-September 2024 Special Lease Deals-
Toyota RAV4 Vibration Tire Warning Light
[u][i][b]BEFORE SEARCHING:[/b][/i][/u]
Girlfriend drives a RaV4. I put on some 31's from my ford. I used CNC'ed wheel spacers made SPECIFICALLY for the bolt hole pattern / size.
On way home she stated the steering wheel shook at about 60mph and there was a " exclamation point wanring light " on her dash.
I don't think it is the spacers as they seemed to "center" themselves when I tightened the lugnuts. This is due to there being no adjustment. It is made only for this pattern wheel. Maybe I need to go over front wheels again and make sure they are centered?
And somebody said the warning light is due to wheel being further away from hub or something. This can't be more then a reflash ut I don't know where / how / how much this is done.
[u][i][b]AFTER SEARCHING[/b][/i][/u]
" Exclamation Warning Light " - I found out this is about the new rims NOT having some tire pressure sensor. The computer doesn't recognize these new rims / tires so it gives off a "warning light". Nothing is wrong with car at all, just a confused ECU. My question is, while I know flashing the ECU is basically my only option, can I get a code reader form liek Pepboys and flash that wanring out of there?
Vibration - I think this is mostly due to improperly balanced tires. At low speed the car is straight and true with no vibrations according to her. I am going to realign the tires (even though it probably isn't the wheel spacers). I think i just need a front end alignment.
Any idea / suggestions / solutions on the above?
SUVs and Smart Shopper
Thank you so much for the reply; that makes me feel better. Now if I could only figure out how to get the heat working without the air conditioning coming on!
I just hate that I bought a brand new car, am leaving town in 2 days and will have to find time to take the car and get the tires filled with air. But, your post makes sense and I thank you so much!
