adding a sync system to an LS?
I have an '05 LSE witht the THX navigaion touchscreen system. I am wanting to add bluetooth of somesort so that I can use my cell phone through the stereo like the sync system. Does anyone have any ideas?
I know my doesn't and I can't imagine how the integration will work.
I've seen it done on a porche (and the features from the phone were nicely integrated into the NAV system over bluetooth). Keep in mind the porche was not retrofitted with the bluetooth option from the begining and the owner bought a connector at the back of the unit to add bluetooth functionality.
There must be companies out there that sell these in-line connectors for the Lincoln Navigation system. (I just don't happen to be very familiar with them)
Hopefully others have been exposed to them and can suggest something for us
Adrian
As per other posts I've read some newer fords (08 models) had the option of adding SYNC to them and Ford created specific kits for each car which included the steering wheel controls and the NAV system. Since no kits were created for the older generation LS's I doubt that this would be a cookie cutter solution but rather a customization that would be beyond my abilities (changing steering wheel and wires)
If someone is aware of a similar product out there that would integrate with the Lincoln LS '03 THX Navigation system it would be great to know about.
In the end I want to use my existing NAV system to dial out and to receive incoming calls over bluetooth (all of it using the display already there) not using additional external connectors (such as the Parrot Adaptors which would require front mounting of their unit)
Adrian
I was quickly told that it's not possible for the LS series....
- I guess we're stuck with off-market products as Lincoln/Ford do not have one for us
Adrian
