-September 2024 Special Lease Deals-
Honda Civic Winter Driving
Considering buying a '09 Civic LX. How do they do in the snow.
I replaced the Bridgestones on my 07 EX at 18,000 miles. I almost totaled several times.
There a lots of good Premium All Season M&S's out there. IMO, the Yokohama TRZ is the best value. I've lost about 1mpg with them. However its worth it too me. The car is soo low you need to be able pull the undercarriage over the snow.
The TRZ's are better than the Goodyear Triple Treads IMO.
I went to the dealer as a result of a discussion in another blog about handling problems on slippery pavement. Mine was so bad I had started looking at buying a new//different car.
The dealer will replace the rear upper control arms which (originally) were designed to "tilt" the wheels allowing for better handling. Only problem with this great idea is that it causes uneven tire wear (a prerequisite to having the dealer replace the parts and to do an alignment on Honda) and lack of control on slippery pavement.
Mine was fixed yesterday. My fingers and toes are crossed cause I love this little car and want to keep it.
That said, as others have indicated, the car sits low to the ground, so if the snow gets too deep, it could be a problem. And it is a light car, relatively speaking, so it can't bully its way through. Also, good tire tread is critical. You don't need expensive or special tire, just make sure you have enough tread on them.
Make sure you know how to respond to a skid. And if you don't have ABS, learn how to pump the brakes.
Over the years I've learned one of those maxims about winter driving: "If the weather is so bad that you need 4WD, then STAY HOME! If you aren't already home, stay where you are, because it is almost always safer in the long run."
I'm considering making a 3 hour drive this weekend to the Tahoe, CA ski area, but it is scheduled to snow/rain. Anyone know if my Honda Civic EX from 1999 will be okay? I have prior experience driving in the snow.
