Jeep Liberty Diesel EGR Service - Replacement Help
imthomasimthomas Member Posts: 6
edited April 2014 in Jeep
We have a '06 Liberty diesel 85k miles with engine light on - egr valve suspected (scan code confirmed) - local shop suggested - remove & clean before replacement. Is there a "how-to" page out there that will help me with this job. Thanks, MT
  • mtb_tdimtb_tdi Member Posts: 6
    The valve is kind of a pain to get to. I have my EGR blocked off and a flash tuning from KermaTDI.com. This allows me to have a non-functioning EGR and not get a CEL. Talk to Charlie at KermaTDI.com if you would like to go that route. I have never removed my EGR, I have tried to disconnect it and the connector is a pain. My EGR simply has a block off plate on it so no exhaust re-enters my engine.
  • imthomasimthomas Member Posts: 6
    Thanks for the note & I'll send Charlie as to blocking off the valve. MT
    FYI: My tuning is only used when I am off-road.
  • caribou1caribou1 Member Posts: 1,354
    How does your engine perform when you go off-road?
    Do you have the nerve to push it to it's limit?
    You must have special tires ;);)
    I don't push it to it's limit due to the TC :mad: . I need a suncoast!!!
