2005 Surburban Tire issues
Anyone have issues with the Bridgestone Dueler HT tires on their Surburban? Had the dealer put two new ones on the front but they are feathering too. Had the front end alignment checked 3 times at two diff places and all state the front end is spot on. ???
Can you explain little better what happens to your tires?
Arrie
I had an issue with front tires wearing on inside edge forming flats (cupping?) around the tire and when checked for alignment it was (toe) right in the middle of the spec. When I was ready to replace those Duelers I had my toe closed to the minimum limit on that spec. Now with Good Year Triple Tread Fortera tires I don't see any sign of a problem yet. Has driven only about 6000 miles on them though.
Do you drive a lot on highway, i.e. fast speeds? Down force with high speed pulls truck down and opens the toe and it could be your problem. I think this is the reason for my problem since 85% of my driving is on highways.
Arrie
I had experience with the Brigstones on my last Suburban and couldnt stand them. Very noisy.
I am using Goodyear Wrangler AT/S on my current 2003 Z71. On my second set now, the first set lasted 66,000 miles. There was plenty of tread left on them, but I blew one on the highway and there was indications of dry rot so I went ahead and replaced them all. Have 30,000 on them now and there is still lots of life in them. I highly recommend the Wranglers.
Ray
They issues were fixed, but for a $40,000 + vehicle, this is unacceptable!! I like the size and power, but the craftsmanship sucks!
How many miles do you have on the vehicle now? I would call GM's number and complain if the dealer won't replace them at their expense..
Just for info. The Forteras are very good tires for my Tahoe. I can highly recommend them if someone is looking for good tires to replace those Duelers.
-Arrie-
