Chevy Suburban oil pressure sending unit
tenmoretenmore Member Posts: 2
edited August 2014 in Chevrolet
I have a 02 burb 2500 leaking oil. had the oil changed today the tech said he thinks it is coming from the oil pressure sending unit. Where is it and what is it? what is required to fix ths problem and can i do it my self?????
    It's basically a sensor, which measures the engine oil pressure, and sends an electrical signal to the computer and dash to indicate how much oil pressure you have.
  • tenmoretenmore Member Posts: 2
    is it a sensor that if bad can and will leak oil though??
    Sure, on one side of the sensor (inside the engine), it's having the oil squirt on it so it can sense the pressure of the oil. On the outside of the engine, it has electrical connections, to send that info up to the gauges and computer.
    I guess as an analogy, you could think of a room full of people wanting to get out, and a big guy bouncer on the outside of the door holding the front door shut. He can tell by holding the door, that there is either one person pushing on the door (low pressure), or 10 people pushing on the door to get out (high pressure). If he gets weak and lets go of the door and the door opens, then the people come out (and the oil is able to leak out).
  • lrw65lrw65 Member Posts: 2
    Would the sensor need to be replaced or the seal around the sensor?
