Of course the other option is to have it repaired.
After turning engine off, wait just a few seconds and it starts right up. Wait longer, it gets harder and longer to start. Wait 35-45 minutes, won't start. - more ether to get it going.
Any ideas?
Any ideas?
https://www.mygmlink.com/main/US/en/oldsmobile/home?cmp=oldshp
The only warning indicator I see in our owner's manual (ours is also a 2000 Alero) that has a water drop (actually, an oil drop; it looks like it's coming out of a small oil can) is the oil pressure light, indicating low engine oil pressure.
http://i42.photobucket.com/albums/e302/mnovak99/alero.jpg
reading and could come across anyone with the same problem im haveing but
I tried instuling a car sterio and i didnt
work out , the power wouldnt come on the unit when everything was wired
correctly . so i figured that this wasnt going to work .I put back the
original one.Now my dash lights dont come on and my keyless lock and unlock
flashing lights are not flashing on/off now when i press on keychain. The service vechlie soon light is on too now so,but everything else is working fine .. what did i do wrong and how can i fix this do you know plz help me i dont want to give my arm and lag to the dealer. if you can give me some solution or give me some idea i would really be greatful Thank you and by the way I have a 2004 alero
Good luck with it.
Thank you and have a great day
I hope we can help.
I hope i can be of some help too ,to everyone anwell
have a great day
Even though the cars are different, the solution is the same. The longer the car sits, the more time available to let the built-up pressure drop. The pump is to suppose to seal it once it has passed the pump (like a one-way valve). The pump's internal seals are no longer holding the fuel in the fuel line. When the pump is turned off, the pump seals allow the fuel to drip back into the tank, thereby dropping the fuel pressure. djm
2001 Alero had a bad wheel speed sensor on driver's front. Bought aftermarket hub as replacement. Got old hub off with a LOT of work, put new hub on. Torqued everything up (but see note later). Also replaced brake pads while I was at it.
After hub replacement lights are all off, but now there is a popping sound when making a hard right turn. I thought maybe I didn't grease everything up on the pads, so I took it all apart and greased the heck out of it. No go.
I lifted up the front end of the car, put it in drive so the wheels spin, and turned the wheels both ways. No noises at all. So something to do with the weight of the car on it all.
The only oddity is the torque on the hub nut. The new hub came with a new hub nut of a supposed 'better design.' The paperwork with the hub said to torque it to 180ft-lb, anything more with cause 'excessive wear' to the bearings. The Haynes manual, however, says 284ft-lb on that nut.
So, that's the only possible confound. Any ideas? It sounds very much like a CV popping, but why would that happen right after a hub replacement with no warning beforehand?
Any ideas?
Thanks a bunch guys and gals.
as for the engine block with a drop of water, it's either a low coolant notification, or if it looks like an oil can, it's an oil pressure problem. to check your coolant, the car's engine MUST BE COOL/COLD! do NOT open the radiator cap after the car's been driven. i'd refill it with a premix water/coolant mixture that you can get from your local autoparts store. make sure you get the right color. the green & orange coolants are NOT to be mixed! as for the oil pressure, make sure your oil fill cap is on, the pcv valve is properly seated. the pcv valve is located at the right hand side of the engine, on top, and looks like a black 90 degree elbow (shaped like an L). follow that line to the rear and make sure the back is also connected. if that's ok, try replacing your oil sending unit. this may be faulty and not sending the correct amount of oil to your engine. remember, where this is NO PRESSURE, there is NO FLOW! GOD bless.
Does anybody have any advice on who I can contact regarding all these problems? The car is 3 years old and has had a TON of warranty work done, now my warranty is over and they found a bad wheel bearing, although my car was in the dealership for an oil change 3 weeks ago, they said they didn't notice anything...3 weeks later, heard a LOUD noise every time I excellerated and picked up speed and now have to pay 400 bucks for a new wheel bearing on the same side of the car where I just had my struts repalced. The struts were done when my warranty was still in place, now the warranty is up and the wheel bearing needs to be replaced! Never again will I buy an Oldsmobile.
