Infinity G37 Best Performance Options
Per the article comparing to the Acura the Journey with Sport option package was the best performer of the G37 options but this article also mentioned that you could not get the sport option (S01) with AWD. I went the Edmunds pricing with model selection and it in fact did allow me to select the sport option on the AWD model.
So a few questions:
1) Can you equip the AWD version with the sport package(18" Mag wheels, paddle shifter, quick steering, better brakes)?
2) Is there a difference between the Sport option package on the AWD model vs. the Sport option package on the 2WD Journey model?
3) If equiping for best performance what options for an automatic Journey and AWD?
4) Would the manual trans Sport model be that much of a better performer and why doesn't it come with the 18" wheels, upgraded brake options ,etc. or does it?
5) How would the AWD with Sport package(if available) compare to the Journey with Sport package performance/handling wise?
6) Are there some photo's out there that show the aero package, rear spoiler and the front chin spoiler, black grill,etc?
Thanks for any help on my lengthy questions.
Mike (Interested G37 buyer)
So a few questions:
1. Yes. You will get the wheels, paddles, seat bolsters, and nifty little "S" behind the G37x tag, but not the stiffer transmission. I'm not totally sure about the brakes, but let me tell you the ones on the AWD model are plenty strong.
2. Yes, see above.
3. You'll obviously want to get the sport package for the Journey model; it's more of a fun feature for the AWD model. The aero package might be helpful, too, but I've read that that's mostly cosmetic. I wasn't able to get that on mine, but it is available on both models.
4. If you're good with a manual, the manual model would be a better performer, which is usually the case. But that's highly operator-dependent. I'm pretty sure the manual model ONLY comes with the sport package, i.e., you can't get manual without sport. So that may be why those other things aren't listed as options.
5. Performance for AWD will be slightly worse in good conditions, mostly because of the added weight of the AWD system. This is true for almost all cars, the only exceptions being the super-exotics with 450+ HP that will light up the back tires on a hard acceleration. That's why you'll see more cars like the GT-R and R8 coming with AWD. But for "regular" cars, AWD slows you down a bit.
Now in wet or snowy conditions, AWD is going to be a much, much better performer, so if you live in a place where that's an issue, AWD is going to be huge on those days. That's probably both obvious and not exactly what you're asking about, but I just had to put it in there to make the disclaimer.
6. There are many. Check out G37driver.com for examples of the stock spoilers, aero package, and grill, and many other mods.
Hope that helps!
If you have nav, you don't need a CD changer. The "music box" feature can copy your CD's to its hard drive, so you only have to put the CD in once. Each day, I take a new CD and burn it to the hard drive, and then take it back in the house when I get home from work (it takes about 15 minutes to copy the CD). Before too long, you'll have quite the collection in your car.
http://www.g37-tech.com/wiki/11-speaker_Infiniti_%22Studio_on_Wheels%22_by_Bose_- - audio_system#Bose_11-speaker_Infiniti_Studio_on_Wheels
Am i missing something?
If you go here:
http://g35driver.com/forums/g37-sedan/242727-exclusive-2009-infiniti-g37-sedan-p- ics-impressions.html
You'll see some pics of taillights and wheels and stuff, and then there is a pic that shows that there is no trunk-mounted CD player. That has been discarded for the 09 model.
I apologize if my post sounded smarmy - I didn't intend for it to, if it did. It's hard to tell a person's tone on a message board. Similarly, I couldn't tell if your post was a joke, and that's mostly my fault, simply because I hadn't heard of this setup in previous years' models.
Anyway, bottom line - Navi = one CD in dash, but hard drive to copy CDs; Non-Navi = 6 CD player in dash. No trunk-mounted CD changer is available.
Hope that helps!
I'm curious - how is having a changer in the trunk going to improve quality? You could just as easily burn those 6 CD's to the hard drive. Then you can have your quality AND quantity if you happen to have more than 6 good ones. It's really very simple - it'll do it for you automatically if you set it up to do so.
Is it mostly a change in exhaust note?
Is there a significant change in performance that translates to real world driving?
