a 02 model XL, and drive extensively in the Northeast from West Point, NY to Ft. Drum,NY on an interstate and rural state highway, in all types of inclement weather. You may or may not be in that situation and your situation might dictate other methods to enjoy the vehicle more.
This is what I did, in reference to your post. I have added in addition, many items such as two sets of PIAA fog and driving lamps, an electronic deer alert, XM radio, but this is limited to your post.
1. The absolute, biggest improvement to this model year Avalon 00-present, was the replacement of TOKICOHP shocks. Without a doubt, the car rides, handles, and breaks totally different. Yes, there are pros and cons, but the pros far outweigh the cons in this case. If you remember CR report on the Avalon, the cons of the stock car included bottoming out, excessive front nose dive during high speed braking, and mediocre handling. These specific aftermarket shocks have addressed all of these issues without VSC, and then some. Is the ride stiffer; yes, but not nearly as much as you would think. I cannot comment on other aftermarket shocks(Koni, Bilstein, etc.) The install is relatively straight forward for a competent wheel and alignment place. Note: I still have a set of the OEM wheels and tires.
2. You can, although not specifically designed for this model year, put on Energy Suspension PU bushing for the sway bar mounts. NOT the Control Arm Bushing. Don't mess with this!!! The polurethane bushing both front and rear, attached to the sub frame, and with less flex, will improve the cornering, and yes, will let a little more vibration through the car. But, there are NO rattles or squeaks in my car at 38K miles to date.
3. No, as far as wheels and tires go, these are strictly my thoughts in my own situation. I have two sets of the OEM wheels, both steel and alloy and one set of 16" rims with 215/55 H 16. I have got to tell you, that although people think they look good, they are the LEAST favorite upgrade I can think of. Here is why. They are a more costly upgrade that the others; The ride quality and hydroplanning increases significantly without a big gain in performance; it is an upgrade that keeps costing!!!!!!!!with replacement tires that are more expensive than OEM.
In addition, the Avalon body does NOT flare at the wheel wheels so, the slightly wider tire set themselves out from the splash guards in the back a little, not alot, but I am very meticulous so I notice everything.
If I have to do it all over again, I would do the TokicoHP for sure, probably the PU bushings(Energy Suspension) although they were painful to put in the fronts, and not bother at all with the wheels or tires.
These are my experiences with regarding your post issues. Toyota may or may not address the weaknesses of the vehicle in their new model (2005)as their are masters at crossing parts from other models and lines (OEM shocks same in Camry, Avalon, and Lexus 300).
Hope this helps. Save the money on the wheels and put in an XM stereo. Now there is something also that was well worth the cost for enjoyment purposes.
abfisch
Toyota insisted they were not to blame and that the cause had to be airborne. The customer won a repurchase. I later found out that there had been a paint problem with the pearl white at the factory for a day or two and other pearl white cars were having the same paint problem.
In sixteen years hearing lemon law cases Toyota was the most arrogant manufacturer I came across. They gave me the impression their policy was you bought it, you own it, too bad, Toyota!
I can't say how they are today. I stopped hearing lemon law cases about 5 years ago. My own personal experience with my Toyotas has been problems have been taken care of well at the dealer level. This is opposite of what I observed at hearings.
Note: My Avalon is pearl white.
If it is only the rear bumper you can also consider having the bumper repainted. The come to you people that fix dealer's cars (scratched and damaged painted bumpers) can repaint your bumper in a couple of hours. My neighbor had his bumpers repaired and fixed by one of these services. Took a little over two hours and the cost was very reasonable. I can't tell the bumpers (both) were ever damaged.
The cost to repaint the rear bumper on my MDX was only $80. That included fixing the deep scratches.
I took Toyota to the dealer sponsored arbitration for a banging from the rear suspension.
You have to first get the panel allow your claim to proceed to arbitration. Mine was declared eligible as it should have been covered under warranty per the panel.
Now for the Arbitration process. The arbitrator had absolutely no knowledge of the mechanical workings of an automobile.
In the arbitrator's decision during a test drive the arbitrator acknowledged the banging noise
from the rear suspension. The arbitrator then disallowed my claim for a repurchase or replacement caliming I failed under the LEMON LAW to prove the value was not substantially reduced due to this problem.
This was not filed under the lemon law - it was filed under the dealer sponsored Arbitration Process. Which is by the way just what it is DEALER SPONSORED.
There is no appeal to the dealer sponsored Arbitration Process.
On December 1, 2003 I followed up with a detailed to letter to Toyota North America President & CEO Mr Yuki Funo in Torrence, CA regarding my problems with our 2003 Toyota Avalon. Here it is January 22, 2004 and to date no response from him or his office.
ARROGANT - there has to be a stronger word in Webster's dictionary.
Where I heard cases it was manufacturer sponsored and the consumer did not have to accept the arbitrators decision, but the manufacturer did. This allowed the consumer to go to court after an unfavorable decision from an arbitrator.
My neighbor two doors down from me had a similar experience, like yours, years ago. He went to court after losing the arbitration. He won in court and got all of his money back, plus attorney fees.
