-September 2024 Special Lease Deals-
Snapped parking brake cable
tom_osentom_osen Member Posts: 1
edited May 2014 in Toyota
I have a snapped parking brake cable and I need help. I have removed the old one (the front section) and replaced it with a new one. My problem is under the dash. The snapped cable is in the pull lever just below the pin that holds it inside the trough of the pull lever. I cannot remove the old pin and the small section of cable. The cable seems to have snapped above the pulley (above where it come up through the floor) in the area where the cable bends. I have tried removing the electronic signal switch, removed the one bolt holding the bracket to the floor, and removed the lower portion of the dash panel (under the steering column) to be able to remove one of the bolts attaching the pull lever bracket to the dash. Help!!...I cannot attach the new cable until i figure out how to remove the remaining portion of the old cable. Can anyone help?
  • kens4kens4 Member Posts: 1
    You must remove the brake switch at the end of the tube ,also you have the dash panel off ,then at the top of the tube where the parking brake rod handle is there are 2 little "arms' sticking up.The first one closest to the dash must be pushed towards the firewall then you can push the parking rod all the way in.handle must be pushed all the way in first, and then you will be able to remove the crimped on barrel end of the cable.the rod will stick out just enough for you to remove it. pully must be removed also,those arms are the 'rachets'you hear when you pull the parking brake,the first one keeps the arm locked in place when you pull the arm out 'closest to the firewall ,second one stops the brake tube from going too far in and damaging your brake light switch.you do not need to remove any mounting bolts.
  • puravidacrpuravidacr Member Posts: 1
    I have a 2004 Runner with 149,000 km (diesel) - the SRS light comes on then goes off for a while then back on.
    1. Can I replace this myself?
    2. If so where is the sensor located?
    3. I also understand that the belt replacement light should come on at 150 km as well - same questions as above
    Give Toyota 4Runner Maintenance and Repair a try.
    SUVs and Smart Shopper
