Cabin air filter
wfd1wfd1 Member Posts: 1
edited April 2014 in Jeep
Can anyone tell me where the cabin filter is located in my 99 Jeep Grand cherokee? I would like to change it out if I could only find where it goes.
  • rpaterpate Member Posts: 3
    New to the post. be advised that Jeeps DO NOT come from the factory with cabin air filters. There is a kit available to install one. It is very simple to do so, kit comes with instructions
    00 JGC repaced rear shocks, sway bar links, bushings. Cannot see anything loose, still has "thump" when going over bumps. Any ideas? Thanks.
  • tuggajbtuggajb Member Posts: 646
    make sure that the bottom bolt that holds the shock on is tight if just snug will get small amount of play and cause thump
