Grand Cherokee MAF and Oxygen Sensor
92montero92montero Member Posts: 1
edited September 2014 in Jeep
I've got a 93 Grand Cherokee V8 and want to try and fix the following problem before taking it to the shop:
When I start it up, it starts and idles ok, but after about 2-3 minutes it starts hesitating.
Then I can hear a loud vacuum sound coming from the intake throttle body (as if it was asking for more air).
After this, it starts to act like it is going to stall, reving up and down while idleling, and quite a bit of black smoke begings to comes out through the tail pipe.
If I rev it up it will rev up but still hesitates and continues to smoke.
And it will eventually die. Once this happens it takes a while to start back up again.
It appears to be an air fuel mixture problem. Which leads me to believe it may be one of the sensors.
I replaced the cap and rotor, it was time to change it anyways, but did not fix the problem.
I noticed it began doing this after driving through a deep puddle of water but it went away. But now it started doing it again.
Any help would be great appreciated.
  • stukistuki Member Posts: 1
    Yes that definitely sounds like you have a faulty O2 sensor. I had exactly same symptons on my jeep yesterday after wading through a large pond my mpg dropped to 8 and clouds of black smoke poured out. I guessed it was the O2 sensor so put my OBDII reader on today and sure enough it came back O2 sensor fault. Replaced it today and now seems to be working fine.
    Good Luck
  • ebizsearchebizsearch Member Posts: 4
    Have a 1995 jeep grand cherokee with V-8, 318 cid. Can not find location to replace.
    Can I get to it without other parts removal?
    Thanks for any help.
  • acshacsh Member Posts: 2
    i am looking for the oxygen sensor that is bank2 sensor 1 where is it located upstream or downstream i am not sure i dont want to replace the wrong one and also if any one knows what to check for code p1494 which is evap switch or i guess a solinoid or something
