Grand Cherokee Mirror
The mirror on the drivers door has smoked up to the point you can't see out of it. Any idea why this happened and how can I remove it to replace it with a new one. Any idea on the cost? It started out as a small line across the top and has since covered the entire mirror. This is a heated mirror as well as a dimmer mirror. Thanks for any help. Also has there been a TSB on this problem?
There will be no TSB on this since it is a problem that occurs with age and sometimes bad luck... there are many variables that can cause the mirror to bleed and cause that. Hope I have helped you, let me know if you need to know anything else..
I have however found a couple avenues for you to mention... for some reason Jeep Grand Cherokee's are very particular when it comes to tightening the lug nuts... each lug nut has to be torqued to the specific torque specifications. Over tightening the lug nuts will cause the rotor to warp.... with the Jeep being that new I would definately mention that the next time you have your tires rotated. All dealerships and quick oil changes should have a thing call a torx stix... it only tightens to a certain tightness when snugging down the lug nuts with a 1/2 inch impact... I have tested numerous places around the Cleveland area and everyone over tightens the lugnuts as much as 75 - 80 lbs... that crazy... Hope this helps you in the future with this brake issue... if it continues please let me know.
