Kia Rondo Theft Alarm System
I just bought a used '07 4 cyl Rondo EX and noticed that the front side windows have a triangle sticker on them that says something like 'Security System'.
I bought the car from an auction, so I have no contact with the original owner.
Did '07 EX Rondos come factory equiped with a security system, or did the previous owner just put somestickers on the windows? How can I find out?
Your immobilizer system is comprised of a small transponder in the ignition key
and electronic devices inside the vehicle. With the immobilizer system, whenever
you insert your ignition key into the ignition switch and turn it to ON, it checks
and determines and verifies if the ignition key is valid or not. If the key is determined to be valid, the engine will start. If the key is determined to be invalid, the engine will not start.
Did you not get an owners manual with your vehicle?
I checked it out by locking the doors (with the windows open), and waiting about 30 seconds. Then, when I opened the door by reaching in, the alarm went off!
