2004 Pontiac Bonneville SE Issues
ISSUE 1: My oil pressure gauge has started periodically bottoming out. I'll get the "check gauges" alert and then it will return to normal pressure. Sometimes it won't bottom out, but will suddenly dip very low and immediately jump back up to normal when I hit the gas. This usually happens when idling but not exclusively. Is this a real problem or a gauge issue? I know there's been an ongoing issue with many Bonneville owners where the oil gauge will stick at 120psi, but this issue is different.
ISSUE 2: My blower motor (for AC) has a bad vibration. How do I access the motor to see if there may be leaves or debris stuck in it?
The Gauges most likely is a voltage problem. Check connections at all points from the battery forwrd. Tighten connections including the grounds at the battery on the floor to make sure there's a good connection. Remember the positive, red, cables are HOT. Do not allow the wrench to touch anything else!
Then it might be battery or alternator. Most likely second would be battery itself failing. What climate are you in? Very hot much of the year? Cold, cold!?
Just curious why a voltage problem would only affect the OPG? Car starts fine and all other electronics (and gauges) are A-OK.
Oh, and I live in Florida, so...
It might be worth changing oil to see if a new filter and oil affects the symptoms.
What does the voltage gauge do during the fluctuations? A few have had a drop in voltage at low engine rpms which then catches and goes back to normal after a second. Alternators work great but there's something in the voltage regulator that's quirky.
Problems with connections on battery usually cause more than one thing to show symptoms.
What does the oil look like? What kind of oil and weight? How long has it been in the car? Miles?
What filter brand was used?
I think I would change the oil and filter to eliminate them.
