-September 2024 Special Lease Deals-
Lexus ES Navigation System
Sure it is nice to have a GPS nav system but what happens after a few years?
The map will be outdated and I think you can buy an upgrade DVD for around $300?
I think up to certain time, Lexus will not provide update anymore then what can owners do?
GPS option cost a bit to get at the beginning but it doesn't make a lot of different when it come to trade in or resell. So does it worth the money to get the GPS?
Or maybe it's better NOT to get the GPS option and save the money to get a portable GPS. That way, you don't have to worry about the updated build in GPS.
What do you guys think?
Newbie with 2 questions.
Question 1.
Is there an "easy" way to remove the plastic (metal?) panel that contains the two central vents and the navigation on a 2002 ES300? I'd like to install a vent-snap-on back-up camera monitor and run the 12v wire to some source of power in that area. Alternatively, if the upper dash (that goes all the way to the windshield) could be removed, that might work too. I'd like to hide this power-wire for the camera. Also, is there a preferred source for power that can be easily identified?
Question/Step 2.
This back-up camera, like most, is wired to the back-up lights. Given that the back-up lights are on the trunk section of the rear lights (and that the camera will go on the area of the license plate), is it easy to remove the liner on the trunk panel (that opens)? Any tricks or traps to those little snap-things?
