Jeep Liberty Dome Light Problems
The dome lights on my 2002 Jeep Liberty come on intermittently (with absolutely no activation). They may flash numerous times, stay on for a couple of minutes, etc. Eventually they will go off.
There is no obvious reason for anything activating the lights............they have a mind of their own.
The dealership thought the radio was the problem (because the factory radio would simply go off for no apparent reason, and then come back on by itself).
After replacing the radio, the dome light problem still persists.
Any help with this probelm would be greatly appreciated.
Any suggestions on how to address this problem. Do I need to replace the "BCM", or try to trace the bad contact / interference??
Again, thanks for your help.
astick
- Check the battery lugs for loose connection,
- Access the BCM by removing the left vertical side panel of the dashboard accessible when the driver door is open,
- Check the BCM connectors and cables; this is where everything is centralized.
Try to remember what you just did or what was regulated or changed when the light suddenly came on. I can get either the dome light, one headlight, sometimes both without the rear lights simply by opening my door or turning off my headlights when the engine comes to a full stop. This usually happens when I need to rush
