Ford Explorer Noises
I have a 2004 Explorer XLT 4.0 SOHC.
It is making a noise at the front of the engine.
My mechanic says it needs the timing chain replaced.
Cost $2,412.00. I can't afford anything near that.
Does anyone know the life expectancy of the chain
if I drive it the way it is?
I saw you note to the bulletin board at Edmunds about your explorer with the whining noise during accelleration. I have an 03 explorer and I have the same problem. I was told that I may need a new transmission although I have not yet confirmed that with another shop. What did you figure out? I'd really appreciate it if you'd share with me what you learned about the problem. Thanks.
Steve
sborowka@optonline.net
Has anyone else found the cause of their noise?
Scott
Sounds like the same issue, and I'm still looking for an answer.
http://www.2carpros.com/questions/ford-explorer-2004-ford-explorer-thumping-like- -a-flat-spot-on-tire