Many of the cases I heard were unfair in the sense the manufacturer had been through hearings a number of times and it was a first time for the consumer. Most consumers were nervous and many were not well prepared. Sometimes I would have to ask leading questions of the consumer and manufacturer in order to get enough information to make a fair decision.
I also found that the few times a consumer brought a lawyer to the arbitration the lawyers were not prepared well for how the process worked. It was not a court room and the rules were different.
The customer prevailed about half of the time. It wasn't uncommon that the customer was trying to pull a fast one, but these were usually easy to spot. What used to really get me was when there was a glaring defect in the car and the manufacturer did nothing. Then at the hearing tried to say there wasn't anything wrong with the car that couldn't be fixed.
My worst case like that was a customer claimed his car would move forward when he put the car in reverse. The manufacturer said that wasn't possible (it was a stick shift). It turned out to be the shortest test drive I have ever made. Customer was correct: The car went forward when the shift lever was in reverse. Only time I broke the rules and issued a decision on the spot.
Lemon laws vary state to state. However, most have the same criteria: There must be a 'substantial' loss in use, value, or safety. The key is the word substantial. To some it is nearly impossible to get to substantial while to others just not fixing a minor problem is.
BTW, having a car person as an arbitrator can also work against the consumer. The car person will be more likely to know what is a annoying design characteristic common to the model rather than a defect. Toyota had at least three of these while I was arbitrating.
I hope this post addresses ALL your questions. If not, ask more.
1. I have had about, lets see experience with aftermarket shocks, since I was in college and had a Datsun 28Z, graduating in 1981. I know I am dating myself. The TokicoHP, in my opinion, are the best. Why, my experience with Bilstein, were they were too hard, except maybe for a 20 year old back, and a twin tube shock design given a comparable performance gives a better ride(softer, not softest).
2. I believe I got the shocks on the internet, for about $400, for the set of four. Actually, these are stuts, on all four corners. You can probably do better on ebay if you are smart and can wait a bit. Anything in the $350 range is a good price for the Avalon/Camry, which is the same replacement part number.
3. Warranty-A warranty is ONLY as good as the company and dealship that honors them. Some dealerships are great, some not so good. The dealership that I bought my car from was the later, as a separate warranty problem I had took 16 months to fix, neither by the dealer or the Toyota Motor Corp. They bounced it back and forth between the two of them, never diagnosing the problem correctly. Finally, (high speed vibration), I took about the front brakes and found the problem, and corrected it myself, using premium brake components. But...to answer you question from your standpoint, YES.... I voided their warranty 3years/36K at about the 15K mark, when I could no longer stand, the damn thing bottoming out when loaded, or excessively diving when seeing a patrol car or traffic stopping abruptly. It made me frustrated and angry, that there top of the line car, does not have top of the line dampers. Now it does. If you are reluctant to change them, then just wait until your warranty expires, then do it. You will have wished you did it sooner, but that is OK. Express your experience in this forum for others.
4. You did not get to the correct place on the Tokico site. When accessing the site, go to "Cars", then "applications", then Toyota, then you are there. They make the HP shocks, not the Illumina, for the older model and new model (2000-present) Avalon. I have an 2002 and they fit like OEM. Even though the dealership will not do it, a reputable, "wheel and alignment shop" or "frame and axle shop" will. You will need a 4 wheel alignment to supplement this change, so it is not an inexpensive deal. Struts, labor, and alignment, probably $700 or so when you are all through. The struts are warrantied from Tokico for the life YOU(original owner) have the car, so if you keep it along time, it is worth it. IF not, then probably not.
5. I drive 20K/yearly, last car sold privately at 236K (Honda Civic EX), 11.5 years old, Tokico Shocks put in after 100K. You couldn't make the OEM tires squeak around a corner. Superior in any vehicle that has decent suspension geometry.
6. Unless Toyota offers the 05 plus Avalon with a "Sports Suspension Package", I would expect the shocks to be the same ones they put in the NEW Camry/Lexus 330. This is how they save money and make money. The new Lexus 430, now comes with a "sports suspension package" (not fufu_ including different rate springs, a larger rear sway bar, some different PU bushings, and ofcourse 18" alloy wheels instead of 17". I have no idea how different it rides, but this should quiet those who says that the Avalon was only made to ride like a Buick. I disagree. It can ride well, isolate vibration, and handle well comprising little. It is still not a BMW 5 series ride, but close enough for the many miles I do, with much better reliablility and maintenance I can do myself.
I have 38K on this 02 now. Everything is fine. The XM stereo added to the JBL system was a sweet addition. We also hooked up a Valentine One Radar detector with a direct connect to the battery(no wires visible).
I hope this is informative and helpful. Again, if you trade often, lease, or just don't care, it is a big initial expense. But I always get my money's worth out of it in the end, as I always keep my vechiles a minimum of 10 years, paying for the next one cash. If you decide to do it, just find a competent shop that does that kind of work, all the time. It is usually very easy for them to do it as they have much bigger jobs, like taking down the entire suspensions, leaf springs in trucks, cross members, etc. It is a chip shot for a good ASE mechanic.