The dealership that did all my warranty work said they never saw anything wrong with the wheel bearing when they checked everything out 3 weeks ago and there is nothing they can do and expect me to pay for it to get fixed. Can a wheel bearing really go bad in 3 weeks?
Since January:
1. Shorted out instrument panel
2. Water leaking from windshield into front floorboard
3. Broken power seat
4. Replacement power seat mechanism faulty - drained battery
5. Shorted out power window switch
6. Now, gas starvation issue causing stalling and bucking(which dealer says they can't replicate)
Dealer service has been abominable. Just couldn't be any worse. I've had my fill. No more GM products for me. Going car shopping this weekend. Pity the residual is so lousy on the Alero, but I sure understand why!!! I had hoped to keep this car a long time, but can't take the unreliability any more - especially at such low mileage. Hope you all have better luck than I!
That said, I agree with you that the mechanical problems you've had and that I've had in a well-maintained, fairly low mileage vehicle are not acceptable.
We bought ours 1 year used (already depreciated, always a good idea) and it's paid for now and we really do like the excellent responsiveness and highway gas mileage with the V6 power. So we'll be keeping it, and enjoying it, and grimacing every year at another unnecessary $500 repair bill.
Thanks for the vent session and good luck with the car shopping, I may be down that road soon as well!
Just in January, I put 1K into the damn thing for a new driver's side front wheel bearing and to fix the upper and lower intake gasket oil leak. Just last night, I was driving and luckily (there must be angels), the power steering went out two blocks away from where the auto shop I go to is located! I found out today that the rack and pinion went out and that the hose is bad; price tag w/o replacing the power steering unit, $700, otherwise $1000 if the power steering pump is out. So that makes for $2,000 in three months. Plus, I need new shocks and the other wheel bearing sounds like it's going out. It's sad, since the car doesn't even have 80,000 miles on it! I've never had so many problems with a car in the past! I wish there is something we could do as well, especially about the brakes, since my brakes are going to hell again after replacing them a year ago. Oddly, the rear brakes have been fine; it's only the front ones that really suck. Does anyone know of anything that can be done, especially since Olds is out of business now????
Lesson learned: I'll never buy GM again! :mad:
i changed the plugs and wires. service engine light came on later that day. i have a pocket scanner and it said the #3 cylinder was not firing. so i changed the ignition coil. no luck. i am wandering what else could be wrong. i am hopeing it is not the fuel injector. also could it be the spark plug or a bad wire??
Comparatively, when I've driven from Chicago to Madison, WI I was stopping every 20 bloody minutes to pay a toll. Not only is that a pain in the butt, and requires far more lanes, I suspect those starts/stops are hurting gas mileage too. Even with "easypass" you have to slow to around 30mph and then accelerate back up to 60mph repeatedly. How much higher would state income tax really have to be to get rid of those tolls ?
Seems your correction may be the solution. Will try it this week-end and post results.
I'm interested in people's opinions on my situation, and would appreciate any suggestions for what to watch out for when doing final inspection. Also, what type of extended warranty would best cover the array of problems most commonly seen?
This model/year has the Quad 4 which is known to be a powerful but harsh running engine (noise/vibration). If maintained it can be reliable.
The biggest drawback to the N-body cars was that they were basically low priced cars which probably got less than steller maintenance, hence many problems crop up later.
My advice would be to find a later model with factory warranty remaining so you can get a GM Major Guard warranty.
I would definitely ask for the service records and check to see if these have already been replaced. That would help me determine the price I'd be willing to pay. If it was serviced at a GM dealer, they may be able to pull up its service records on their computer.
You could ask the mechanic doing the inspection to see if he can tell if these parts have been replaced, but I'm not sure you could tell. Maybe with the rotors you could as you could assess the amount of rotor left on them and if they had been turned down.
anyway i was just wondering if anyone else here loves the car as much as me and has done anything with it mod wise, and if anyone has modified one and lives in delaware id like to know i live in delaware and never seen another hooked up alero. thanks sorry it was long
My input on N body cars hasn't changed over the years:
Inexpensive to buy, but without maintenance (which quite often doesn't get done on inexpensive cars) it won't last, which leads to bad reputations.
