1999 Grand Am. The Ignition key will not turn. The ignition lock is in the dashboard, not the steering column. I tried all keys many times over many days. I jiggled it, cranked the steering wheel, rocked the car, sprayed it with graphite based "Lockease" & swore, etc. GM dealers want $500-$600 to fix. Local Locksmiths range from $300-$400 to fix. They all want to replace the lock cylinder.
I found a local Locksmith who said he would repair (rebuild) my lock for $150 if I bring him the car. Here's the key. He said to insert the key in the ignition and tap on it a few times with the handle of a medium sized screwdrivver, then try to turn it. BINGO, it turns now. He said if this works, the lock will only last a short time and needs to be rebuilt. He will get my business, even though I found another Locksmith who would do it cheaper. Hope this helps someone.
The only way to check the fluid level is by removing the plug on the side of the trans case, near the front, on the passenger side. This plug is right at the proper fill level. It needs to be from underneath, and of course the trans should be warmed up and the engine running (do not remove the plug with the engine off). That red cap is removed for filling only.
You may want to search the Grand Am forum, myself and others have detailed the procedure for changing and refilling the fluid, which should help.
Mike
My DH got 4 of the boots removed but is really struggling to get the other two. Does he HAVE to buy the spark plug boot pliers?
I searched for the posts detailing the fluid change myself in both the GA and Alero forums and can't find it. Must be using the wrong search words. Hummmm, will have to think about it a little.
I try to put in a disc, and it sits there and makes some noise, then gives me an E20 error message and spits the disc out. The player actually works, but intermittently, (once every month or so) I've tried using laser lens cleaning CD's and had no luck. I've also tried calling a few dealerships about it... I just keep getting transfered to people who don't pick up their phones, or told that all they'll do is replace it... to the tune of 300-$500! ridiculous. There must be an easier way to fix the problem. Thanks in advance for any thoughts on this.
Victor
Replacing the serpentine belt(if needed) is aggravating though. Have to take the motor mount off and raise the engine.
Good luck...
Thanks in advance.
Thanks in advance...
Mike
I have a 2000 Alero V-6, and same as you, still like the looks of the car a lot after 7 good years. When I look at the power, style, initial cost and MPG it is hard to find a comparable replacement in the new car market.
I already had the intake manifold gasket replaced ($1200 minus $600 GM goodwill), front rotors replaced twice, water pump (only $60 for WP but $250 for labor), ignition switch for about $400 and now I am looking at close to $700 for the hub bearing assemblies.
I think I will be in the market for a new non-GM in the near future even though I currently have $3500 in credits on the GM card.
This was in April 2005. I called the Oldsmobile 800 number in my owners manual and was suprised that they were actually still there and answering the phone as "Oldsmobile Customer Satisfaction". Deal was I had to pay the Pontiac dealer the $918 and send receipts to Olds and they sent me a check for half. The savings really wasn't that great because the local independent shop would have done it for $600.
I didn't have the bubbling under the door panel material problem. I think that started in 2001.
You don't have to change out the entire ignition switch, just the passlock sensor that happens to be in the ignition. I had this done and it only costs about $300. My dealer said that they have seen this before and 9 out of 10 times it was the sensor causing the problem. I had the sensor replaced at the end of January and I haven't had any problems since then.
Until you can get it in the shop for the repairs, an easy and temporary fix is when you get out of the car, lock your door with your key, that will reset the security. If it happens that the light still comes on, get out and use your key to lock the door again. Once the light stops you should be able to start it up again without any problems. This tip was given to me by a tow truck driver, and it worked like a charm until I got it in the shop.
Thank you for your help!!!
Good luck with your Alero's.
This morning it wouldn't start at all. When I turn the key it does nothing. I take the key out and all my gauges on my dash board go crazy. The needles bounce all over the place with the car turned off. I read about leaving the key on acc or on for 10-20 mins, so I tried that, nothing. But everytime I do that, my clock goes back to 1:00 the next time the battery is on. Now I am getting a click like the battery is dead.
Please help!
Still driving around with 87 octane but will upgrade to 89 next fill up.
Bad news is that if the above doesn't work the bulletin said to take apart the engine and try some stuff.If it gets to that pointI will trade in car first
There is also a procedure to cut a yellow wire and bypass the passlock security. This will allow you to strat your car but security light will always be on. Do a search on "ignition switch" and "security" in this forum to read how others have solved this problem. Pay particular attention to meaasage #2737, 2738 and 2740. Also check message #2291 in the Grand Am forum.
I have read a few comments on this topic and I was wondering, is a "auxiliary water deflector" and a
"Moisture shield" the same or two completely different parts on the door??? :confuse:
Where could one purchase such an Item??
Thanks in advance.
I have had many of the issues others have had with their cars. My parents have an Intrigue and had FAR fewer issues so I am disappointed in the Alero.