Happy motoring.
abfisch
abfisch
She claims that the air blows cold after a while. I presume that the heater supplies hot air until the desired temperature is reached and then cools down a little to keep the temperature steady.
I never noticed this while driving the Lexus over the last three years. Maybe the extra low temperatures in Mass lately have affected how the heater works?
Both cars have automatic temperature control.
I took it back, they changed it (n/c) and heater air flow problems went away.
Good luck!
I could see an LS-330. Even the current model lends itself to Lexus treatment, thus leaving the low end of the Lexus range as IS-300 (Low price, competes with BMW 330), ES-330 (Competes with BMW 530), and LS-330 (General luxury car at sub-$40K).
The only trouble is that the Avalon is bigger inside than any Lexus ever made, even the current LS-430.
In addtion, the Lexus LS430's truck is at least as big, and the fuel tank is 22.2 gallons (US) versus the Avalon 18.5. While not getting the same gas mileage, you can run approx. 550 miles on the Lexus without fill up.
abfisch
In other dimensions the Lexus is an inch or so larger. I was comparing the Avalon with the LS 400 recently which is why I made the mistake - sorry. And I'm sure that the space is efficiently used in the 430.
Is this a common problem, or is it a rare occurence. luckily have a warranty from the dealer and will be taking it in this am. Any answers this AM will be appreciated.
Avalon Ride Comments: Reference CR article I believe, JAN 03, review of Avalon. I think it was last year this time. Pros and Cons interesting. Most people enjoy it as is, not me, but most. Depends on your driving situations.
abfisch
A Lexus LS430, mentioned above, is not in Avalon's class. You can buy any TWO Avalons made for just one LS430. And in 3 years an LS430 depreciates about what a good Avalon costs. The ride..the feel...nothing is similar here except dependability. No comparison is meaningful.
Some say Avalon has problems with a soft ride. The car will bottom out on occasion. Above 80 mph in a high crosswind is scary. Curvy roads at speed can be exciting. Steering feel above 25 mph is non-existent. Believe, this is not an Acura TL or BMW 5 series. But most owners who post here seem to accept these things. (My opinion, the worst thing Avalon offers is Auto-temp on the XLS. Too many problems posted. And it didn't even work properly on the DEMO '03 I drove!)
Avalons can be modified - wheels, tires, etc. - and some owners have explained that very well and in detail here. For me, the car fine as is. Our greatest worry, as Avalon owners, is what Toyota will do to the next generation. But if we read these many boards often enough, at least we will be among the first to know... Enjoy.
I went from Lexus ES 300 to Avalon, and I think that the Avalon offers (mildly) better value. The Avalon's ride could be better, but the majority of people want a "Japanese Buick" (and having driven a Buick as an insurance replacement for several months, the Buick shows exactly what's wrong with American design).
Perhaps the new model will address some of the CON issues.
abfisch
The January 15 invoice reads that an evap test had shown the filler neck and gas cap to be faulty, so they were replaced. That, however, did not solve the problem since the light came on again three days later. So I took it in once more. My most recent invoice, dated January 23rd, reads as follows: GAS CAP DEFECTIVE. REPLACED GAS CAP. Apparently the new gas cap from eight days earlier had somehow been faulty and needed replacing. Anyhow, I'm thankful that the light is currently out.
Now for the bad news. When I phoned the service department the morning of January 23rd, I was told that my car had been fixed, but I was also told that a Toyota employee had driven my car through a yellow light at a camera-equipped intersection the night before. (I believe I was also told that the employee had driven my car home that night.) In any case, the service employee said that I may or may not receive a violation notice, but if I did she told me to simply forward it to the service department and someone there would pay it.
Three days later I received a $70.00 traffic violation ticket from the city, and of course I'll send it to the dealership and have them take care of it; however, I read the ticket and learned that the traffic light had actually been red, not yellow (which I suspected had been the case), and that the violation had occurred at 11:02 PM! What I'm wondering is how outraged should I be by what has happened, and what -- if anything -- should I do about it. First of all, it strikes me as unusual that an employee would be driving my car after working hours as part of the testing process. I figured it would only be tested during working hours. Also, why would the employee be so careless as to run a red light? And for what reason would he/she be driving my car after 11 at night? (From the still picture it appears that someone could have been in the front passenger seat, though I'm not sure of that.) Since I wasn't there, I have no way of knowing who was in my car that night and what that person, or persons, might have been up to.
At the very least, isn't it unusual that a customer's car would be "tested" after 11 PM? I wonder how widespread this practice may be. Do employees routinely drive customer's cars home at night, if, indeed, that is what happenend? Has anyone had a similar experience? I guess I wouldn't have even been aware of this if the camera hadn't caught my car running the red light.
Ask for a sworn statement to be taken by the police that the person driving the car was the employee of the Toyota place.
Then have your lawyer open a discussion with the owner about compensation.
Do you know if this ticket, even if paid by Toyotie, is going to impact your insurance?
I think this practice is very, very unusual.
