Toyota Sienna Rust problem
Hi, I was wondering if anyone else had this problem. My 2006 Sienna at only 4 months got some rust on the passenger door. It was fixed by the dealer. Now, on the inside bottom of both side doors, rust showed up. Not just a few dots but big spots. We live in Ontario. Snow and salt may have a role, but not after 2 years and definitely not after 4 months.
Anyone else had this problem with their Sienna?
The panels are galvanized and should not rust that easily. Was yours bought brand new, or used? Were the panels ever repaired?
I just came from the dealer and after the collision center refused to fix the problem since we have 80k KM (while the warranty is up to 60k) they agreed that there is a problem and fixed it by sanding the rust and applying rust inhibitor. It should solve the problem for a while.
I was told that rust on the bottom of the front doors is a known problem but on the back doors (to be precise, it's on inside, on the body and not on the door itself) is not something they know about.
One more thing they told me is that starting with 2009 the paint will be water based on all Toyotas. It's supposed to be a bit more resistant to chipping.
i didnt know if there was a rust issue on the sienna's like there is on the Thundra.
Also you should check the front headlamps, typically they dull out quickly due to sun rays.
I kept my Sienna for 131,000 KM (Montreal Canada) and 39 months.
Than i sold it due to expensive repairs, such as alternator, steering assembly, and radiator leaking from inside. All under 100,000 km of highway driving.
Our Sienna 3.3 L also had the bad drive by wire problem. You would push hard on the accelerator from stand still, and most of the time, nothing would happen.
Dangerous indeed when trying to move along to a quicker lane, from a stand still lane in traffic. The dealer had reprogrammed the ECM, but to no vail.
Finally we sold the Sienna, and have had no regrets. It was a fine vehicule, if you did not push it in any way. Wide body made it comfortable, and the engine and transmission were both very smooth. Dangerous package however.
Best
