2004 Tahoe electrical problems.
Have '04 Tahoe w/ 21K miles. one day rear door and glass would not open, couldn't even hear the latch mechanism working. then realize the left turn signal was not working, thought maybe bulb was out, so turned on hazard lights, just left side not working, then both rear doors locking mechinism started acting up, would not lock and unlock. anyone with same problem? please help!!!
What was the result?
Had the car brought in to dealer when still under warranty. they checked it out and only replaced the blown fuse ($100.00). Told to bring it back if it happens again. Now the vehicle is out of warranty. Is anyone out there having the same issues.
Otherwise, if this was mine I'd try to determine whether the problem was in the locking/unlocking door solenoids (a defective solenoid), the wiring to the doors (like wires flexing in the door jamb shorting), the switch panel, or the control circuitry. Since it is failing pretty regularly, that should be easier to do....although a pain in that you'll have to take a bunch of doors apart.
Opening the doors up and unplugging the solenoids will help eliminate them, or prove they are the problem. You can meter out the switches, to verify that they are internally shorting. If the wiring is shorting out, then it is most likely at the drivers door jamp, which is the door that gets the most opening and shutting on vehicles. If none of those prove to be the problem, then suspect the control circuitry itself.
John
1. 50A breaker LREC2 draws approx .082 amps
2. 10A IP/DIC draws approx .435 amps
3. 15A Radio draws approx 1.3 amps
4. 15A Info draws approx .21 amps
5. 30A Radio draws approx .64 amps
6. 30A TREC draws .05 amps
Approximately 0.143 amps being drawn with those 6 pulled. I did not bother to check the fuses on the driver side of the dash yet.
I think the radio is the issue, but without knowing what these should draw, how can I confirm.
Any help is greatly appreciated.
and help or thoughts would be great
thank you
Did you find any solutions? Seems I'm having similar issues!!!
Thanks for the help!!!
